Question about Konica 7075 All-In-One Laser Printer
Hi, Do you know wherer I can find an IP-601 Controller and Interface Kit so I can connect out Konica 7075 to our network?
    Habit-Forming:
    New Friend:
  • 106 Answers
From the Copier & printer store, to make sure they have go to Konica outlet.
Posted on Nov 04, 2014
How do i connect Konica Minolta photocopy Biz211 to a computer for network printing?
First of all, make sure that there is network interface card is installed in your photocopier.
If yes, then connect the network cable to the machine.
Then from the control panel of machine, Go to "Administrator Mode" Administrator Setting.
Press--Utility---then select "Admin Setting"
Now enter Admin Password=000000, press "OK"
Now go to "Network Settings" and Assign the IP address to the machine.
After assigning the IP address, install the relevant printer driver, (compatible with your operating system) You can also download the drivers from the internet.
During the installation of drivers, select "TCP/IP Port" This port is used for network printing.Enter the IP address of Photocopier in this port number.
After finishing the installation, your machine is ready for printing.
If you are still facing difficulty at any point, feel free to ask any time.
Jul 01, 2015 | Konica Minolta bizhub Office Equipment &...
Cannot Connect Konica 7075 To PC
You need to purchase IP-601 Print Controller (options) for Konica 7075, from there you can connect your PC.
Mar 29, 2014 | Konica 7075 All-In-One Laser Printer
How can i connect my printer konica 7075 to pc. anybody help please
You need to buy IP-601 Print Controller (options) for konica 7075. To be able to use it as a printer too.
IC 601 controller is connected to my konica minolta bizhub C6000 printer but display is showing controller is not connected
check the cable between the print controller/firey and the copier, also is the print controller/firey set up for a c6000
Feb 07, 2014 | Konica Minolta Office Equipment & Supplies
Use as printer konica 7075
you have to have the optional print controler IP601
How to setup a konica to print lpr .
  1. Click start then printers and faxes
  2. click add a printer
  3. click next
  4. make sure local printer attached to this computer is checked and uncheck the box for automatically detect and install my plug and play printer and click next
  5. click on create a new port and on the drop down box next to it select standard tcp/ip port. Click next.then next again
  6. enter the printer ip address and click next
  7. click custom and then settings.
  8. click lpr enter the queue name: print and make sure to check mark the box that says lpr byte counting enable and click ok
  9. click next then finish
  10. click have disc then browse for the driver disc and install the driver by clicking next tell it if you want it to be your default or not and click nexttell it you want to share and try to print a test page by clicking next then finish then ok for the test page popup
Sep 01, 2009 | Konica 7075 All-In-One Laser Printer
Good day, pls. help me, how can i install network ip address for konica 7035. thanks alot
Using arp command (Windows 95/98/NT/2000)
From Windows 95/98 MS-DOS prompt or at Windows NT/2000 command prompt, you can use the arp
command to assign the IP address to the network interface card. It is necessary that TCP/IP is set up
correctly on the computer that will execute the arp command. Perform the following procedure:
1. At Windows 95/98, select [MS-DOS prompt] from the [Start] menu. At Windows NT/2000, select
[Command prompt] from the [Start] menu.
2. Execute the arp command. For example, if the MAC address of the network interface card is
00:11:22:33:44:55 and the IP address to assign is 192.168.0.128, then input as shown below,
and then press [Enter].
(Example: C:\>arp -s 192.168.0.128 00-11-22-33-44-55
3. Execute the ping command for the assigned IP address. In this case no response is returned
from the network interface card.
(Example: C:\>ping 192.168.0.128
4. Turn off the main power supply to the print controller and the main body printer, then turn it
back on.
Chapter 2 Setting Up the Network Interface Card
2-4 Konica Network Interface Card INSTRUCTION MANUAL
A Status Page will be output. Check that the IP address is correctly set in the list. Or, when about 5
minutes have passed after having restarted the print controller and the main body printer using the
ping command, check that the network interface card responds correctly. The ping command is also
executed at Windows 95/98 MS-DOS prompt or Windows NT/2000 Command prompt. The example
of executing the ping command is shown below:
Aug 31, 2009 | Office Equipment & Supplies
Pls. help us,how can we used land cord to connect printer konica 7035 to computer. we already down load a driver from internet . we try many times to check sa IP address and test print but still we cannt...
