Question about GE PDW7380NSS Stainless Steel Dishwasher
I have no wiring diagram for my dishwasher GE model PDW7380N00SS. There is a green wire with a yellow stripe that is loose at one end and visible when the kickplate is removed. Where should this wire be attached?
  • deverett Sep 06, 2009
    The wiring for power does have a solid green line that is attached to it. The unit is still working. Should this just go anywhere on the frame? I do not see an attachment point.
    Guru:
  • 1,326 Answers
Sounds like a aground wire. Normally green or green with white/yellow stripe is ground. Is the dishwasher still functioning properly? If it is I would strongly suggest it being a secondary ground more then likely attaches to the frame of the unit. You may be able to see where it goes by lookin under but probably not without turning it up pside down.
Posted on Sep 06, 2009
  • James Brooks
    James Brooks Sep 06, 2009
    If its a ground it will ground to any metal point on the frame (should be a hole somewhere). Depending on how it broke off it will either have a round connector on the end of the wire (scew goes thourgh it to frame) if it looks like its been cut/torn you should be able tolocate the other half of the wire and splice it back together and wrap with electrical tape.... If it was a power line something would not be working correctly which is why I am convinced its a ground. It just prevents any shock incase of electrical short.
1996 dodge ram 1500 trailer plug wiring diagram
The diagram does not show separate wires for turns, so you don't need an adapter. The left signal/brake wire is green with a red stripe. The right is green with a brown stripe. The running lights are on the black wire with a yellow stripe.
Aug 18, 2017 | Dodge Cars & Trucks
I NEED TO KNOW HOW TO CONNECT WIRES TO NEW ON/OFF SWITCH
get an electrician in to do the job
I will reply as it you have 3 wires , one red , one black and one yellow with a green stripe or green with a yellow stripe
they can be brown , blue with the yellow s/green stripe
for a switch to work it makes /breaks a live power circuit , so assuming the red wire to be the power wire , one end goes in one connection and the other end goes in a connection directly opposite
the black wire is a neutral wire and is not connected or cut
the yellow/ green wire is a ground wire and is connected to a metal part of the cabinet
for brow, /blue combinations --brown is normally the live wire
AS I STATED AT THE BEGINNING--- SAFETY FIRST--- GET AN ACCREDITED ELECTRICIAN IN FOR THE JOB
Nov 20, 2015 | Indesit Dishwashers
What are the fuel injector wire colors for a ford escape 2008 3.0L v6 4wheel drive?
Okay, you know each injector has a power wire, and a ground wire that goes into the pcm? All of the power wires to all six injectors is a green wire with a red stripe.
The ground wire colors are as follows:
inj 1: green wire/blue stripe.
Inj 2: gray wire/yellow stripe
Inj 3: violet wire/gray stripe
Inj 4: yellow wire/orange stripe
Inj 5: brown wire
Inj 6: green wire/white stripe
I should note that the wiring diagram I am looking at shows this diagram as from a 2008 model manufactured during 2nd quarter of the year 2008. If your injector wire colors are different than as listed above, there may have been production changes during the year. But the power wires to all six injectors would still have the same color wire. You could figure it out that way: in other words, looking at the injector harness, same wire color to all six is the power wire, all the odd colors are the ground wire for that injector. Hope this makes sense to you. Good luck.
Feb 03, 2015 | Ford Cars & Trucks
For a maytag dishwasher WU900 need a wiring diagram thanks Norm
Each component should be labelled clearly on your diagram. Look at figure 6-A. The symbols used to represent each component are pretty universal.
Wire colors are abbreviated and shown next to each wire. For example, Y means a yellow wire, V means Violet, R means red, LBU means light blue. Black is usually abbreviated BK, blue is usually BU. GR or GN are green, GY is gray. A wire color with a dash or a slash means --- with a --- stripe. For example BU-W means Blue with a white stripe, T/R means tan with a red stripe.
Figure 6-A: Typical Wiring Diagram
Oct 17, 2010 | Dishwashers
I need the radio wiring diagram for a 1992 cadillac eldorado. the wires i have are: black w/ white stripe, yellow, green w/white stripe, green, brown, 2 brown w/ white stripe,black on one plug the other...
white is front left. greay is front right. green is rear left . purple is rear right. black is ground .yellow is power. red is ignition. or do u need factory wiring? the12volt.com try this website it is very helpfull
Feb 10, 2010 | 1992 Cadillac Eldorado
I need a factory radio wiring diagram for a 2006 chevy 1 ton just a am/fm cd player
1989-1990 And Newer
AS VIEWED FROM MATING END OF CONNECTOR
A B C D E F G H I J
K L M N
Typical GM Factory Typical New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Left Front Spkr (-) Light Gray White w/ Black Stripe
B Left Front Spkr (+) Tan White
C Right Front Spkr (-) Light Green Gray w/ Black Stripe
D Right Front Spkr (+) Dark Green Gray
E Ground Wire Black Black
F Not Used
G Headlight Dimmer Wire Gray Orange (if available)
H Power Antenna Turn On Pink (if available) Blue
I +12 Volt Ignition Wire Yellow Red
J +12 Volt Battery Wire Orange Yellow
K Right Rear Spkr (-) Light Blue Purple w/ Black Stripe
L Right Rear Spkr (+) Dark Blue Purple
M Left Rear Spkr (-) Yellow Green w/ Black Stripe
N Left Rear Spkr (+) Brown Green
Smaller sized
Feb 01, 2010 | 2004 Mazda 3
Speaker wire colors
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
Car Radio Ground Wire = Black
Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
Car Radio Dimmer Wire = Light Blue w/ Red Stripe
Car Radio Illumination Wire = Orange w/ Black Stripe
?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front:
White w/ Green Stripe (+)
Brown (no stripe) (-)
Right Rear:
Purple w/ White Stripe (+)
Light Blue (no stripe) (-)
Left Front:
Light Green (no stripe) (+)
White w/ Orange Stripe (-)
Left Rear:
Light Blue w/ Black Stripe (+)
Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front:
Green w/ Orange Stripe (-)
Right Rear:
Orange w/ Red Stripe (+)
Black w/ White Stripe (-)
Left Front:
Orange w/ Green Stripe (+)
Blue w/ White Stripe (-)
Left Rear:
Red w/ Green Stripe (+)
Red w/ Blue Stripe (-)
Aug 10, 2009 | 1991 Ford Tempo 4 Door
Need a stereo wiring diagram for my van.
Yep!
Here you go...
1995 Mercury Villager Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Green/Purple
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Light Green
Radio Illumination Wire: Green
Radio Dimmer Wire: N/A
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 5′ x 7′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Light Green
Right Front Speaker Wire (-): Dark Green/Orange
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Light Brown/White
Left Rear Speaker Wire (-): Light Brown/Yellow
Right Rear Speaker Wire (+): Light Brown/Green
Right Rear Speaker Wire (-): Brown/Pink
That's what they show for factory
K
May 31, 2009 | 1995 Mercury Villager
GE PDW7380NSS Stainless Steel Dishwasher Logo
66 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
