Question about Hotpoint VVSR1070D Top Load Washer
Agitator stopped working
While washing agitator stopped working properly,motor kept running,dont know how long,it stopped and now it only buzzes when turned on,i checked the belt and it is loose,belt shavings along side,and thats what i see
  • tubird Dec 08, 2007
    washer agitates but does not do spin cycle
    Sergeant:
    Champion:
  • 262 Answers
Depending the age of the unit the lid switch can be bad if not that old take front panel off and the newer machines have a motor wit a control board on them with a light on it to give you error codes if it flashes one flash every few seconds the motor is fine but if the light flashes twice over and over again replace motor there is a tech sheet behind timer panel to tell ya the codes.as far as shavings the belt would be something to look in to
Posted on Dec 08, 2007
What needs to be replaced? I installed a new motor but my washer still won agitate or spin.
check / replace the start run capacitor for the motor
have a electrician do it or a service technician if you do not recognize it
it is normally up near the control panel
Oct 19, 2015 | Haier HLP21N Washer
Fills up but doesn't start turning but starts buzzing a solid buzz
1 Unplug the washing machine, and turn off the water supply to the machine. If necessary, remove the water hoses from the back of the washing machine because they may be in the way of the access panel. 2 Check that the agitator is seated correctly by opening the lid of the washing machine. If it's loose, pop off the top of the agitator--if there is one--and tighten the bolt that holds the agitator in place. Or, in some models, simply pull straight up and then reseat the agitator. 3 Remove the access panel located in the back of the washing machine by unscrewing the screws holding it in place. This allows access to the drive motor. 4 Press on the drive belt that works the agitator. If the belt moves more than 3/4 inch, tighten the belt to fix the spinner problem. If the belt is worn or cracked, replace the belt. 5 Replace the drive motor, if tightening or replacing the drive belt doesn't fix the agitator. Purchase a new drive motor at a wholesale retailer. Disconnect wiring, remove screws holding motor in place and insert new motor. Screw into place, and connect wiring. 6 Check for any black substance leaking under the washing machine. This might indicate a clutch problem, if the washing machine spinner is not working. Contact a professional repairman to replace the clutch
Feb 15, 2011 | Speed Queen ATSA5AWN Front Load Washer
Top load washer not agitating. buzzing noise from motor
1st check pump is pumping out water/ next could be motor not running due to fault, not sure if brushes are in this motor if so check for wear, quite old so could be the motor gone...
Oct 31, 2009 | Washing Machines
Buzzing from washing machine and it wont start the
first of all this sound is from the motor bearings they are getting brushed up with the body of the motor internally and motor needs replacement the internal coil of motor is got weak so it over heats.this is seen in many cases.you can get required parts from www.repairclinic.com It doesn't agitate If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
Sep 12, 2009 | GE WWSR3090TWW
Maytag Atlantis 6451 noise when on and agitator doesn't work.
it does sound like a bad motor.
they are rather expensive on that machine,
you would be looking at 300 or so
May 28, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Washer Fill and then there is a buzzing sound
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Apr 01, 2009 | Whirlpool Washing Machines
Humming noise during spin cycle
Strangely enough, the electronics in the motor drive circuits are quite hardy. Suggest if motor does agitate but not spin, check the motor brushes and see what length and condition they are in.Have had to replace brushes on many occasion.If you have a motor that has a capacitor then check the cap. It could be defective.
Feb 08, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer stopped working
To help you with this problem I need you to do something. Place the machine in spin cycle and see if it will pump the water out. Also, lift the lid and look at the back. There should be a model/serial number plate. This information would help.
I do not believe the motor is at fault. I suspect a bad motor coupler. If the machine willpump the water out then I am Sure.
Dec 16, 2007 | Kenmore 24032\24036 Top Load Washer
Hotpoint VVSR1070D Top Load Washer Logo
145 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
