Question about Pro Line Cooktops
Just bought new electric hob to replace old one need to no how to wire it up
  • steven_wolff May 11, 2010
    Is it a plug in type or directly into the cooker socket?
  • 32 Answers
WHEN YOU OPEN THE TERMINAL YOU NORMALLY FIND A CIRCUIT DIAGRAM IN THERE. YOU WILL HAVE AN EARTH, NEUTRAL AND LIVE TERMINAL. IT IS NORMALLY MARKED ON THE TERMINALS. GOOD LUCK. MAKE SURE THAT YOU SWITCH OFF THE POWER TO YOUR STOVE POINT TO MAKE SURE YOU DONT SHOCK OR GET AN ELECTRICIAN TO DO IT FOR YOU. THATS THE SAFER OPTION.
Posted on Sep 07, 2009
Suitable replacement for a Neff T184 induction hob
then you need to go shopping at an appliance store
Sep 29, 2016 | Neff Cooktops
Hob problems
Take a closer look at the wiring diagram on the base or in the book.Check you have put in the relevant links.If not wired properly you may only get half the hob working.
Hope this helps.
May 19, 2010 | Smeg 28 in. P752 Electric Cooktop
SMEG SE435X-1 60CM Electric hob. Keeps tripping fuse
It's possible that one of the burners stay on for a long time, which cause one of the wires to overheat, breaking the connection and touching the body of the unit, please turn the breaker off and check for a loose connection, replace the wiring if you feel confortable doing it yourself or contact a technician.
Jan 06, 2010 | Smeg 23 in. SA435X Electric Cooktop
Induction hob switching off
check that the hob is wired correctly underneath 1,2,3 should be linked together as live 4,5 as neutral and earth takes its place as earth,
if it is wired correctly then i m afraid the hob needs a new induction element it is all one complete unit on these hobs not seperate so your looking at £1000 + to fix it plus engineer call out charges
Dec 06, 2008 | Kuppersbusch K 23 in.EKE604.2 Electric...
Wiring for Neff Hob-not supplied/no wiring instructions
The details of how to wire the T1213 hob are printed on the base of the hob next to the terminal compartment. For a single cable installation, Neutral is connected to terminals 4 & 5 which should already be linked with a copper link. Terminals 1,2 & 3 should be linked together using the links supplied (hidden in the side of the terminal compartment) and Live is connected to any one of 1,2 or 3. The Earth goes to the terminal beside the cable clamp.
Nov 28, 2008 | Neff T1323 Electric Cooktop
Hob turns off
hi im gerbee my suggestion is replace the pcv control wat brand u have,always also in philipines the electric hob is so very sensitive,the pcv cotrol is not repairable.or next time u by a new one gas cooktop more ok compare to electric ceramic hob, or use electric ceramic hob w/knob control compare to sensor type,i think the part of the sensor or pcv control is so very expensive,that why i buy an another one.dont try to repair more difficult to com.tnx
Nov 24, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
Converting gas hob to electric hob
If you are in the USA most codes require a seperate circuit for the oven and the cooktop. Most cooktops require 30 amps and at least #10 wire.
Jun 09, 2008 | Cooktops
Only 2 hobs work
this is almost certainly a wiring issue at the mains connection block, there are links which have not been tightened down. there is usually a diagram adjacent to mains block telling you what to do. connection block is covered by a plate. take plate off and tighten all terminals making sure links have been inserted. switch of at mains of course
Jun 06, 2007 | Zanussi 23 in. ZKT641H Electric Cooktop
Cooktops Logo
241 people viewed this question
Top Pro Line Cooktops Experts
Paul Carew
Are you a Pro Line Cooktop Expert? Answer questions, earn points and help others
