Question about Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera
Wont transfer pics to computer. says communication error
    Brigadier General:
  • 11,967 Answers
Try using a separate card reader to download your pictures.
Posted on Sep 07, 2009
Error message: communication error
I use a USB cable and never see a communication error
Jul 08, 2015 | Canon PowerShot SX520 HS Digital Camera...
Kodak Z740 all of a sudden wont import jpeg images to iphoto. Camera communicates with iphoto and will show photo info, but then an error code says it cant read the format and lists jpeg. I know its a...
An external reader is the best solution. It will transfer the images way faster than using a cable connected to the camera. See if there is a setup option in your camera that chooses the SD card only for storing photos. If there is, then select it.
Apr 15, 2017 | Kodak EasyShare Z740 Digital Camera
Communication error
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use ZoomBrowser or any other photo cataloging program.
Jul 03, 2010 | Canon PowerShot SD600 Digital Camera
I get communication error on the camera screen
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jun 05, 2010 | Canon PowerShot SD1000 Digital Camera
"Communication Error" cannot use the USB setting to transfer pics to computer have to use "picture bridge" plug and play won't work, tried on 3 different computers
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Apr 23, 2009 | Fuji FinePix S5200 / S5600 Digital Camera
My canon powershot s45 works fine , until i plug it into my computer. then it wont even power up . its not my ports or cords i checked them. i dont have the manual & i think that a setting was changed or...
When connected to the PC the cameras display will blank out, this is normal. If the cameras "Communication" setting is set to "Normal" you can only download images when the cameras drivers have been installed of the bundled CD. If you change it to "PTP" (Picture Transfer Protocol), you can connect it to any computer without installing drivers. Set the camera into playback mode, press the menu button and navigate into the menu with the tools(setup). You will find it there. Good Luck!
Apr 15, 2009 | Canon PowerShot S45 Digital Camera
Communications error
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Nikon Transfer or Picasa.
Jan 28, 2009 | Nikon COOLPIX L18 Digital Camera
Cannot transfer images
the pics you are trying to transfer might be too big for the phone,try to reduce their size/dimension. if it doesnt work, use a memory card reader to transfer the pics directly into the memory card of your phone
May 25, 2008 | Nokia N95 Cellular Phone
Cant transfer the pics
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Windows Photo Gallery or Picasa.
Apr 25, 2008 | Fuji FinePix A360 Digital Camera
Error in connecting the digital camera
i had this problem for couple of days, until i started googling this problem. I started to reread this instruction manual. If you have a communication error on the camera screen. Make sure the the USB port you are using, is a working unit. If it is, more than likely the port is not inserted correctly. Keep fiddling around with it until the message goes away. I would also turn the camera on and off to double check and make sure.
Jan 16, 2008 | Fuji Finepix Z20fd Digital Camera
Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera Logo
110 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
