Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
How do we install a clutch for our whirlpool ultimate care LSQ8543JQ0
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. For servicing the installing the clutch you’ll need to first remove the gear case and then remove the old clutch assembly to install anoyher one.
The gear case can be removed by first removing the outer cabinet. After removing the cabinet, remove the pump and motor assembly. Now carefully lay down the washer on its back and remove the 3 bolts securing the gear case. Now pull the gear case straight out from the tube support assembly. Now, compress the clutch spring with a pair of pliers and lift the lining from the clutch hub. To remove entire clutch assembly begin by removing the spin tube thrust washer up & off the agitator and then remove the tube support ring. Remove the retainer ring and lift the clutch hub up and off spin pinion.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 06, 2009
Whirlpool Ultimate Care II LSQ8543JQ0, the washer fills will water on all cycles but does not do a wash, drain or spin.
This is usually caused by the lid switch. These are inexpensive and easy to replace. There are videos at www.appliancehelponline.com/servicemanual.html that will walk you thru testing and replacing this part. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
May 17, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Replacing agitator dog ears
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST.
We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you get your appliance problems resolved soon.
Thank you, Ella
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Mar 09, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care Heavy Duty Super Capacity Plus
clutch could be it check if nothing is jammed between tub andbasket. if u have an oily tranny i would replace it
Feb 12, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer will not high spin
It sounds like a set of clutches would fix it. If not clutches...transmission. :(
Feb 24, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ8543JQ0 WON'T SPIN
really sounds like a coupler issue. May look fine but if one of the teeth are busted it will do this. You can get a tutorial for fixing this here. http://www.shop.washermd.com/category.sc?categoryId=4
Jan 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II washer won't spin clothes more dry than soggy
Tip the washer backward, inspect the bottom of the gearcase for oil. If oil is present, the oil has migrated to the clutch causing it to slip during spin. The gearcase and clutch will have to be replaced if oil is present. Check the owners manual for limited warranty on the gearcase. If oil is not present, the clutch is just worn and should be replaced.
Oct 04, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate care 2 (ABOUT 4 YEARS OLD)
Sounds like the clutch is slipping but sometime catching. Or maybe the transmission is almost gone. Is there a burning smell? If so, probably clutch.
Apr 14, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
