Question about HP ScanJet 2400 Flatbed Scanner
Lamp error ?
Scanner lamp is error how to slove this problemhp scanjet 2400
Lamp error
Yup!
The lamps have a limited lifetime (or it could have just failed prematurely due to some other reason).
For the cost of parts, it would be cheaper to buy another scanner.
Nov 01, 2013 | HP ScanJet 2400 Flatbed Scanner
My Hp scanjet 2400 not working, always display error massage: scan still runing, or being using by another aplication. wait untill it completed
sir remove you any printer install in computer or something pending print on your printer remove it or canceled printer.
Feb 22, 2010 | HP ScanJet 2400 Flatbed Scanner
HP Scanjet 2400 scanning picture green and backgroud green
go to scanning software in ur computer change color section and remove this problem
regards
john
Nov 03, 2009 | HP ScanJet 2400 Flatbed Scanner
I'm getting a lamp error on my 2400. I followed the unplug and wait solution but that is not fixing the problem. Can I buy and fix the lamp myself or is thing fubar.
The lamp error is usually caused by dirty mirrors in the scanner. You need to take the cover off the unit and clean all of the mirrors with window cleaner. Allow about 5 minutes for the mirrors to dry and reassemble the scanner, power on and test. You should be good to go.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 17, 2009 | HP ScanJet 2400 Flatbed Scanner
Error in Scanning
Sorry to ask u ,how old it is,this kind of problem is found due to following reasons
1)driver software:uninstall n reinstall driver
2)scanner is dusty:clean the scanner from inside
3)inner scanner cable(black cable) defective:replace cable
but before all try this
1)go to my computer,u can see icon of scanjet 2400
2)right clk,clk get pictures.....,new window will open,
3)click preview n wait n see does it shows the preview?
4)if it shows preview then reinstall hp director,or try above mentioned steps,definately the problem will be solved,
thnx
Jan 24, 2008 | HP ScanJet 2400 Flatbed Scanner
HP ScanJet 2400 Flatbed Scanner Logo
244 people viewed this question
Seeker5211
Seeker5211
