Question about Canon PIXMA MP530 All-In-One InkJet Printer
Same problem... will not turn on and power is connected ??
Yes it is plugged into a good outlet and it was fine yesterday ???
No power when I turn the unit on
  1. Verify whether or not the date and time appear on your Brother machine's LCD. If anything is displayed on your Brother machine's LCD, then it is most likely receiving power.
    1. If your Brother machine's LCD is blank, continue toStep 2.
    2. If your Brother machine's LCD displays a message other than the date and time, please refer to the FAQ about the message being displayed for further information.
  2. Verify the Brother machine's power cord is connected securely to the power outlet. If you are using a surge protector, extension cord, or power switch, disconnect it and plug the Brother machine directly into the wall outlet.
  3. If the Brother machine is turned OFF, its LCD will be blank. Please make sure the Brother machine is powered ON by pressing and holding theOn/OfforPower Savekey. This key is located in the upper-right corner of the control panel.
  4. If your Brother machine's LCD is still blank, connect it to a completely different, known working power outlet. If the Brother machine powers up, then the problem is related to the original outlet.
    -OR-
    Confirm the power outlet is working by plugging another known working device (a lamp, radio, etc.) directly into the same outlet. If the other device does not work, the problem is related to that power outlet. If a wall switch controls the outlet, verify that the switch is ON.
  5. If your Brother machine still will not power on, please contact Brother Customer Service.In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :
Brother Printer Support
Nov 14, 2013 | Brother MFC-J220 All-in-One Color Inkjet...
Philips DVD player ... No Power?
Yes! that is the most logical, the power supply board is usually where cap will be located, sometimes it will have a slight bulge at the top telling you it is open.
Mar 21, 2012 | Philips Televison & Video
Hi my name is samantha and i have a problem i have an amp of 250 watts and i was playing it yesterday and it was fine and then today i was playing it again i connected it to my lap top and it was fine....
Houses and outlets have protections called GFI. The room (or outlet) does not have to be in a wet area to be on the circuit of an GFI plug.
Get a lamp, and test the outlet. If the lamp does not light, then you know the outlet is turned off. Look for the circuit breaker box, or a tripped GFI outlet.
good luck and don't forget to vote!!!
Sep 30, 2010 | Radio Shack Audio Players & Recorders
Whirlpool refrigerator trips gfci outlet
Yes ,, if the fridge outlet is behind the fridge and therefore not accessible for use by counter top appliances .. then yes change it to a regular outlet.
The cause is probably the compressor, getting a bit noisy..electrical noise I mean.
Feb 23, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool DU1100XTPS 9 Dishwasher acts as if no power
Is your dishwasher have a power cord and plugged into a wall outlet under the sink if the answer is yes then maybe the GFI outlet has tripped and all you need to do is reset the button on the outlet
Sep 22, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
Worked fine yesterday, today zilch !!
One computer I fixed had its internal power regulation confused. With the AC adapter plugged in, holding the power switch down for twelve seconds, then pressing it again, switched it back on. This sort of problem can come from a variety of causes, though. There is an internal power distribution chip which could have received a static electric shock or power surge and gotten cooked. The RAM could have gone bad. The socket where the adapter plugs into the computer could have been cracked loose. Check the power switch and then RAM first, and write more if that doesn't fix it.
Jan 05, 2009 | Toshiba Satellite M105-S3041Notebook
No power- no anything
Try the steps mentioned bellow
Unplug the power cord from the All-In-One as well as the power outlet when there is still power in the All-In-One. and wait for atleast 1Min
Plug the power cord directly to a wall outlet without surg protector. (if possible connect it to a different power outlet)
Before connecting the power cord to the All-In-One press and hold the # and no 6 button and then insert the power cord, do not release the keys
until you see a message a reset (if the screen goes blank then release the keys and turn the power on)
Then check and see
Good Luck
Oct 02, 2008 | HP Officejet 5510 All-In-One Thermal...
My PC won't power on.
First, check all connections insid the computer. then,depending on your skill level and warranty status, you can try the following:
Remove or disconnect all accessories from the pc (Hard drive, floppy, cd/dvd roms and accessory cards) Then see if it will turn on. If yes, the replace the items one by one unrtil it fails.
If no, then you must either try a different (known good) power supply on your motherboard. (you can also see if your power supply powers a known good motherboard).
If not, the you motherboard is likey faulty.
Jun 02, 2008 | E-Machines T3985 PC Desktop
Moved Washer and Now no Electrical
Suggestion: You dont need any special outlet. With a tester (you can get this in any electric shop) see if there is power in the outlet. You said it was hot?? It is not supposed to be hot. Try another outlet; & you could unscrew your machine plug to see if all the three wires are okay, ie. well connected, screwed in.
Sep 21, 2007 | Kenmore Elite 45986 Front Load Washer
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
23 people viewed this question
old marine
old marine
