Pull the refrig out from the wall , and remove the rear panel . Touch the compressor and feel if its hot or running . If the compressor is cool , then the main control board is bad ( since the compressor isn't running ) . If you can solder , you can repair the board (another paragraph ) . If the compressor is warm , then you could have a thermistor or 2 bad . This would have to be checked by a technician , unless you know how to get into the diagnostics procedure . Also , see if the compressor cooling fan is working and the black squirl cage is clean of dust .
Testimonial: "Quick, professional response."
It was a little dusty, clean now, fan is running. Compressor is warm and appears to be running. Thanks for the advice.
How do I remove the inside rear panel on a GE profile Freezer to replace the fan. I broke the switch on the door about 6 months ago and the fan constantly since then. (until this weekend)
