Question about Mitsubishi WS-55807 TV
I have a mitsubishi tv and when i turn it on i get no picture and a blue line down the middle. audio is good. i use a digital cable box.
Yes i have taken care of this.
Posted on Sep 10, 2009
WD-65734, cable DVR, audio receiver and digital remote: picture goes black for 1-20 seconds and then returns, but audio is stable. Status led and lamp led are NOT on. Any suggestions? Thanks,
well are you using an hdmi cable, cause if you are there is a known issue with the communciations where it will lose communication if you reremove the hdmi cable then turn the box off slide the cable back into the box then turn the box back on it should restore the pic and audio just fine. if this is your fix then its one of three things a faulty hdmi cable or an out of date hdmi cable meaning the version is no longer support for the video production. or it's the hdmi output on the cable box. or it's a poor seat/faulty hdmi input on the tv. easy fix is try to replace the cable or use componet cables (red/blue/green) if this is not the setup of your tv/cable box then i will need more info.
Aug 20, 2012 | Mitsubishi WD 65837 65 in. HDTV
I need to know where to plug in my connectors for my cable box. I have two red ones and one blue one I can't find the right holes to plug them in. I have a green one and white one fixed so I have a black...
This would be 5 pins, red-white is for audio and rest of 3 pins red-green-blue for video signal, it calls component video.
Find out red-green-blue jacks at back of TV that would be label as Y, Yr, Yb
Plug each pin in same color to get color picture.
Jan 08, 2010 | Proscan 32LA30Q Television
No sound great picture
Are you connected to a Cable box? then make sure cable box is not on MUTE and audio cables are attached.
From MENU check to see that speakers are not disabled on your TV.
Good Luck
N Sabre
Nov 07, 2009 | Mitsubishi WD-57734 57" HDTV
Ghosting problems with a Samsung-LN32B360
I think your cable box is old version together with weak signal caused this problem. I guess you are using coaxial cable hooked up to the TV at TV cable input jack.
At the TV there are some better quality inputs which are real digital transmission (audio and video) HDMI and components (digital video and analog audio).
The most simple and best quality is HDMI provided the box has HDMI output.
Secondly is component inputs. There are 5 cable trends in which 3 of them (red, blue, green) for video and the rest 2 are for audio (red , white). The cable box should have same color accordingly as ouput. Please note that the color must be matched otherwise you will see the screen has one color only.
Playing a DVD player to see picture good or not. If picture is good, TV has no problem at all.
May 25, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
8' Optical Cable from TV to Receiver and Signal is Breaking Up
Before you buy anything try checking the AUDIO Settings in the Menu of Each Device (Mostly TV) and see if they are set to PCM or BITSTREAM. HDMI is mostly set to PCM while Optical is generally Bitstream. The TV may be set to the opposite of what it needs to be. I would try to get PCM to work first cause it is Better, If not then set what you can to Bitstream and it should pass. Also check in TV Menu for SOUND OUT or AUDIO OUT or SPEAKERS. Some TV's have a problem passing Audio through when they are already Outputting them to it's own Speakers! I Hope this Helps out!
Apr 11, 2009 | Yamaha HTR-6130 Receiver
Mitsubishi wd 52525 Problems, but no blinking lights.
Are you using an hdmi cord or av cables?
Apr 10, 2017 | Televison & Video
No picture, blue screen only
Good Day;
It sounds like you have a lack of signal; 1. reset TV by unplugging TV & signal sources from wall for at least 5 minutes then plug back in, 2. Turn all eguipment on such as cable box, dvd & etc, then change the inputs from your TV's remote, if still no pix,only blue.
Good Luck.
May 01, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Black box in middle of screen
If you have a menu button on the front of your tv go into the closed caption portion and turn off the text mode . This will get your picture back . If you don't have a menu button on the front of your tv you will need a remote that can access the menu . Good luck
Feb 29, 2008 | Mitsubishi CS-35405 TV
Poor
Hi there!
Sounds like convergence Amp to me. Refer to a repairer if you are not sure. Good luck,JUS004
Jan 11, 2008 | Mitsubishi VS-55707 TV
Thin vertical line
What you have described is definitely some form of Electrical Interference. Interference can come from a variety of causes. Is the Cable Inputting the Cable Box close to some High Voltage Electrical Lines? Or Are you located near some Electrical Power Station? Or A Police station, where the Radio Transmitter of the Police Station causing the Interference? As I said, there are a variety of reasons. Also, Try to check if the connector is loose at the rear of the Cable Box, or at the rear of the TV. You will have to eliminate every possibility reason. Wish i could help further.
Jan 21, 2007 | Mitsubishi CS-35405 TV
Mitsubishi WS-55807 TV Logo
88 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
