Question about Logitech diNovo Edge 9676850403 Keyboard
Broken Retainer Clip (Right Shift Key)
I also have a broken retainer key for the right shift key. Anyone that has the retainer clips or a broken dinovo edge I would be more than happy to buy it from you.
4 Suggested Answers
  • 4 Answers
SOURCE: Lost bluetooth stick for my diNovo Edge
You might beable to buy a replacement key from logitech, and no any stick wont work, it has to be the one designed for use with the dinovo.
Posted on Apr 26, 2009
  • 7 Answers
SOURCE: Replacement key caps
I would buy a plain dinovo for like 20 to 30 dollars and take it from there.
I’m happy to help further over the phone at https://www.6ya.com/expert/alex_8bda69cf9239121b
Posted on Jul 30, 2009
AldRezaine
  • 995 Answers
SOURCE: dinovo edge wireless keyboard base charger NOT SOLD SEPERATELY
You can buy the charger at any computer stores in your place. Just ask for it and if the store you enter does not have that item, they can order that kind of charger from there supplier.
Posted on Nov 05, 2009
Broken shifter cable, how do i repair it
Put park brake on or block wheels, and shift into neutral (if possible), If not go to tranny and pop the cable off the tranny lever (pry off with screwdriver). Turn tranny shift lever, until it clicks twice, leave here for later adjustment. Follow the cable to the adjuster, pull out the flat steel retainer clip, pinch the sides to remove cable from bracket. Remove upper covers below the steering wheel. Remove kick panel below steering colomn. Remove cable from steering wheel shifter assembly (pry off and remove clip same as at tranny). Remove the side kick panel and follow cable along floor. You may find it easier to remove the driver seat (4 nuts on floor and wiring). Pull cable thru floor and replace. Reverse procedure to install. Lock the cable and clip at steering colomn, but leave the clip off at tranny. The tranny should still be in neutral. Now turn key to run and shift the shifter into neutral. At the tranny side cable there is a white square button, press in and lock cable to lever. install retainer clip. move shifter thru ranges and ensure it locks in park. Readjust if needed by pressing button and moving shifter lever on tranny.
Jan 27, 2011 | 1995 Chevrolet Silverado 2500
I broke the Y key for my laptop. I broke the white bracket under the black key. The black part is intact but it is completely detached from the keyboard. Can this be fixed?
No the broken retainer clip can not be repaired, but you can buy a new laptop key retainer clip, take a look at www.replacementlaptopkeys.com, they sell the toshiba laptop keys you need, take care.
Jan 17, 2011 | Toshiba Satellite U405S2918 Replacement...
How to unlock laptop key pads in hp pavillion
Hi, if you want to switch numeric keys on or off, you can do so by pressing Fn + Num (located above Backspace) simultaneously.
If this solved your problem, please leave a positive comment for me.
Jul 18, 2010 | HP Pavilion dv6000z Notebook
My cap lock won't lock, however I can get a
Gently removed the CAP LOCK KEY and inspect for dirt or a broken retaining clip. If dirty blow it out. If the clip is broken the key will not work I'm afraid to tell you
Jul 17, 2010 | Dell Inspiron E1705 Notebook
My 3 y/o knocked keys off the laptop keyboard. How do I reattach? Only the key face cameoff the plastic clip is still in place.
If the clips are still in place then place the key over the clip align the key cap so it is in line with the other keys and press down on the key cap until it clicks onto the clips.
Jun 23, 2010 | Acer Aspire 7720 Notebook
Broken "shift" key.
Well you can try and clip it back on, if able, or use a wee bit of hot glue, or replace whole keyboard.
Apr 02, 2010 | Computers & Internet
How to replace keys
the screws that hold the keyboard is usually under long plastic cover on the top the keyboard..
Feb 14, 2010 | Toshiba Satellite A135-S4527 Notebook
Broken battery retainer clip (red) on Olympus C-7000 Camera
You may want to call Olympus Customer Service and see if you can order this part from their parts department. Their telephone number is 800-622-6372 option 2 and then option 3.
Mar 09, 2009 | Olympus C-7000 Zoom Digital Camera
Loose shift key....any advice on fixing it?
O.k. first the key. Most likely the retainer has come loose. Take the key off and check the if the retainer is broken, if so, then you will need to contact Compaq support for a new one. If it's not broken, take the key off the retainer, put the retainer back on the board, and place the key in it's general position and press. It will snap into place. If you can't figure out how they retainer fits, then take another key off, be careful to just remove the key leaving the retainer. This will give you a view of how the retainer goes on the board.
Now for the sound. You must do this in order to get the sound working with XP:
This model of Presario has an audio controller that supports
the high definition audio. You need to have Microsoft Universal Audio Architecture (UAA) bus driver for high definition audio installed on the computer before installing the audio driver.
Here is the link for the Microsoft Universal Audio Architecture driver that need to be installed before installing the audio driver:
ftp://ftp.hp.com/pub/sof...4000/sp33867.exe ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33867.exe
After installing the UAA driver from the above links you have
to restart the notebook and then install Conexant high definition
audio driver from the following link :
ftp://ftp.hp.com/pub/sof...4500/sp34200.exe ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34200.exe
Installing the audio drivers may result in an error, but continue
with the following steps to get the audio driver installed correctly.
1. Click on Start and select Run. Now type devmgmt.msc and press enter.
2. Right click on "audio device on high definition audio bus" and click update driver.
3. Select "install from a list or specific location"
4. Click next. Then select "don't search, I will choose the driver to install"
5. Click next and then select "sound, video and game controller" from the list.
6. Click next and then click have disk.
7. Click browse C:swsetupsp34200 folder and select the .inf file and click open and continue with the on screen instructions.
Jul 26, 2008 | Compaq Presario 700 470024-192 Notebook
Reattach Acer Aspire laptop Key?
they just clip on.put key back in place and push down firmly.you may have to wiggle it a bit back an forth.
Mar 02, 2008 | Acer Aspire 5500 5570-2609 Laptop
Logitech diNovo Edge 9676850403 Keyboard Logo
218 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
