Question about GE Dishwashers
Pluged drain - GE Dishwashers
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Sep 06, 2009
AC unit is leaking
The drain tube is pluged take the hose off at the unit try blowing in it chances are its pluged and the condensation can't drain
Jun 27, 2013 | Heating & Cooling
I have a GE model #EWA4500D1WW washer that will not drain
did it drain before? check the trap. if to much stuff made it through the wash it probably pluged the drain
Feb 04, 2012 | Washing Machines
Water is coming out of the AC vents inside the car
DRAIN HOSE FOR AC NOT OPEN (PLUGED) YOU SHOULD SEE IT UNDER CAR AT R/ FRONT UNDER FLOOD BOARDS FOR PASSIGER OR A LITTLE FORWARD. IT WILL BE CLOSED UNTILL WATER OPENS IT UNLESS PLUGED. FIND IT AND PUSH WIRE CAREFULLY UP IT AND IT SHOULD DRAIN AND BE OK FROM THERE. THE HARD PART IS FINDEING HOSE GOOD LUCK
Jul 23, 2011 | 1996 Oldsmobile Cutlass Ciera
I have water leaking onto the carpet on pass, side front & rear and I assume the drain for air cond is pluged. I don't know where the drain is located or how to unplug it. it is a 2003 cadillac...
i believe you have a leaking heater core, if the water is leaking out from under the dash right under the glove compartment this is almost certainly the problem
Jan 22, 2011 | 2001 Cadillac DeVille
Code F02 is lighting up, but the drain not pluged
I would make sure that your using HE detergent. The FO2 error code can occur from a suds lock caused to too much detergent or not using high efficiency soap. If you are using HE soap then the problem is going to be in your drain pump. Its fairly easy to clean just google a how to on clearing the pump. Theres also some how's in the "tips" section on this webside. Hope this helps _MJ_
Apr 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a quantum toilet that flushes normally but then syphons the water from the bowl Possible problem?
Look for your main plumbing vent that goes out your roof, is it pluged with a nest or something? When your drain system drains, it needs outside air from the vent to keep the system from vaccume lock. Same as vapor lock in the gas line on your vehicle. If the system is'nt getting air it will **** the water from the traps in your drain system like it is doing in your toilet. You may have to have a professional drain cleaner or plumber correct your pluged vent.
Feb 27, 2010 | Mansfield Plumbing Products Mansfield...
Dishwasher is leaving grit and dirt on dishes. I have cleaned filter, but nothing changed.
run a load without dishes and see if it drains properly if not your drain hose is pluged or its not draining properly
Aug 23, 2009 | Dishwashers
Discharging water to fast.
You drain may not be blocked but it could be slow. Get some drain crystals from walmart. Go by package directions.
Feb 05, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
ASKO 1595
yes have you tried what i suggested yet
Mar 29, 2008 | Asko D1776 Stainless Steel Built-in...
Dishwashers Logo
54 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
jdthefixer
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
