Question about Fuji FinePix S7000 Digital Camera
It's impossible to ON my camera "FinePixS7000". The lenz not go out from camera body and flash could not been UP. I have changed the battery twice, but unfortunately. What can I do? I am living in Great Chicago (ZIP 60089). Are there your repair centers around? Roman Mazur
    Guru:
  • 1,326 Answers
Has the camera been dropped or exposed to water? Also how long have you had the camera? There is no reset button on the camera. To be honest, these cameras are not servicable, when they stop functioning they have to be replaced. Usually when one or more funtions stop working or the camera fails to turn on it is 95% of the time bad and in need of replacement.
Posted on Sep 06, 2009
MY CAMERA IS DISPLAYING E:61:00 WHAT IS THE MEANING
E:61 means
Difficult to adjust focus
(Cannot initialize focus) please check
lens block assy is your camera initialize the focus means at the time of starting your camera lenze is move forward & revirce if no then chang lenze block assy
Jun 17, 2013 | Sony Cyber-shot DSC-T100 Digital Camera
Lenz are still
You should take it to the photo shop to ask for repair service, I guess it works! Impact from shock(fall) can misplace the components in the camera and it can't resolve by only turning on and off the camera.
Apr 24, 2013 | Fuji Film FinePix JX500 14 Megapixel...
Blurry pictures, flash timing is off
do you use a lenz cleaner on the lenz of the camera
Dec 07, 2011 | Canon PowerShot A520 Digital Camera
Good camera but the lenz as stuck out
Check the batteries are in good order. Sometimes weak batteries will not have enough power to close the lens. Unfortunately it's definitely the most common fault on all cameras where the lens moves in and out. The fault is either caused by a sharp knock on the lens whilst extended or grit or sand lodged between the lens elements or the lens and the camera body where the lens slides in. This is usually a job for a repair tech and can prove expensive because the majority of the camera has to be removed to reach the lens. At some places on the net there are tips on how to fix it and usually consists of bashing the lens onto a table top or something similar. Please avoid this as it's more likely to cause further damage and render the camera non-repairable.
Apr 10, 2010 | Fuji FinePix F420 Digital Camera
" " lens pops in & out twice & the screen says access then screen says turn power off and on again. Sony Cybershot dsc w55
this problum is related with optic zoom lenz assy its not work propally so thats why screen shows access problum pleae go to your nearst sony service centre & fix the problum or repair optic zoom assy
Feb 05, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
My sony camera gives this message and lenz will not close.
    This message appears when the lens assembly start malffunctioning. Therefore, You have to replace the Lens Block Assy. For this plz contact any nearest Sony Service Centre nearby to u.
Thanks for using fixya!
Take care.
Mar 11, 2009 | Sony Cyber-Shot DSC-S90 Digital Camera
How do I clean the interior of the lenz for Powershot A640
Its a big job, If your petty handy, You have to start from the back of the camera, Remove rear cover,Then front cover, Next lcd Display unit, Hopefully your haven\'t put the battery\'s in the camera for a while because the flash has high voltage in it, if you have, You must discharge first, them take circuit board out,Then lens assy, Now the fun part, You have to take the lens apart from the back also, Like I said its a big job, Better when you get this far into the camera you just replace the lens, with a used one form a diff camera (same model )
Feb 25, 2009 | Canon PowerShot A640 Digital Camera
Samsung S760 Digital Camera - Not turning on and lenz stuck out.
Yes you are correct lens is struck
* Carefully inspect around it for dirt or debris
* If you see any dirt or debris around the lens, use canned air to gently blow it away
* After removing dirt and debris, turn the camera on and off
This should work
Hope this helps .
If your problem still continues you need to take to service center .
Thanks for using FIxya
SAM ANDERSON
Jan 30, 2009 | Samsung S760 Digital Camera
Camera wont turn on
goto http://www.digitalcamrepair.com/self_diagnosis_page.htm
for self diagnosis.please let me help you before leaving a bad feed back.
Apr 30, 2008 | Kodak EasyShare C533 Digital Camera
SAMSUNG DIGIMAX A 7
Sounds like a power issue. Make sure you use the recommended batteries. Also, some cameras have settings to where you need to change it in accordance to the type of batteries you are using. exp. alkaline, ni'mh, etc.
Dec 31, 2007 | Samsung Digimax S700 Digital Camera
Fuji FinePix S7000 Digital Camera Logo
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
