Pal to NTSC
I am trying to record DVDs from a JVC Pal VCR to a MAGNAVOX NTSC DVD recorder. I bought a PAL to NTSC converter, but the vertical adjustment is off and the DVD recorder-records the vertical offset.
I understand that with the new TVs there is a way through the remote to adjust this. Can I do this with the DVD and how.
Or any other suggestions?
Thanks.
  • roberga Dec 10, 2007
    The message I received was not a solution but a quick and dumb response
    I assume to get money for answering. In fact, it made no sense at all.
    If this is the type of assistance you have to offer, please refund my
    $9.99.
    Thanks,
  • roberga Dec 11, 2007
    Well again this does not answer my question about the vertical adjustment. The video converted fine, the vertical adjustment is just off a little bit. Is there a way to fix this using the remote like a TV or other method - Without buy more stuff.
    Buying more stuff is not a solution to the problem.
    If this can not be done using the stuff I have. This service cannot help and therefore please return my $9.99.
    Problem Solver:
  • 10 Answers
If you bought a converter it would convert 25 frames a second to 29.97 or 30 frame 625 to 525 NTSC no adjustments and thats been that way for decades. You can rent a sony or Aiwa deck with legal converter on board and do this easy. So go and get a real converter!
Posted on Dec 10, 2007
Can i convert at PAL video with this machine?
The version of the ZV427MG9 sold in the U.S. only supports NTSC video files. Thus it won't play a PAL VHS tape.
If you find a similar version sold in Europe, that would probably play PAL videos. However, if you used the tape to DVD dubbing feature, the DVD would still have the PAL format. I'm not even sure that a video capture device with video conversion software on a computer would do what you want to do.
I wish that I had better news for you.
(The video would also matter. If you are trying to convert a commercial video (ex: a movie) to DVD, the dubbing feature doesn't work due to copy protection.)
Feb 14, 2015 | Magnavox ZV427MG9 DVD Recorder/ VCR
Vertical addjustment for a DVD recorder
It should be inbuilt to switch on the vetical adjusment! or else you have to find another! 1
Dec 08, 2007 | Samsung DVDR120 DVD Recorder
JVC DR-MX1S
It's likely to be an incompatible signal. You have PAL (UK) and NTSC (Belgium), the DVDR/VCR combo may not be compatible with PAL causing it to seem like it's not receiving any signal, when in fact it is - but not in a recognisable format. You may try and get an NTSC to PAL signal converter like this: http://cgi.ebay.co.uk/NEW-TV-AV-Video-System-NTSC-To-PAL-Converter-Converor_W0QQitemZ270163920912QQihZ017QQcategoryZ32837QQtcZphotoQQssPageNameZWDVWQQrdZ1QQcmdZViewItem That'll solve your problem.
Sep 09, 2007 | JVC DR-MX1S DVD Recorder/VCR
I have converted some NTSC vhs to PAL dvd, when i play them on my LG DVD player, it says disc error
U must copy NTSC to NTSC.PAL to PAL.Check ur DVD recorder/VCR combo menu set up regions auto, if it have it.Will play all regions DVD discs.
Mar 26, 2010 | LG RC897T DVD Recorder/VCR Combo
Does these dvd players read a dvd in the pal format
As per the information available, this DVD Recorder supports only NTSC format DVDs.
Sep 04, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
The display screen is rolling and is in black and white.
Hi
You switched to PAL mode from NTSC or vice versa. Most DVDs will only output PAL or NTSC, not both. So even if the disc is region ffree, the fact that it's encoded in PAL (50hz) makes it appear like you describe - no vertical hold / black and white.
Some set top players [Apex, Phillips] will convert PAL to NTSC on the fly or vice versa.
Remember, PAL/NTSC is not the same as Region.
Here's some detailed info:
http://www.michaeldvd.com.au/Articles/PALvsNTSC/PALvsNTSC.asp
http://www.sjbproductions.com/web_pages/tip_video/ntsc_pal.htm
http://www.dvdcity.com/codefree/codefree-ntsc-info.html
You can convert the DVD to NTSC, and strip the region code by following http://www.videohelp.com/guides/how-to-convert-interlaced-pal-dvd-to-ntsc-dvd-id1107#1107
-or-
http://forum.videohelp.com/topic221928.html
[This is very time consuming.]
You
What DVD
Most players are either NTSC or PAL, however increasingly DVD players from the Far East (Apex, Phillips etc)
, which is 50hz instead of 60hz, hence the lack of vertical hold
Mar 23, 2009 | Televison & Video
Converting NTSC home Video tapes to Pal DVD or NTSC DVD
You need either an NTSC DVD recorder (keep in mind that the US has 110 voltage, while Australia does not), or a computer card that supports NTSC. Some video capture cards support both NTSC and PAL (often switchable). Choose good quality, and pay attention to video/sound sync - some bad quality cards loose sync. Once the tapes are transferred to DVD - and keep it native NTSC all the way, they can be played on virtually any PAL DVD player/TV combo. With an NTSC source, it's best NOT to convert to PAL, while with a PAL source in the US, you'd need to convert to NTSC or only show the DVD on a computer (where NTSC/PAL doesn't matter).
Feb 19, 2009 | Panasonic DMR-ES35VS
I can only record and play back in black and white.
siri,
for the black and white screen output of your DVD and VCR.
1) for DVD player: using remote control locate "setup" button and click.a dialogue box should appear indicating " audio setup" video setup" etc.....
2) select and scroll to "video setup". in video setup there should be an option to choose "AUTO" "PAL" or "NTSC"
3) choose "auto" then check if any change in screen color.
for VCR, locate a switch or button indicating "PAL" "Auto""PAL SECAM" "NTSC". same with the dvd choose and select "auto"
note: if you still have the manual for both VCR and DVD check the instruction with regards to video color setting.
cheers,
mark
Jan 15, 2009 | Philips Magnavox DVD/VCR Dual Player
PAL to NTSC conversion
This is not a converting unit, it will play the format of the tape inside. To convert the signal you need one of the following:
1) A converting VHS player; they are fairly expensive.
2) A separate video converter (hardware); they run for about $200-$500; just put this between your VCR and the TV.
3) Capture the PAL on your computer using a software like Movie Maker via a Firewire cable. Than convert it to NTSC on your machine using software like Nero... do a search on Google for converting software. Or just watch it on our computer in PAL format, most computers do that... For this step I use a separate camcoder that has a passthrough feature. The VCR connects to it and the camcorder connects to the computer via Firewire.
4) send the PAL tape to a specialized shop for conversion. They normally charge $30-$40 for a regular 2h VHS tape.
Jan 20, 2008 | Philips DVDR3435V/37 DVD Recorder/VCR
NTSC to PAL
You have to buy first a VHS player that can play NTSC, might not be available locally in Ireland so you have to probably buy online (US). The DVD recorder is fairly comnon nowadays and all of them are capable of recording and playing NTSC and PAL. You can then connect the AV out of VHS player to the AV In of the recorder. Or you can use a VHS-DVD combi. You can google in UK, here is an example: Toshiba RD-XV45, according to the specs, it can play NTSC on the VHS and you can record to DVD on any format that yoou want You can go to this link to view other product: http://audiovisual.kelkoo.co.uk/b/a/sbs/100304323/16875665.html My father died of cancer 6 years ago and I am also transferring the Hi-8 videos to digital format using PC.
May 23, 2007 | Samsung SV5000W VHS VCR
Televison & Video Logo
140 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
