Question about Lexmark P315 InkJet Photo Printer
Hi there. The colours on the prints are very insipid/Blury.Green is a nasty yukky yellow and skintones come out crimson or Blury red.Also theres a stripe down one side of pics.Can anyone help?. Many thanks for reading
HI, when printing in colour the blue appears as partially green
Usually this happens in inkjet, when you have a mix of the colors int he cartridge.
so, inkject usually have 3 colors, Blue, Yellow, Red.
If yellow color finds it's way towards blue, then instead of blue, you will see green.
Solution: change cartridge.
Aug 01, 2011 | Office Equipment & Supplies
Hi, im searching for the stereo wiring chart for my mitsubishi lancer 2002 GLXI. i have searched for it but the colours are completely different to what i have. For example the colours i have are - Blue/...
This is all I could find. Hope it helps.
WIRE COLOR POLARITY LOCATION
Battery RED/BLACK (+) RADIO HARNESS
Accesory BLUE (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination GREEN/WHITE (+) RADIO HARNESS
Power Antenna YELLOW (+) RADIO HARNESS
LF Speaker (+) WHITE/BLUE
LF Speaker (-) BLACK/BLUE
RF Speaker (+) WHITE/RED
RF Speaker (-) BLACK/RED
LR Speaker (+) YELLOW/BLUE
LR Speaker (-) GRAY/BLUE
RR Speaker (+) YELLOW/RED
RR Speaker (-) GRAY/RED
Apr 14, 2011 | 2002 Mitsubishi Lancer
I want to print in white ink on black paper. I have a Canon MX310 printer
Inkjet printer inks are dye-based, and that's the reason.
Perhaps this will help explain things. You know those little boxes of food colouring you can buy in the supermarket - the ones that have four little bottles of colour - red, blue, yellow and green. Within reason you can combine these to turn white icing into most colours. Use nothing and the icing is still white or use everything and the icing will go a black-brown colour. Use a couple of drops of red and blue and you'll get purple.
But if you start with black icing, there's nothing you can add that will make it anything but black.
It's the same with your inkjet printer - because white is obtained by not having any ink print on the white paper. But of course that only works when the paper is white. Naturally you'll get different results on all colours of paper, decreasing as the paper gets darker in colour. Print blue on yellow paper and you should get green printing.
The only way to print in white is to do what commercial printers do - use opaque inks and include a white ink in the process. And as far as I know there's no commercial ink that will do that with an inkjet printer.
I can hear lots of you muttering "Rubbish. Of course you can print light colours on dark paper." Well all I can say is, have fun experimenting, but you won't be able to do it.
About the only way to achieve the sort of result you may be after is to print the job then trim it and paste it in place. For instance, if you want to print onto a black or dark-coloured T-shirt then print onto white transfer material, trim the print to size and iron it in place.
Dec 29, 2010 | Office Equipment & Supplies
ShubhangiWe try to connect CD player with Samsung LCD TV. CD Player is having Three Component Yellow, Red,White. It dont have Blue and green components.What to do ???
Hi, Component input connectors use the colour convention
Green = Y (luminance signal)
Red = Pr or Cr (Red colour difference signal)
Blue = Pb or Cb (Blue colour diffrence signal)
Composite input connectors use the colour convention
Yellow = CVBS (composite video, blanking, sync)
Red = Audio Right
White = Audio Left
for compatibility both units will need to have matching colours. note the component inputs do not have audio and as such will also have a set of red & white connectors for use with the audio signals too ( rule of thumb Component = 5 connectors, composite=3 connectors)
Sep 23, 2010 | Samsung Televison & Video
My DCP-115C printer was missing red colour.
Yellow is one of the colours used to produce a shade of red.
I don't know how but ther must be a way to print a test page to see if the print heads need cleaning I've never used a brother.
Sep 26, 2009 | Brother DCP 115C All-In-One InkJet Printer
I have a used C60. I have replaced both ink cartridges with Epson cartridges. When printing in color, the colors are not accurate. For example, red comes out yellow. Also, there are lines running through...
Hi there. The reason for your problem is that the colour cartridge contains cyan, magenta and yellow ink, plus a black cartridge of course. All the other myriad colours are produced by mixing these four basic colours. So, if you print red, it requires ink from both the magenta and yellow cartridges. Thus if your red produces a yellow print, it means your magenta is not printing. This can be due to a number of reasons, mainly an empty or faulty magenta cartridge or blocked magenta print nozzles.
If you wish me to help you with sorting out the lack of magenta, please post a new comment to this effect.
Mar 04, 2009 | Epson Stylus C60 InkJet Printer
Help
the colour in the cartridge are either empty or got mixed.so you r not getting proper colours. replace the colour cartridges
thanks.
Nov 05, 2008 | Brother DCP 115C All-In-One InkJet Printer
Hitachi 43fdx01b rear proj. hdtv
if you are using Y, Pb,Pr, connection to the tv from a sat or cable box check the red wire on both ends red may be disconected.
Feb 09, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Excessive Yellow ink use
The printer software should have an option for head cleaning & alignment. Make sure to run these maintenance options and see the results. You may need to re-run the tests.
Sometimes generic inks can cause a problem, so after cleaning, try to use an oem cartridge (same company as your printer) and observe the results.
Jan 24, 2008 | Office Equipment & Supplies
Lexmark P315 InkJet Photo Printer Logo
37 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
