Question about Music
Problems with certain channels and there gain pots
I have a similar problem in the the gain for channels 6, 9, 12 and 16 all seem to have intermittent faults.
Channel six and nine seem to come back on after a gentle tap on the channel strip, 12 is a lower gain then the rest but is useable and 16 has a problem when you turn the gain pot past 11 o'clock - the level just drops.
Is this an issue that could be repaired?
    Novelist:
  • 133 Answers
I assume you are talking about an audio mixer, here's what i think:
I'm not sure about channels 12 and 16, but channels 6 and 9 seem like having some loose solder contacts, which usually occur with long term use - you need to remove the problematic channel strips and check the solder contacts on any of the pots / switches / connectors that protrude through the top panel - resolder any loose or bad solder contacts (i usually resolder ALL pins on ALL connectors, pots and switches just to be sure).
As for the lower gain on CH12 - see if the mixing slider is connected via wires, if so, compare it to the connections on other channels, see if there is a loose wire or if the wires are connected in a wrong way (i had a "lower gain" issue with a mixer once that turned out to be a wrongly connected mixing slider - i obviously wasn't the first person to repair that mixer...)
Channel 16: check input preamp IC, could be a bad electrolytic filter capacitor or other components, possibly a faulty IC.
Hope some of this helps...
regards
3rq8 (Triarcuate)
Posted on Sep 08, 2009
Still have sound through speaker with channel B gain input set to OFF
This could be fixed checking/changing the vol pot of the "B" channel, also i would highly recommend to clean all back switches, including Stereo/Bridge switch, which it should be outwards to operate in Stereo mode, let me know if i can help more.
Jan 26, 2013 | Peavey PV 900 Power Amp
Marshall valvestate 8080 experiences volume surges. Seems randoms as occasionally it won't happen or it will happen less than other times. But all the same annoying when playing! I get rid of i
Most likely cause for this is an intermittent potentiometer. Check to see if any of them are mechanically loose as this is a sign that they have been damaged and could have cracked the wiper surface inside the pot causing this problem. Alternatively, any switch that controls any gain setting could also be intermittent or dirty. Gain of the amplifier should be stable, but is controlled by the feedback and signal injection at the pots so that is where to look first. Good luck, as intermittent problems are tricky, but sometimes better than no function at all which can be more costly.
Jun 24, 2017 | Marshall Amplification Music
Power problems with my Peavey PV-1500
Suspect that the pot is broken, or start cleaning all the back switches, this pv amps suffer from a terrible switch quality.
Mar 15, 2012 | Peavey Electronics Peavey Pv 1500 Power...
The right output channel on the right side of my pmc 05 pro 4 has very low output. I can hear both right and left output channels in the headphones when I have the cue selected but when I try to monitor...
I assume you swapped thee output leads as well as the inputs which you di mention, to verify you amps and cables...
The Vestax schematic I have is NOT your same model, but the companies often re-use circuitry. In the schematic I have it appears that the two channels go through two levels of NJM2068L op amps.
In these two levels there is both a master gain control. It is important to know whether the gain control varies the output level of the right, even if it is low. Also in this gain control area is a master balance pot which varies the ratio of the left and right and is CAPABLE of taking either channel to near zero output... IF you have that control check it for sure !!! The pot is a dual employing both an A taper and C taper which is a reverse of the A.
The right tool for troubleshooting this is an oscilloscope, but first an inspection looking for board cracks around the output and pot area is in order.
Jan 01, 2011 | Vestax PMC-05PRO IV PMC-05 PRO 4 DJ MIXER
I just bought a used valveking 100 half stack and the 1st channel does not work, second channel works but seems to have a loose input jack as connection is intermittent and affected by wiggling the input...
Same thing... they probably broke both jacks. Sometimes the guts of the jack is broken and it doesn't appear to be broken but is broken internally. You may find broken solder on the pins to these jacks as well.
Note that the two input jacks have a different gain.
Here is schematic: http://elektrotanya.com/peavey_valveking_100_212.pdf/download.html
Dec 02, 2010 | Peavey Valveking Head
Line 6 AX2 212, Are all of the pots 10K Linear ( apart from the volume which is dual ) or are any Log pots? I have changed the pots for linears as I was suffering intermittent problems, the sound is back...
Given your description of intermittent problems, I would venture an educated guess that the problem was NOT the pots to start with. Usually pots will have a part number and you may find an "A" or a "B" indicating the taper.
Look for a circuit board crack in the vicinity of the guitar input section, especially near the pots. Use a BRIGHT led flashlight from opposite side of the board and inspect all solder joints around the input section.
Line 6 seems to play games with a "guitar sense" line that goes to the DSP so problems with that or a break in the circuit trace could cause the symptom.
Aug 22, 2010 | Music
The gain control no longer works on the clean/crunch channel. all other features work fine, whats wrong with my amp?
Hi there. Try re-soldering the control pot to circuit board connections. If not, use ohm meter to verify pot functionality. If bad, replace.
Thanks
Paul
Jul 10, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
I need to know the value pots to buy for vol,bass
If you have the old pots look on the edge of the cans (metal backs) for the code. Take them to a good electronics supplier and they can match them or measure the resistance from each outside pin with all pins free of interconnection. You will also need to know the audio tapers. The supplier should be able to tell from the codes.
Jul 08, 2009 | Music
MG100HDFX Amp - crunch setting seems too loud
There are 2 channels, Which means there are 2 sets of knobs ... One for clean and one for crunch. Start out with a low master volume and set up the crunch, Then the clen and switch between the 2 and make adjustments until they match volume wise ... Then turn the master up.
May 12, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
Music Logo
101 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
