Question about Kingston 2GB Secure Digital Memory Card
I have loaded a 2 Gb memorycard on my LG U990 Viewty phone but it is not recognised ie message ''external memory card not loaded''. What am I missing?
    President:
  • 2,600 Answers
Your phone may not support 2 gb cards. Also check the little slider lock on the card to make sure it is not in the locked position. Check the owners manual for the phone, it will tell you the size limit for the card.
Posted on Sep 06, 2009
Testimonial: "Thanks for suggestions, I have checked each but still not working so think it may be the card is not compatible with the U990 phone!"
Cant download pics etc from my lg u990 viewty to vista laptop
When I try to open the content (inorder to transfer files from internal memory to my pc) it says invalid access to memory. Why? And what is the solution?
Sep 12, 2009 | LG KU990 Viewty
Computer doesn't seem to recognise LG KU990i via usb
first check ur usb port that is it ok? sometimes some usb has problem when it become old. then check ur usb cable is that ok? if everything are ok then format ur pc and install usb 2 software for ur usb system. thanks
Aug 08, 2009 | LG KU990 Viewty
USIM LOCKED
Just get it from FastGSM KU990 Viewty Unlock Code Page
Make sure you have sim card from network your phone is locked to. You need it to be able to type the unlock code.
Jun 16, 2009 | LG KU990 Viewty
Phone can't recognize external memory card
Memory card should be Micro SD. The KU990 will only support cards up to and including 2gb, so if you have larger that is why phone will not recognise it. If you have 2gb or below, have you formatted it in the phone?
Apr 24, 2009 | LG KU990 Viewty
LG Cookie Won't Recognise Memory Card
it will need to be smaller then 8gb...... also micro SD......... NOT micro SDHD .....you also need to format it using the phone (check user guide for info on how to do this)
hope this works for you .....good luck
Apr 23, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Please help, i cant activate use of my memory card on the lg viewty
If its a new card, have you formatted it in the phone? (go to Menu, Settings, Phone Settings, Memory Manager, External Memory then click on the Format button).
To activate its use, go to Menu, Settings, Phone Settings, Memory Manager, Primary Storage Setting and select External Memory.
Apr 16, 2009 | LG KU990 Viewty
LG Viewty (KU990) Memory Card Issue
The default setting for the viewty camera is set as the handset. changing the primary storage setting to external memory does not change this.`Switch the camera on as if you were going to take a picture. Click on the cog wheel in the bottom left hand corner. click on the memory card icon (second to last icon on the left.) Top right will show memory in use. Select external memory and click the save icon below. follow the same process for the video camera. Pics and vids shoild now be saved on your memory card. If you take the memory card out you will have this process again.
Jan 13, 2009 | LG KU990 Viewty
My LG KU990 can not see my micro sd card even thought it's in the phonr
when you go into my files on he phone scroll right to the bottom and it should say external memory or memory card.
i hope this was help...
Dec 01, 2008 | LG KU990 Viewty
LG viewty 4 gb memeory card..I accidently formated ths on phone! how do i unformat it?
Hi, I also had this issue.
The solution is on http://communities.sandisk.com/sandisk/board/message?board.id=mobile&message.id=209
You need to google for an app from HP called SP27608.exe.
This will read the card as 4gb and let you reformat it.
May 10, 2008 | LG KU990 Viewty
Kingston 2GB Secure Digital Memory Card Logo
179 people viewed this question
Top Kingston Electronics - Others Experts
Jerry Umali
Tony
Are you a Kingston Electronics - Other Expert? Answer questions, earn points and help others
