Question about Compaq FS 7550 (Carbon, Silver) 17 in.CRT Conventional Monitor
I HELD A KEY DOWN TOO LONG A MESSAGE SAID TO DO SOMETHING I MISUNDERSTOOD AND PRESSED OK NOW I HAVE TO HOLD EACH KEY DOWN A LONG TIME TO TYPE
  • Andrej.cet May 11, 2010
    please give more details as I would like to know if you do mean the monitor's keys or the keyboard of the computer... plus it would be helpful to know which version if windows u are using!
  • 37 Answers
I think you have held down the num lock keys for over 5 seconds and have activated the toggle keys, try control panel..ease of access centre ..make the keyboard easier to use..you will be able to do your keyboard settings from there
Posted on Sep 06, 2009
How do I fix Canon error message 2700?
Dear
Resetting the waste ink absorber on a Canon printer can resolve some error codes that appear when turning it on.
  1. Make sure the printer is turned off.
  2. Press and hold the Resume button (triangle inside a circle).
  3. Whilst it is held down, hold down the Power button. The green led light should come on.
  4. Keep the Power button held down. Release the Resume button and then press it twice. The light should go amber, then green again.
  5. Release the Power button.
  6. Press the Resume button four times and then press the Power button straight after to confirm the selected action (Reset Counter Absorber).
  7. Turn off the printer and then turn it on again
Thanks.
Feb 15, 2015 | Canon PIXMA Office Equipment & Supplies
When im on browser everthing large and i pressed something on accident on setting while i was on internet and it wont go back to norman please help
If you mean you pressed something and everything you see now is LARGER... I've done that often. Easy fix.... hold down the "CONTROL" or "CTRL" as is is on my computer.... and while holding it down... hit the - (minus key one time). If still to big hit the key again while still holding down the ctrl key. The same can be accomplished to make things larger.... by doing the same thing.... (holding down the control key (ctrl) and hitting the + key one time. (or two times to make it smaller. Hope this fixes the problem.
Jan 27, 2015 | Computers & Internet
I was messing around with my calculator. I pressed 9 and then pressed enter repeatedly until my there was a big column of 9s. Then I pressed second up and held it and pressed 6. The screen became totally...
Turn the calculator on. Press an release the 2ND key, then press and hold the down-arrow key until the screen lightens. If you go too far, press and release the 2ND key then press and hold the up-arrow like you did before.
Oct 20, 2010 | Texas Instruments TI-84 Plus Silver...
How do i repair: hp Photosmart C7280 Printer ink system failure error: Oxc18a0101
Try holding down the ok -- cancel -- black -- color buttons with 4 fingers while at the same time powering the unit off. Keep them held down till it is off. Then turn it back on normally & it should try to do "Maintenance" & you hear a whirling noise --- that is the ink pump spinning to try & pump in ink to the print head.
Here are the details. Got the Ink System Failure message. The error code shows was '0xc18a0005'. The tech had me press and hold the '*' key on the key pad, then press the '#' key and release them both. Then he had me enter '123' to enter maintenance mode. He then had me press the right arrow (beside the OK button) until System Config. menu appeared on panel. Then pressed OK two times to clear the error condition, then cancel two or three times to return to the top menu. Then powered off and back on, printed a test page just fine, copied a document fine.
Jul 18, 2010 | HP Photosmart C7280 Printer
I pressed 2nd key and up and then held up and hit clear and eventually the screen went dark how do i fix it?
Press and release the 2nd key. Press and hold the down-arrow key. If you go too far this time, press and release the 2nd key, then press and hold the up-arrow key.
Apr 08, 2010 | Texas Instruments TI-84 Plus Silver...
Has new battery and wont turn on
Hello, You can try to perform the self-test. Procedure is as follows. To perform the self test on units with two batteries:
  1. Turn the calculator off.
  2. Press and hold the c01788482.jpg and c01774569.jpg keys; keep both keys held down for the next step.
  3. Press the c01788481.jpg key so the c01788483.jpg and c01788481.jpg keys are held down simultaneously.
  4. Release the c01788481.jpg key.
  5. Release the c01788482.jpg key, followed by the c01774569.jpg key. The main test screen displays the following: '1.L 2.C 3.H'.
    • Press c01788484.jpg to perform the LCD test (all LCD segments will be turned on). Press any key to exit.
    • Press c01788485.jpg to perform the checksum test and see the copyright messages. Press any key to go from one screen to the next until the main test screen, '1.L 2.C 3.H', is displayed again.
    • Press c01788486.jpg to perform the keyboard test. Press EVERY key on the keyboard until all the keys have been pressed at least once. The screen will progressively turn off with each key press. Once all the keys have been pressed and the screen is clear, press any key to return to the test screen.
Press c01788481.jpg to exit the test system. This will also turn the calculator off. If the calculator detects an error at any point, it will display an error message. For the HP 12c financial calculators with one battery, to perform the LCD self test:
  2. Press and hold the c01788480.jpg key, and simultaneously press and hold the c01788481.jpg key.
  3. Release c01788481.jpg then c01788480.jpg .
  4. After a few moments, all elements of the screen should be displayed. Press any key to exit.
Nov 02, 2009 | HP 12c Calculator
Continual pop-ups saying OSD Main Control locked followed by language choice, etc. I have tried the buttons on the monitor with no effect
I held down the OK button for several seconds and the message vanished. On releasing the OK button, the problem reappeared. I intend to put a rubber glue (one that can be removed) which hardens on application, to hold down the OK button in the pressed position. Hope this solves the problem.
Oct 12, 2009 | Philips 170S5FS 17" LCD Monitor
Hi I was reading the screen and held down the
There would be an Icon in the system tray where you see your time and date (refer the image)51386ea.jpg
double click on that icon and you will get
uncheck the use filter keys box and the keyboard would start working
Sep 30, 2009 | Acer Aspire 2930-4661 Notebook
Wrong Settings on Ricoh 2018d Nashua
1.Press [user tools/counter] key .
2.Press and hold it pressed [#] key.
3.While you hold down pressed the [#] key press [OK] than the copier will ask you do you like to return the settings to default or not.
This procedure you will have to repeat to all the features.
example : [system features] or [fax features]
remember while on the display writes [fax features] you should hold it pressed the [#] key and while is pressed he [#] key press the [OK] key ones .
Feb 20, 2009 | Ricoh Office Equipment & Supplies
My numbers aren't working and my num loc is on
i got it!! hold down the 2 shift keys for a few seconds then bamm!!
Sep 08, 2007 | Targus USB Ultra Mini Keypad Keyboard...
Compaq FS 7550 (Carbon, Silver) 17 in.CRT Conventional Monitor Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
