Question about John Deere 6300,6300l,6400,6400l Tractor Radiator
PTO CONTROLS. How do you engage and disengage PTO.
PTO CONTROLS. DOES NOT STAY IN ''DOWN''POSITION.
PTO keeps on turning. 2 Levers on left hand side .Long lever moves down to floorboard but does not stay there. Short lever engage or?
    President:
  • 1,627 Answers
The tractor is not a 6300 is it.If it' not you need to adjust the cable for the p.t.o. until it will stay down.Don't turn the turnbuckle too much at a time because there is a fine line between the won't engage and the won,t disengage adjustment.
Posted on Oct 21, 2009
Craftsman zero turn 26 hp kohler engine new pto electric clutch does not work
Sad to say it may have never been a bad pto clutch but probably safety switch problem. The running tractor wants you in the seat, brake off, levers over your lap and not backing up for the PTO to stay engaged . There is two push button switches on each lever that lay over your lap ,one on the parking brake,one under the seat. All of these switch wires meet at the PTO switch and all have to agree they are in the position they need to be in to allow electricity to come down the wire to the PTO Clutch.
Dec 22, 2016 | Craftsman Garden
New pto switch stoped working after 4 mowings
Maybe the problem wasn't the PTO switch. My Cub Cadet RZT PTO would disengage when I backed up and then failed to re-engage. I was able to isolate my problem to the safety switches at the base of the steering levers. I sprayed them with WD40 and they've been fine. Just a thought and worth checking. I hope this helps.
Jun 15, 2014 | Mustang Rzt 50" Zero Turn Riding Lawn...
Why does my engine shut off after running for awhile with PTO engaged; will restart with PTO disengaged, but shuts off when i attempt to engage PTO?
Does this only happen when the engine is warm or at operating temperature or all the time even when cold? In older engines, a 'bad ignition coil' would fail when the engine warmed up and would not start again until cool or at ambient temperature.
Apr 27, 2014 | Garden
My freedom z will not start
1. Be sure the fuel shutoff valve, located behind the
operator's seat, is completely open.
2. Sit in the operator's seat, fasten seat belt and place
the steering control levers in the neutral position.
3. Engage the parking brake.
4. Place the PTO switch in the disengaged position.
5. If the engine is cold, choke the engine as needed.
6. Move the engine throttle control to about half engine
speed.
7. Turn the ignition key to the START position and
release the key as soon as the engine starts. Do
not hold the key in the START position for more
than 15 seconds at a time. Allow at least 60
seconds between each cranking attempt to prevent
overheating of the starter motor. Prolonged cranking
can damage the starter motor and shorten battery
life.
8. Allow engine to warm before operating the mower.
Apr 05, 2014 | Scag SFZ61-730FS Freedom Z Zero Turn
I have a rzt 54 cub cadet, when i engage the pto it cuts breifly then the mower shuts down PLEASE HELP
A battery going bad may be your culprit. I found out just the other day that your mower can keep running but when the battery gets too weak, the pto clutch disengages and shuts down,
Apr 29, 2012 | Oregon Scientific Electric PTO Clutch for...
Cub Cadet-Blades won't stay engaged
sounds like either a saftey switch problem or a bad drive clutch on the pto. usuallly the mower shuts down,not the blades, they may have changed this though. my best guess would be a safety sensor try calling your local cub dealer and talking to the repair person he can shed light on the problem.
Jul 24, 2009 | Mtd Garden
Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Jun 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
John Deere 6300,6300l,6400,6400l Tractor Radiator Logo
723 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
