Question about Raypak Free Hydraulic Lift Gate Delivery - No L...
The pilot light on the swimming goes out as soon as I try to ignite it.
  • 491 Answers
Are you holding the pilot button down when lighting the pilot light?
Hold it down longer once the pilot lights........ a minute may be necessary.
Posted on Sep 06, 2009
  • Scott Corey-reid Mar 18, 2014
    if you are not getting enough dc millivolts you will need to replace the pilot generator
The pilot light will only stay lit when you hold the pilot reset button in, as soon as you let the button out the pilot light goes out and the actual burners never come on. Any ideas?
Gas line is clogged if your pilot lite goes out - They got rid of pilot stoves because the pilot was always lit and using gas.
And without a lit pilot no way you can get the burner to ignite unless you use a match, assuming you have gas going to the burner!
Nov 08, 2015 | Heating & Cooling
Belling gas oven will only work when holding in ignition
The oven piot light heats a sensor which keeps the pilot light burning after releasing the button. The pilot light flame must be sensed by the sensor, the sensor must be in working condition. Replace the sensor or make necessary adjustments to make the pilot light flame burn on the sensor. The sensor is either a thermocouple or a generator. Thermocouple is standard, a generator needs to be properly matched with its type rated in millivolts, same rating for the replacement.
Feb 10, 2015 | Belling Kitchen Ranges
I have a model HE424M 33Mj/h gas Pyrox Firestar gas heater. I have just cleaned it and now it does not start. The pilot light is ok as is the spark but as soon as I let go of the centre button tha whole...
The pilot light has a thermocouple that allows gas to the pilot light while the flame is burning. If flame goes out it shuts gas off to the pilot jet. The thermocouple is bypassed by a switch during the initial ignition and once the thermocouple warms up after a minute or two of holding in the bypass switch, it should maintain the pilot. It seems that your thermocouple is faulty and needs to be replaced if pilot light keeps going out.
Sep 22, 2010 | Heating & Cooling
Pilot light will not stay lit As soon as I release the gas dial pilot light goes out. Heater will not ignite
messure thermo kopple must give couple of volts. check connections. these both are most of the times reasons for disfunction
Feb 07, 2010 | Blue Rhino Uniflame Patio Heater Stainless...
After about 5 years with no problems, the emberglow vent free gas logs are not igniting. the gas is coming out as i can hear it, but the ignite switch doesn't have any effect. if i hold a lit lighter in...
Sounds like a bad pilot sensor called a Thermocouple. It is a copper tube that goes from the gas valve to the pilot assembly. It is the smaller of the two tubes. They are available at better hardware or farm stores. It is best to unscrew it from the gas valve and pilot assembly and bring it with you when you shop for one. It is something any mechanically inclined homeowner can replace.
Dec 03, 2009 | Desa International CCL3924PTA 24" LP Gas...
My laars swimming pool pilot light keeps going out and it makes a clicking noise when it fires up and the pilot light goes out? it has been going on and off alot recently but can work for weeks on end then...
check power pile conections on gas control valve.it is the 2 wires that come from pilot asembly.if they are loose or have rust or oxidation this can affect pilot and cause intermittent outage. let me know
Jul 20, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Jandy Lite 2 - Pilot goes out when I turn to On
Sounds like you need a new thermo couple. found at most hardware stores
Jun 23, 2009 | Jandy Lite2 LG400 Ceramic Compact Heater
Raypak Free Hydraulic Lift Gate Delivery - No L... Logo
100 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
paulcarew
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
