Question about Tomtom GO 910
The screen shows an error and says "Device not Present.Please verify."
It powers on ok but it acts like the hard drive has no information on it.Any help very much appreciated.
  • mucklechuck Mar 11, 2008
    I turned on my new TomTom GO 910 and have a blank screen. Also, I tried to turn the unit off after this outcome, and now it will not turn off. Also tried the reset button....UGH! Oh yeah customer service (by phone) was a joke. geez!
  • 178 Answers
DO YOU HAVE TOM TOM HOME INSTALLED ON YOUR COMPUTER??
LET ME KNOW
I HAVE A 910 ALSO I CAN HELP YOU
Posted on Feb 20, 2008
Black screen, hard drive not running
If you remove the power adapter, battery, RAM and hard drive. Plug in the power adapter and power it up. If you get a screen with error information on it, the motherboard is probably OK, if nothing there is a motherboard issue. If you get a screen remove the power, insert the RAM and power up again. Do the same after adding the hard drive.
Jan 03, 2014 | Toshiba Computers & Internet
Help! Glyph PortaGig 50 won't show up!!
Control Panel, Computer Management, Disk Management. Check that your Glyph is present. If it is present, does it have a drive letter assigned? If not Right Click and Assign Drive Letter.
If drive not present you should check power and data connections.
Dec 16, 2013 | Glyph PortaGig 50 External USB 20 Hard...
Acer m3400 keeps saying select boot device put in a new hard drive and thried to reinstall from a win 7 system builder disc no joy same error what have I missed?
First, new hard drive must show up in BIOS. Verify. Then try setting CD\DVD (optical drive) as 1st boot option. You should get "Press any key..." on the screen to set up Windows. There is a bigger problem if you can't get to this point.
Sep 24, 2012 | Acer Aspire M3400 PC Desktop
When i turn on my Acer Aspire One D255 it says: "check cable connection! PXE-M0F: Exiting Intel PXE ROM. No bootable device -- insert boot disk and press any key"
The PXE ROM is part of your system's network interface controller. It is being entered on your system's startup to look for a bootable image on a physical network connection and if found, to boot from that image. If there is no network cable connection to your system or if there is but no bootable device is found on that connection, the result is the error message that you got. As to why your system is entering the PXE ROM can be explained by looking at your system's Setup Utility,,,
Press F2 while powering up to enter the Setup Utility and use the cursor control keys to go to the Boot tab which then shows the Boot priority order. The default order is as follows...
1. IDE0
2. IDE1
3. USB FDD
4. USB HDD
5. Network Boot : LEGACY PCI DEVICE
6. USB CDROM
Your system's internal hard disk drive should be listed beside IDE0 and it will be accessed first to look for a boot record. If the drive fails to boot, the next devices in the list will be accessed accordingly until either a bootable device is found or the last item which is USB CDROM. If a USB CDROM is plugged in on one of the system's USB ports, it will be checked for a bootable record and if not found or no CDROM is plugged in, then the system displays the last part of the message -- insert boot disk and press any key.
Press F12 while powering up enters the Boot Menu which has the Boot Option Menu. This menu should show by default the following...
1. IDE 0: (the name/type information for your system's internal hard disk drive
2. Network Boot: LEGACY PCI DEVICE
If there is no hard disk drive information shown beside IDE 0, then the possibilities are that
1. there is no internal hard drive present
2. there is a hard drive but it has failed
If there is hard disk drive information and pressing enter to select it does not result in an operating system startup, then the drive's startup partition has been wiped and so it has no bootable image.
If there seems to be an internal hard drive present but it has no bootable image, you may attempt recovery from the installation images in the hidden partition. The recovery allows restoration of...
1. operating system to factory defaults
2. applications (selectable)
3. drivers (selectable)
Press Alt and F10 keys together while powering up and the Acer logo is showing to enter Acer's eRecovery Management. Follow the instructions to do the recovery.
Feb 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
When I turn on my acer aspire one d250 it says Check cable connection..! PXE-E63: Error while initializing the NIC PXE-M0F: Exiting Intel PXE ROM No bootable device -- insert boot disk and press any...
1. IDE0
2. IDE1
3. USB FDD
4. USB HDD
6. USB CDROM
Press Alt and F10 keys together while powering up and the Acer logo is showing to enter Acer's eRecovery Management. Follow the instructions to do the recovery which will erase all user data and restore the operating system to its factory default when you purchased the netbook.
Jan 03, 2011 | Acer Aspire One D250 (99802378332) Netbook
SATA Drive not present on optiplex gx520
If this is a new drive that you just installed, verify that one end of a SATA data cable (usually red in color) is connected to your hard drive and the other to the first available SATA connector on your motherboard.. Then verify that a SATA power cable is connected to the power receptacle on your hard drive. If the drive was working OK, but now your system cannot see it it may have failed. Try these tests:
Plug in and as you turn on your PC, hold down the delete key to enter BIOS setup. (On some machines it's the F!, F2 or F10 key).
Once in BIOS setup, first scroll through all the menus and make sure that all on-board IDE and SATA devices show that they are set for ENABLED or Auto (If you see DISABLED, change it to ENABLED.)
Then, navigate to and select the first display screen, ususally titled "Standard CMOS Features". Your Hard Drive should be listed under IDE or Sata devices. If it is, follow the on-screen instructions to get to the Boot Menu. If this hard drive is the device that you want to load your operating system from, be sure it is listed as one of the boot choices.
If your hard drive is listed in CMOS settings, but windows does not see the drive in "My Computer" then the drive may not be partitioned. If you don't know how to partition and format hard drives, you will have to seek the help of a PC technician.
