Question about Whirlpool Ovens
I took the glass and handle off the front of my oven and now am having issues getting it back on. Any suggestions?
  • 999 Answers
You can add the make and model number or email me some pictures of the pieces...
erpaalai@verizon.net
Posted on Sep 17, 2009
Need to glue outer cold glass door to the door frame.. in cadco convection oven
not sure which to use but id go to a window auto glass shop and inquire
Dec 12, 2012 | Cadco Ovens
How do you put door back onto Electrolux wall oven......Been trying for hours, no success!
Hello paulascor549 - I completely understand that you took the oven door apart to clean it, therefore you must have took the following steps to do so. According from my research you would have to reassemble in reverse order. If you have already tried to do so and it proves to be ineffective, contact a professional to move forward accurately.
Door Removal and Cleaning of Interior Glass
Tools needed: Phillips head screwdriver or small quad bit driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
B. Refer to owners guide? With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Nov 24, 2012 | Electrolux 30" Built-In Single Electric...
Took apart glass oven door on a whirlpool. Where
Hello, bd_lft_up.gif bd_top_bg.gif bd_rt_top.gif bd_lft_bg.gif OVEN DOOR bd_rt_bg.gif bd_wpl_oven_door1.gif bd_wpl_oven_door2.gif clear.gif bd_lft_btm.gif bd_btm_bg.gif bd_rt_btm.gif Oven Door
#1 -- Oven door liner
#2 -- Oven inner glass
#3 -- Oven door hinge
#4 -- Retainer, glass
#5 -- Bracket, handle
#6 -- Door glass seal, top
#7 -- Door glass seal, side
#8 -- Oven outer door glass
#9 -- Door handle
#10
Read more: http://www.appliancepartspros.com/bd_whirpool_oven_parts.aspx#ixzz0pj5Z78oi
http://www.appliancepartspros.com .
Hope this helps.
Thanks
May 30, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
The inner glass door on my zanussi oven has come
You should be able to repair your existing door. Have a look around the perimeter of the door to see if there are any screws, particularly near the handle. You are looking to take the front fascia off the door, so that you can access the inside. Most doors have the front fascia held on by small brackets glued to the back of the glass that clip on to a fixing on the internal door. The top of the fascia is normally held in place by the handle. Once you have the front of the door off you can retrieve the piece of glass that has fallen out. You will almost certainly find that the glass has come away from the adhesive that was used to hold it in place. You will need to clean up the glass and the metal door and re-stick the glass using a high temperature oven door glue
Jan 31, 2010 | Zanussi ZBF360X Electric Single Oven
How to get the glass front back on oven door of Whirlpool range
Ok. Heres what I was dealing with....Dissasembled. NOW (after you scrubbed everything to your liking try this.
1: With the door laying "oven" surface down on a flat surface. Gently place glass sheet/pane down squaring it up evenly as you can.
2: (Might sound strange) Grab the door handle and reposition it where it needs to go and slide the glass in the "ledges". Even everything up square as possible. Insert screws(2), but do NOT tighten all the way.
3: Now you have 2 (L & R) uprights. Insert "handle" end of uprights first, then align carefully the "tips" into the holes, and then snug the oven handle screws.
4: Carefully align the metal "base" channel/seat with the glass so the window/glass seats on the bases slots/shelves. Align all holes and insert screws (4 - 2 screws on both sides of base), finally align the center screw and tighten snug.
5: Replace door on Range Unit ande get cookin again!!
Hope this helps. I think its a poor design to let anything inside the door. Nice Range/Oven unit. Just a bad door design in my opinion.
Oh Yeah. The door hinges only took me 4 months to figure it has built in hinge locks. THEY are VERY convenient and once you know how they work. They are an AWSSOME invention for what they do!!
Apr 18, 2009 | Whirlpool GBS277PDS Electric Single Oven
How do I take off the glass on my oven door to clean it?
I have a Kenmore oven and all I had to do was remove the screw at each end of the handle (accessed with the door open) and the very front section just opened up - SIMPLE!! Wiped it down put the screws back in. Did it all by myself - just have your cleaning cloth in reach before you start. Can't believe I looked at those drips for years and it was that simple!!!
Mar 21, 2009 | Maytag CWE4800A Electric Single Oven
Loose oven door handle
I had the same problem. We took the door off completely & turned it upside down. There are screws on the bottom of the door, take them out, take off bottom trim piece that holds the outside glass panel in place, remove glass panel and you can access the door handle screws and clean the inside of the glass while you are at it.
Jan 05, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool oven door
The metal bars go under the top door handle part, put them under the part you need to screw back in.
Sep 15, 2008 | Whirlpool RBS245PDS Electric Single Oven
Fixing a door
I took other hinge apart.
Removed front glass by removing handle -bar.
Removed upper screws of spring on both sides. loosened two bottom screws of spring assembly.
Removed control panel assembly by taking out 5 screws.
Started with one side hinge first.
Inserted larger arm of lever first then inserted small lever, pressed with small screwdriver to engage a little slot {bottom side} of smaller lever to little stud inside.
With the same screwdriver engaged a little hinge to the notch of larger arm..
Did the same thing for other hinge.
Put the upper screws back,
Tightened bottom screws back.
Put the front glass and handle-bar back.
Put control panel assembly back.
Now it is ready to go.
Door is Fixed.
Nanddas Bambhania.[Like to put things apart and putting them back.Helping friends solving their various mechanical and electrical problems.-big or small appliances]
May 09, 2008 | Cadco OV-250 Electric Single Oven
Ovens Logo
32 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
