Question about GE JVM1330BW/WW Microwave Oven
Ge microwave blows fuses, replaced fuse after hiltonjug's excellent advice and the next day it went through another one, doesn't sound good. Thanks, Jeff
    President:
  • GE Master
  • 1,922 Answers
Have you checked/replaced the : HI-Voltage capacitor,the HI-Voltage Diode, and checked the unit for current draw while its in operation?these are three main components of fuse failure
Posted on Sep 22, 2009
Need help with a power issue.
Most of the time you have defective door switches that make the fuse blow.
Nov 03, 2015 | GE JVM3670 Microwave Oven
I have a microwave JVM3670SK06  ge what amp fuse does it use
I found a good site to find parts for the microwave. It has the fuse for $7. GE WB27X10388 Line Fuse PartSelect
Here is another search form different sellers.
WB27X0007 GE Microwave Ceramic Fuse Replacement
The fuse info
Specifications:
  • 250 Volt.
  • 15 Amp.
  • Type: Fast Blow.
  • Approx. 1.25"L.
Oct 18, 2015 | GE Microwave Ovens
Why is my GE Advantium SCA2001 blowing the main fuse?
Yeah pal, you've not gone deep enough yet. You'll find a power wire bare inside the unit, pull it apart and tape that wire up to stop it from grounding out and blowing the fuse.
Aug 31, 2014 | GE Microwave Ovens
GE Profile Spacemaker XL1800 The microwave runs, the lights come on, timers goes, but it does not heat/cook and it makes a loud buzzing sound.What is wrong with it,and can I repair or trouble shoot it?
Hi
Thanks for using FixYa. If it’s a loud hum/buzz sound then 90% it’s usually a bad magnetron and other times it’s a bad high voltage diode. However, from what you have described it seems to be the magnetron. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 29, 2010 | GE XL1800 1100 Watts Microwave Oven
Microwave Blowing Fuse. Fixed. After Day, Fuse Blows Again.
Hello there:
If you have all ready changed out the fuse and it has happned again i would first check to see that the fuse is the right one for the machine (i am sure that you did this but please recheck ) next i would look at the controle board as the next culprit it maay be failing expecially if there were any pops ar sparks that was noticed before the initial failure.
Also check to see if all of the wires by the board a re not loose or looked burned ar if there is any grease or anything like this around the area
And finally check to see if the plate is turning ok and not sticking cause this would cause the microwave to overload and it wil make every fuse you put in there fail after just a couple of uses ok
SO please try all of these things that i have explained to you
I hope this is very helpful for you.
Best regards Michael
Dec 12, 2009 | GE JE2160 Microwave Oven
Hi, When my GE jvm1650bb microwave starts, it begins to work and then blows the fuse in the house. Does this every time, the circut is not overloaded. Is their a part that went bad that I can replace?
Try your oven on another circuit in your house. It is curious that your oven doesn't blow its own fuse before the house one. If it doesn't blow the fuse in the "new" circuit, check to see what is really on the kitchen circuit. It might, in fact, be overloaded. Good luck.
Nov 28, 2009 | GE JVM1650 1000 Watts Microwave Oven
GE microwave fuse
If it keeps blowing fuses there is something seriously wrong..it will be cheaper to buy a new one rather than get it repaired
Sep 06, 2009 | GE JVM1330BW/WW Microwave Oven
Fuse blows when I press ''Start''
Okay, the part you're describing is the magnetron, and you'll not find one cheap.
The good news is that this is probably not your problem.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/xformer.html
The best place to order Sharp parts is Tritronics. You can also call them at 866-779-5835
Nov 21, 2008 | Microwave Ovens
2 year old ge profile spacemaker Microwave lost all power
Inside unit is a cylinder fuse which can blow for a number of reasons. External cover needs to be removed to access. If you are confident in doing this and can find & check the fuse then it would be my first guess. If fuse is OK then you will need to have repaired. If fuse isblown & you replace then it blows again,you will need to have repaired. regards
Jul 25, 2007 | GE JVM2070 Microwave Oven
Microwave Ovens Logo
193 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