If the CMOS Setup screen does not see your hard drive, and you have another KNOWN GOOD SATA drive, you can temporarily install it to isolate the problem to either your drive or your PC. If not, then you need to have both the drive and your PC tested by a PC technician to determine what the problem is.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please return to the FixYa website and rate my response to your question.
Dec 23, 2010 | Dell OptiPlex GX520 PC Desktop
My seagate sata 500gb barracuda 7200.12 ST3500418AS not booting.and showing black screen.I can`t install windows because no drive is showing .please help.
If your hard drive is an IDE type, the data cable that connects it to the motherboard will be a flat (usually gray colored) cable that has three 40 pin female connectors on it. If it is an 18" cable, the 2 connectors that go to IDE devices (hard drive or CD-ROM) will be spaced about 6" apart at one end of the cable and the connector that connects to the motherboard will be at the far end of the cable. Also, the cable will have a red stripe along one side of it. The stripe is an indicator of where pin # 1 is on the cable.
Since the IDE cable connects to two devices, there has to be a way for the motherboard controller to know what is connected to each connector. This is accomplished by small straps called jumpers on the rear of the IDE devices. The jumper choices are Cable Select (CS), Master (MA), and Slave (SL).
If your hard drive is strapped as master you must connect it to the connector at the end of the cable. ( If there is a second device on the cable it must be strapped as slave.)
If your hard drive is strapped as Cable Select it is usually connected to the end of the cable but any device on the 2nd connector must also be strapped as Cable Select.
Verify that the hard drive is strapped properly and then be sure it is connected to the drive with the red stripe side closest to the hard drive 4 pin power connector.
At the motherboard end, be sure the cable is connected with the red stripe side adjacent to pin 1. A "!" is usually marked on the motherboard next to the pin 1 of the IDE socket.
Verify that a 4 pin power connector is plugged into the connector on your hard drive and be sure it is fully inserted. .
If you have a SATA drive, the connections are easier. Verify that one end of a SATA data cable (usually red in color) is connected to your hard drive and the other to the first available SATA connector on your motherboard.. Then verify that a SATA power cable is connected to the power receptacle on your hard drive.
When you are sure your connections are correct, plug in and as you turn on your PC, hold down the delete key to enter BIOS setup. (On some machines it's the F!, F2 or F10 key).
Then, press the Enter key to select the first display screen, ususally titled "Standard CMOS Features". Your Hard Drive should be listed under IDE or Sata devices. If it is, follow the on-screen instructions to get to the Boot Menu. If this hard drive is the device that you want to load your operating system from, be sure it is listed as one of the boot choices.
If the CMOS does not see your hard drive, then you need to have the drive and your PC tested by a PC technician to determine what the problem is.
Best regards,
Yavacotech
Dec 19, 2010 | Seagate ST3500418AS 500GB 7200RPM SATA...
Error Code 0141 - No driv detected
Hi anarosenfeld.
After researching all the information online, I found that the issue might be due to the Hard Drive or the CD/DVD Drive.
Based on the information provided by you on this email, I suggest that you perform the below steps:
1) Shut down the system if it is on, Remove the Optical Drive. See instruction in this link: http://support.dell.com/support/edoc...htm#wp1179838
2) Power up the system, see if the malfunction is still present.
3) If the malfunction is still present please perform this actions:
4) Shut down the system, Remove the HD and put it back See instruction in this link: http://support.dell.com/support/edoc...htm#wp1180014
5) Then, see if the malfunction is still present.
If the issue still persists even after performing the above steps, please perform the further troubleshooting steps which I have mentioned below:
1) Run the Drive Self Test (Hard Drive Diagnostic).
a) The first step to perform when you encounter errors with the hard drive is the drive self test. Depending on the system, this test can be run either from a CD or from the System Setup (BIOS). When you run the diagnostic test, you will be informed whether the diagnostic is able to test your hard drive.
b) Most recent Desktop, Portable, and Workstation systems have the hard drive diagnostic included in the System Setup. You will find detailed instructions on running this test at the following web address:
http://support.dell.com/support/topi...401E0A55174AE6
2) Hard Drive Cannot Boot, is not Detected or Reports Errors.
a) There are many steps that will help solve or least determine the exact cause of the hard drive errors you might encounter. You'll find easy-to-follow steps at the following web address:
http://support.dell.com/support/topi...=us&l=en&s=gen
Please perform all the steps mentioned above.
Hope this helps.
Please feel free to ask further questions.
Aug 18, 2010 | Dell Inspiron 1525 Laptop
After formatting my pc is unable to run
(1)When you power up the computer press F8 key thne if you are able to see safe mode and other menu then enter in safe mode.Then go to start menu->run type in run "chkdsk /r"
thne press "y" then scan your computer with antivirus. uninstall that antivirus because sometimes it conflict to windows.
then restart computer thne wait untill it check disk and fix errors.
Then you can see desktop screen.
(2)But if you are not able to enter in safe mode then you need windows disk or recovery disk.
Then boot computer with that disk.
For that when you power up the computer press F1 or F2 or "del" key to enter in bios .
Then go to boot option and set frist boot device as your cd or dvd drive.
Then save and exit settings.
Then insert disk in rom then it boot with that disk.
then follow the procedure and enter in recovery console .
Type in console prompt "chkdsk /r"
the press "y"
then it fix error on disk.
Then check in normal mode if still not load windows then follow above procedure again but this time select repair previous windows option so it repairs old windows and you get your old windows .
Let me know if you need further assistance.,
Thanks
Nov 06, 2009 | Computers & Internet
Tomtom GO 910 Logo
59 people viewed this question
Top Tomtom Computers & Internet Experts
Tom Chichester
Moazzem Hossain
Moazzem Hossain
jamie alexander
jamie alexander
Level 1 Expert
Are you a Tomtom Computer and Internet Expert? Answer questions, earn points and help others
