Question about Sony Ericsson w580i Cellular Phone
I dropped my phone and now the screen wont work it stays black.
I dropped my phone screen face on and the battery fell out, so then i put the battery back in and turned it on. The phone works but the screen stays back can you help me plz?
Screen blank on x836 turns on screen blacksout help thanks
Black Screen, Working Phone [Solved] - Phones - Cell Phone General ...
www.tomsguide.com/forum/id.../black-screen-working-phone.html
Dec 14, 2015 - 12 posts - ‎10 authors
I turn my phone off and then turn it back on, same result, black screen. I then tookout the battery and put it back in, same result. I took the battery ...
Why is my screen black but everything else works ... - iFixit
https://www.ifixit.com/.../Why+is+my+screen+black+but+everythin...
iFixitThe Samsung Galaxy S3 is a multi-touch, slate-format smartphone with ... I have a problem with my phone i dropped it and it works but all i see is a black screen ! ... was fine but then a couple of mins. later the screen started turning pink and when I .... i dropped my gs3, the screen cracked & the screen stays black, everythimg ...
Phone stuck on a black screen during or after a call? Here's ...
www.smartmobilephonesolutions.com/.../cell-phone-shows-a-black-scree...
Is your phone showing a black screen after finishing a conversation and not allowing ... causes and better yet some solutions to fix this issue on your cell phone. ... phone up to your ear, so that the phone will lock (turns on the black screen), ...
Jan 04, 2016 | Cell Phones
How do I fix black screen after phone fell in water?
open up phone put all in big jar of rice or silica gel to remove moisture, if you can remove battery then do so else just leave in jar for a week then try again
Aug 21, 2015 | LG Cell Phones
Screen is black
The strip that connects the screen to the motherboard, probably fall out of the socket. That's why you don't see anything on the screen. It's just my opinion though.
Aug 01, 2014 | ZTE Cell Phones
How do i fix my phone if it has a white screen and i can't see anything
Make sure there is no loose parts: remove the back cover, slightly tighten all small visible screws (use an appropriate size screwdriver, and do not tight too hard). Replace battery, then black cover, charge, and restart. If problem remains, have your phone replaced (make sure you backup any pics, contacts, etc by connecting your phone to a PC with USB).
May 09, 2014 | straighttalk.com
Dropped phone and now doesn't work
Try any of the below combination.
  1. Hold Volume Up + Volume Down + Power.
  2. Hold Volume Up + Home + Power.
  3. Hold Home + Power.
  4. Hold Volume Up + Camera
Dec 12, 2017 | Samsung Cell Phones
I dropped my phone on my apartment floor it was a motorola razor and when i dropped it the back and the battery fell out i picked it up and put the battery and back on the phone again and when i turned it...
Improve the Fixya.com experience for everyone by voting!
In my humble opinion, you have two inexpensive choices:
  1. Sign onto eBay and type in the following: Motorola V3 Razr original LCD display screen + tools and you can fix it yourself for less than $10.00.
  2. The second option is to buy a used phone for about $20.00 delivered, if you're lucky.
All the best,
Ben
Jul 15, 2011 | Motorola Mobility RAZR V3
My Nokia 7390 wont turn on!!!
the drop might lossened the lcd or damaged ur phone and this is a hardware problem i recommend u to take it to ur product care center
Apr 04, 2010 | Nokia 7390 Cellular Phone
Dropped Pantech Matrix in water
it's probably going to be really expensive to repair it if there is major damage. but i got in the pool with my matrix in my pocket and i dried it out and it wont turn on with the battery in it(it's bad i know) but if i take it out and plug it up it works fine but i cannot call, or text. it wont connect to a network. i dont know whether or not i should invest in a battery which isn't that pricey at all or just get a new phone. i'm just not sure if a new battery will fix the problem.
May 04, 2009 | Pantech C470 Matrix Smartphone
Blank Screen
1. Put your iphone in the dock, with the USB cable disconnected from your computer.
2. Make sure the phone is off (The only way I got the phone to turn off is to hold the power button + the home button for like 15 seconds)
3. Once you know the phone is off, press and hold the HOME button then plug in the USB cable to your computer, keep holding the HOME button the whole time.
4. Next it should put a Yellow Triangle on your iphone and it should say "connect to itunes".
5. Now restore your phone, and you should be GOOD TO GO!
Oct 16, 2008 | Apple iPhone Smartphone
Motorola V3 Razor screen and key pads don't work
i have that same problem, razrs suck, i hate em!! my screen is black, i can make and recieve calls...but my screen wont turn on, this is the 3rd time its happened...first time just restarted it...second time i let it sit without the battery in for over night...now it wont turn on no matter what...and the shiy silver circle peice on the left of the phone, the smooth one, it broke and fell off the phone, and i lost it at school...cingular is saying that voids the warrenty...
Oct 16, 2006 | Motorola Mobility RAZR V3
Sony Ericsson w580i Cellular Phone Logo
506 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
