Question about InFocus ScreenPlay 7205 Multimedia Projector
6 black vertica lines pulsating from top to bottom
I have an IN24 with 6 black vertical lines pulsating, what causes this?
  • 2,236 Answers
Possibly a resolution issue (clock and phase). reset the settings to factory default. if that doesn't help, there might be a voltage or colorwheel issue. does the projector chirp? if so, it's the colorwheel. if not, there is a voltage/grounding issue. check to see if the plug has 3 prongs on it. if the round prong is broke off, replace the cord. if not, check the fans. if they all are working, you have a power supply problem that is not regulating the voltage properly. replace the power supply.
Posted on Sep 10, 2009
Why I have a thin line across the screen in my TV model Panasonic TC 21. After replacing the vertical IC the horizontal line across the screen reduced to few inches and not as it was earlier. vertica
First, You should to replace by original part, then you should check the voltages on power supply, and check the voltage for vertical IC based on datasheet, also check the voltages on vertical section including yoke and last you should check the ESR capacitors on vertical section.
Oct 13, 2014 | Panasonic TC-21PM10RQ 21" TV
Black vertical line down Sony TV screen
that isa capacitor at vertical area mostiy 1000 uf to 22000 /35volts
Sep 03, 2014 | Televison & Video
Approximately. 2" wide vertical black line top to
You may need to adjust the resolution of your laptop to fill the full screen of the TV.
Sep 27, 2013 | Televison & Video
I have a hisesense 40" lcd lked tv.i grabbed it fron the top and my finger touched the screen.now its has about 12"black uneven spot and in the spot i have rainbow lcolor lines..plus one blue vertica
It sounds like you cracked the screen. If it is cracked, you cannot fix it. Your only options are to replace the screen (BIG $$$) or buy a new set. If you can email me a pic of the TV I can tell you for sure if the screen is cracked. LCD screen are very thin, about as thick as a dime and it doesn't take much to crack them.
info@back2lifeelectronics.com
Nov 25, 2012 | Televison & Video
Upon turning tv on after it's been off for a while i get two lines going from top to bottom of the screen. theres a line on the left side about 2 inches in from the left thats red and about 3 mm wide and...
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
HOPE THIS HELP...
Jun 19, 2010 | Toshiba REGZA 47HL167 TV
My LG 50'' has Black vertical lines after only 3 weeks
The Vertical Amplifier has failed in some section, or a faulty power supply to that section, it is almost impossible to tell, until one looks at the set. a Symptom, like this can, and does have a number of "Causes". This must be fixed first,and then any damage caused, must be repaired.
Apr 04, 2010 | Televison & Video
2" black horizontal line appears on paper when I fax, print,
Check the wondow where the paper passes to be scanned. You will probably find some debris or white out stuck on the glass. That is usually the cause of vertical lines on sent faxes.
Sep 17, 2009 | Office Equipment & Supplies
Vertical black lines
I want to know the possible cause of tv with 2 black line at the top and bottom of the screen. Is it have the same causes even if the tv model is not the same..thanks
Dec 19, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
Toshiba 46HM95 46 tv
If the line is all that is showing with black on the top and bottom. This indicates a loss of vertical deflection which is caused by the loss of the veritcal sweepignal. Check the output of the vertical section of the TV set. You will need an oscilloscope, and multimeter along with a schematic.
Oct 01, 2007 | Toshiba 46HM95 46" HDTV
InFocus ScreenPlay 7205 Multimedia Projector Logo
117 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
