Question about Maytag MFD2561HE Bottom Freezer French Door Refrigerator
No water in the ice maker
The ice maker is not drawing any water for ice but the cold water dispenser is working just fine. HELP
  • 520 Answers
If you follow the water inlet tube into the back of the unit there will be a panel to remove. Take the screws out and slide it out of the way. Continue to follow the tube to the two electric solenoid valves. one valve has a tube that goes to the ice maker. unplug the refrigerator and turn off the water supply. Then remove the water line to the solenoid valve and unplug it. Now you can remove the screws that hold it and it will be free. Replace the valve with a new one and that should get you back in business. New solenoid valves only cost $25 to $40. Hope this helps. Good luck.
Posted on Sep 06, 2009
  • Maytag Master
  • 1,606 Answers
Pour about 2/3 cup of water into icemaker . If it freezes and dumps , and water doesn't go into icemaker , replace the water inlet valve ( the piece on the refrig that the wall waterline connects to . If it doesn't dump the water poured into it after freezing , then replace the icemaker .
My Frigidaire refrigerator works find; Freezer stays cold but doesn't freeze food or ice
Its defrost assembly parts issue or the compressor is getting waek indication.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
ICE MAKER NOT PRODUCING ICE. WATER IS GETTING TO LINE; WATER DISPENSER IS WORKING FINE, MOTOR ON ICE MAKER IS WORKING. THIS PROBLEM STARTED AFTER WATER LINE TO FRIG FROZE DURING COLD SPELL.
Remove the icemaker and check the incoming water line. It may be frozen.
This icemaker manual may be of some help to you.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/9e1ec3936ebd443e852572fa00675934/$FILE/4316835.pdf
Jan 17, 2010 | Refrigerators
Ice maker makes ice, but not nearly as much as it used to. What do you suggest. Water flow out dispenser is fine. Filter has been replaced.
I would suggest making sure the coils under the refrig are clean of dust , lint , pet hair , etc . Also , letting the ice build up so it gets closer to the bottom of the ice maker (coldness of the ice will help keep the ice maker cold ) will result in ice maker cycling more often (making ice) .
Sep 08, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Water dispenser won't work --ice dispenser is fine but no water comes of the water dispenser.
fridge set too cold ? frozen tank or water lines in fridge. set ref warmer for a couple of days
Aug 26, 2009 | Amana AFB2534DE Bottom Freezer French Door...
ICE MAKER NOT WORKING
Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
Nov 20, 2008 | Kenmore 53642 / 53644 Side by Side...
Cold water dispenser on new whirlpool side by side dispenses lukewarm water...ice maker works a charm
there is a tank in the refrigerator section that hlds about 1.5 gal of water as you dispense it refills and pushes out the cold water. if your unit is new it will need a day to cool down the tank of water before you will get cold cold water at the dispenser
Hope this help explain how it works
Aug 01, 2008 | Whirlpool GS6NBEXR Side by Side...
GE monogram side by side no ice water dispensed not cold
To actuate the ice maker pull the arm down and it is in the on position.
The water is actually cooled in the refrigerator section. However it is not designed for a continuous flow. It takes time for the heat to be removed between each water draw.
If your refrigerator temperature is not cold enough it will affect the water temperature also. Check the refrigerator compartment temperature with a thermometer.
May 16, 2008 | GE PSS26MGS Side by Side Refrigerator
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
I just used the hair dryer and it worked the water is flowing again out of the dispenser
Dec 28, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Maytag MFD2561HE Bottom Freezer French Door Refrigerator Logo
309 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
