Question about Dryers
If I set the Dryer for 52 minutes It shuts off within 5 minutes. I bought the dryer used. I have made sure it is level
  • steven_wolff May 11, 2010
    Why do you set it 52mins? does it shut off on any other settings? Has the control knob been removed and replaced wrongly?
  • 1,543 Answers
You do not state a model or even a manufacturer, but I'll take a stab at this.
If you use manual (or timed dry) setting only, dryer should work fine, but all automatic settings are doing what you describe,..... sounds like the moisture sensor bar need to be cleaned off. They are usually two thin metal strips, about 4 to 6 inches long and a inch or so apart. They are generally located inside the drum, very near the lint filter. What has most likely happened, is that fabric softner sheet use has built up a waxy coating on the bars, preventing them from detecting the moisture in the clothes. The dryer sees this as a dry load, and just runs the last few minutes of a cool down cycle and turns off. Cleaning the bars should restore your dryer to work in the automatic drying cycles.
Posted on Sep 06, 2009
All else appears to be working except the dryness level selection button does not light up and will not allow selection
How do I read the digital display panel and controls on my ...
www.samsung.com/uk/support/skp/faq/1025253
Samsung ElectronicsAug 12, 2014 - The Drying light will illuminate and remain lit until the cycle is ... the indicators will light up until you press the Start/Pause button. ... When you turn on your dryer the Cotton Cupboard Dry cycle is selected by default. ... Drying Level button ... If you do not turn the Drum Light off within 5 minutes of turning it on it ...
Dryer Control Panel And Functions - Samsung
www.samsung.com/ca/support/skp/faq/230147
Samsung ElectronicsJan 7, 2015 - To set Dry Level in the Normal, Heavy Duty, or other Sensor Dry ... An indicator light illuminates next to the selection. ... Temp Selection Button ... When using Manual Dry, you can select the drying time by pressing the Time Selection Button. Important: Clothes may not dry completely if the drying time is not ...
MACHINE OPERATION
docs.whirlpool.eu/_doc/501930002795EN.pdf
Material thickness: whenever there is greater load than the dryer can handle, ... Do nottumble dry: nylon stockings, delicate embroidery, fabrics with metallic ... The indicator lamp above the relevant button lights up to confirm your selection. ... Wait at least 5 minutes, to allow the laundry to cool down, before you unload the ...
501930001546EN.pdfDOWNLOAD
Jan 01, 2016 | Dryers
Dryer LG 1100 shuts off after a few minutes. If you set it for 54 minutes, you check if after 5 minutes it reads 14 minthen in 5 minutes it starts cooling down. The clothes are still wet.
Clean your lint filter, and clean the entire line vent from the dryer to the outside export port, also look inside the dryer vent hook up for obstructions and remove any lint. Keeping these parts lint free will save you energy and also drying time and maintenance repairs. My dryer is 18 years old.
Sep 29, 2015 | LG Dryers
Dryer shuts off within a few seconds and smell burning
That's a sign your motor is bad. Soon it won't start at all.
Mar 13, 2014 | Maytag MEDC300XW - 29", 7.0 Cu Ft, He...
After starting dryer will run for a minute or so then shut off
there is a problem with your exhaust check the air duct or take off the exhaust hose it will be packed with lint this will keep the dryer from running correctly !!!
Nov 12, 2013 | Hotpoint NVL333EY Electric Dryer
My whirlpool dryer keeps shutting off
make sure the vent pipe (and the lint trap) is clear and not plugged with lint
Aug 24, 2009 | Dryers
Dryer wont turn on about 5-years old we bought on saturday it ran for about 10 minutes and shut off and will not restart. When you hit the on button you can hear what sounds like electrical current but...
Hi there, the electrical current hum is coming from the motor. there has been a failure within the motor windings and you will have to replace or repair this electrical motor. this will fix your dryer.
Before you purchase the motor, i would recommend checking all wire harnesses for lose connections and corroded contact clips as well. if the wires are connected and the wire harnesses are in good condition, replace the dryer motor.
Please rate and god bless:)
Apr 20, 2009 | Ovens
Drying timer on auto dry
I called LG...they said to unplug the dryer for 5 min. to reset the timer ...this solved the problem.
They also said not to use dryer sheets during the sensor dry cycle as the coating on the dryer sheets causes the sensor to malfunction as it can't read the humidity level in the dryer.
Dec 28, 2008 | LG Dryers
Toshiba 52
MAKE SURE THE BALLATS MAKE NOISE . IF IT DOES YOU HAVE PROBLEM WITH LAMP.......
May 02, 2008 | Toshiba 52HMX84 52" Rear Projection...
Dryers Logo
105 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
