Question about Maytag Dryers
The dryer just stopped working. No light inside
The dryer just stopped working. No light inside either. I changed outlets but it still does not work. The dryer is a Maytag Ensignia 200 series .
Any idea where I can find a maunal also?
  • 37 Answers
Hope this dosent seem to simple ,but have you tried changing the fuse in plug?
Posted on Sep 06, 2009
Miele Dryer Problem
HI,
If your dryer doesn't work at all, it could be because of problems with:
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Aug 06, 2008 | Dryers
I have a Kenmore Elite electric dryer that we purchased in 2002. It suddenly stopped working - no light inside dryer, drum doesn't turn it is like all of a sudden there is no power to the appliance. My...
Sounds like you need to replace your electrical breaker in the main control box of the house that feeds the dryer. You should get 120volt on each leg coming into the dryer. Good Luck, I hope this helps Please rate me, Thanks
Dec 26, 2009 | Kenmore 63942 Dryer
Our dryer stopped working mid cycle. light
with no light it tells me you have lost L1 check your outlet, and your wire connections
Sep 30, 2009 | Maytag HYE3658AY Electric Dryer
Dryer won't come on. it is plugged in and the outlet and breaker checked out ok.
are you getting voltage when you say you checked outlet? is it a gas or electric dryer? should have 220 or so at dryer for electric and 120 for gas. if voltage ok, trace it through to fuse most likely. no light in dryer means no voltage...
May 24, 2009 | Dryers
2001 Jeep Cherokee - Power outlet, no power
Have you checked the fuse for them? The location should be in your owner's manual.
Mar 06, 2009 | 2001 Jeep Cherokee
WHIRLPOOL DRYER WILL NOT START
You have a bad terminal in the wall outlet.
It is not the dryer.
Feb 24, 2009 | Whirlpool LER5636P Electric Dryer
Does not work at all
The maytag dryer has a main power board that controls every thing from the light to the heat time. You can change this board but probably it is best a get a new dryer. The board is very expensive because it is the brains of the machine. A technician will tell you to change the board but with the parts and labor it will be costly and who knows if something else will happen. You cannot tell unless this board is changed if there is.any thing else wrong because you need it before the unit will even turn on. I hope this helps you.
Nov 23, 2008 | Maytag PYE4557A Dryer
Dryer stopped working
Yes it maybe a fuse problem .But first you want to make sure the door switch is working.
May 21, 2008 | Dryers
Dryers Logo
155 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
