Question about Garden
Stihl FS 55 will not start
Just bought a Stihl FS 55 and cannot get it to crank for second use. Pumped bubble 4 times and placed choke on. Has not even attempted to fire up. Yes, switch is in ''on'' position.
  • 389 Answers
After trying to start several times, remove the spark plug and see if it is "wet" If it is you are flooding it. Do not pull the rope more than 3 or 4 times with the choke closed, whether it "pops" or not open the choke half way after the 4th pull and make sure you have the throttle trigger squeezed to give it gas
Posted on Sep 16, 2009
How do I fix my Poulan Pro bvm200fe?
If you do indeed have (good)fuel and spark to cylinder, I suggest you remove muffler and clean the internal screen/mesh and carefully scrape off carbon around exhaust port. Do not let debris fall inside engine when cleaning.
Repairing my STIHL FS 38 Clogged Muffler Fix
How To Troubleshoot Your Weedeater to crank every time
Feb 20, 2016 | Poulan Pro 25cc 2-Cycle Gas Blower...
How to start a Stihyl gas trimmer?
here are the steps to starting most stihl trimmers:
#1 turn the choke on (should be a little black knob or an orange switch on the engine itself)
#2 press the primer bulb 3-4 times (should be a little plastic/rubber bubble again on the engine)
#3 put trimmer on ground or bench (I find ground works best)
#4 pull the pull cord fast and hard away from the engine
#5 once it starts turn the choke back off
Jul 20, 2014 | Stihl Owners Instruction Manual Gas Edger...
Stihl fs 86
I am a Stihl mechanic. We tell all our customers that the proper starting procedure for a Stihl is as follows. Turn on the switch. Set the choke lever to full choke. Prime the primer bulb three times(if it has one) and pull the pull rope NO MORE THAN THREE TIMES with the choke on. If the unit has not tried to start after the third pull, open the choke lever and pull till it starts. Sthil carburetors are notorious for flooding after pulling the rope more than three times on choke.
Thanks;
George
Oct 08, 2013 | Garden
I replaced a coil on a stihl weedeater, fs 55 rc, and am having a problem with flooding. also I need the gap spec for the coil/mag
put a piece of paper between coil and magneto magnets, then tighten down. Just so it is not scraping or hitting when you pull it past the magnets . The flooding is because your possibly leaving the choke on to long . Only pull it a couple times, when choke is on. Then turn to half choke.
Sep 01, 2013 | Stihl Garden
Starting procedure for stihl 012 av
Full choke, stop switch on run. Pull rope handle 3-4 times or more until it "tries to start" (it will not start, but it will try to for a split second) move the choke lever to the half-choke position and without pulling the throttle, poll the rope handle until the engine fires and runs for 4-5 seconds then fully open the choke to the run position, let it warm up for 25-30 seconds (don't forget to let it cool down about 45-60 seconds before you turn it off!) and then proceed to use it.
Aug 07, 2012 | Stihl Garden
Can't start new stihl weedeater fs 45
The Stihl FS45 has a particular way of getting started as do all the stihl products. We sell Stihl equipment in our store and service and repair them also. The normal starting procedure is to:
Be sure the switch is turned to the ON position which is the negitive sign (-). The (O) is the off position.
Press the primer bulb 3 times.
Move the choke lever to on.
Pull the starter cord three times only. If the engine fires, turn the choke to the off position and pull till it starts.
If the engine did not try to start during the first three pulls with the choke on, you must turn the choke off and pull till it starts.
Remember:Pulling more than three times with the choke switch on will flood the carburator on every stihl product thats on the market.
However, if the units still refuses to start, being its new and still under warrenty, return it to the repair shop that services Stihl products and they will repair it according to warrenty. All parts and labor should be honored at no cost to you. Please provide your receipt and serial number located on a silver tag located on the unit or the mechanic will get it off the unit when he works on it. Either way, it will most likely have to have a new carburator put on it. I hope this helps. Please comment back if this was helpful. Thanks; George
Mar 17, 2012 | Weedeater Garden
Stihl KM 55 won't start
1. 1st change the spark plug to NGK BPMR 7A.
2. Set the kill switch to on position (I)
3. lock the throttle interlock on
4. Do not prime the fuel bulb...this may cause flooding.
5. set the choke to full choke.
6. pull the cord gently until the piston resists then pull hard
7. repeat pull a second time
8. open choke all the way
9. pull cord again hard.
engine should start within 2-3 pulls, release throttle and feather the throttle until stable
Apr 04, 2009 | Hand Tools
Garden Logo
3,062 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