Using arp command (UNIX)
From UNIX you can use the arp command to assign the IP address to the network interface card.
1. Turn off the print controller and the main body printer.
2. Log in as superuser on a host on the same subnet as the network interface card. However, if
the server resides on another subnet, complete this procedure to store the IP address in the
3. Find the MAC address of the network interface card. The address is printed on the Status Page
each time you turn on the print controller and the main body printer.
4. Edit the hosts file (usually /etc/hosts) or use NIS or DIS to add IP address and node name of
the network interface card. See the network administrator for the IP address. For example, a
network interface card with a name of printfast and an IP address of 192.9.200.200 has the
entry:
192.9.200.200 printfast
5. Add an entry to the arp cache for IP address and Mac address of the network interface card,
as:
arp -s 192.9.200.200 0:40:c8:0:0:ff
RS6000 (AIX) requires the ether option after arp -s. For example:
arp -s ether 192.9.200.200 0:40:c8:0:0:ff
6. Check the print controller and the main body printer to see that the network interface card is connected
to the network. Turn on the print controller and the main body printer.
7. Send a ping command to the network interface card to verify it is running on the network, as
for example:
ping 192.9.200.200 or ping printfast
The network interface card will not respond to this ping command but it will read its IP address
from the packets.
8. Turn off the print controller and the main body printer and back on again and then send the
ping command again to verify that the network interface card obtained its IP address. A confirmation
message displays as:
192.9.200.200 is alive
9. Remove the entry from the arp cache using the following command. Specify the network
interface card either by its IP address or by its name, for example:
arp -d printfast
Konica Network Interface Card INSTRUCTION MANUAL 2-5
Using MAP
By using MAP (Management Access Program) included the CD-ROM that comes with the network
interface card, you can automatically identify the network interface card on the network and set it up
for TCP/IP by using Web Utilities. To use this method to assign the IP address to the network interface
card, the following procedure should be performed on computers in advance:
• TCP/IP correctly configured
• IPX/SPX-compatible protocol installed
• MAP installed and MAP setup correctly executed
About how to set up TCP/IP and how to install IPX/SPX-compatible protocol, refer to Windows Help
menus for example. For MAP, refer to “Using MAP (Management Access Program)” in this chapter.
To change an IP address already assigned to a network interface card, you can not use the
arp command. Use Web Utilities instead. These methods also allow you to set up subnet
mask and default gateway, etc.
Using NIManage
Refer to “Chapter 7 AppleTalk Configuration”.
 Accessing Web Utilities
The network interface card is provided with an HTTP server having Web Utilities. By accessing this server,
you can change settings of the printing system. There are two ways to access Web Utilities, through a Web
Browser, either through Netscape Navigator, version 4.x or greater or through Internet Explorer, version 4.x
or greater.
• Use MAP to have the network interface card on the networks identified automatically, thereby accessing
Web Utilities.
• Use a Web Browser to type the IP address assigned to the network interface card, and thereby access
the Web Utilities. For example:
http://192.168.0.128/
If you designate the proxy setting in your Web Browser you cannot access the Web Utilities.
For more information see your network adminisrator.
2-6 Konica Network Interface Card INSTRUCTION MANUAL
A utility called MAP is provided on the CD-ROM that comes with the network interface card.
This program automatically identifies the network interface cards on the networks and lists them on Web
Browser screen. From this Web Browser list you can select a network interface card to change its settings
and control Web Utilities.
Aug 31, 2009 | Konica Minolta Office Equipment & Supplies
Konica 7022 with Problem code F-26-1
There is toner/starter spilled onto a sensor near the drum, it mite just need to be cleaned, this sensor monitors the drums abililty to develope a image, if the cleaning does not work it mite be the sensor or the drum. The drum needs to be removed to clean the sensors.
Mar 23, 2009 | Konica Minolta Office Equipment & Supplies
Konica 7022 (code F-26-1) Pls call service 0870-2425050)
i have a konica 7022 it say call service code F-35-3, what's wrong with it, help me.
Mar 21, 2009 | Toshiba 2060 Copier
Network
restart, wait a 1-3 minute, when the printer shows ready for copyng then look again.
Nov 16, 2007 | Konica Minolta bizhub C250 All-In-One...
63 people viewed this question
Top Konica Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
isaac johny
isaac johny
Are you a Konica Office Equipment and Supply Expert? Answer questions, earn points and help others
