Question about Philips 51PW9363 51" Rear Projection HDTV-Ready Television
Blank Ok, I was on here a couple days ago complaining that my tv has no sound picture nothing. I was told to sheck the fuses. I checked them and on the back found 2, and 1 was blown. So then I replaced it 3 times now, and everytime I plug the tv back in it blows the fuse again. I know something else has to be wrong that is causing it, but what. Please help me..... Thanx......nicole
  • Philips Master
  • 8,617 Answers
Sounds like something in the regulator circuits blowing the fuse. I can post alink where you can get a service manual as well as free support to help you figure it out. Your set is coverd in the DPTV305 series phillips magnavox on page 2 of the phillips section for 10.99 and they email them instantly if you want one.
http://servicemanuals.vstore.ca/
Posted on Mar 19, 2008
TV picture goes out after 10 minutes of viewing with popping sound
It can be a couple things. Something bad on the power board. Or the vertical output circuit. How long ago did you purchase the television. Your best course of action is to have it serviced.
If you need any information or other assistance let me know.
Thanks,
Lee
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Audio but no picture mitsubishi wt-46807
Did you try the OPTION menu---think I offered that to you a few days ago......
Mar 27, 2012 | Mitsubishi WT-46807 46" Rear Projection...
I have a Phillips FLATTV model ... Problem with the Philips Flat Panel Televisions I have a Phillips FLATTV model 42PFL7662D/ 05 I have no picture, the audio is OK, I have had a hissing noise for about 2...
Try with that...
http://www.filestube.com/3c4e959f7e53ba6703e9,g/PHILIPS-42PFL7932-LC420WU5-V2-CIRC.html
Symptom:
Sound but no picture.
Cure:
Master or Slave inverter is defective.
It can be that the driver IC is defective or MOSF
inverter transformers, or 470uF 35V C
Replace driver IC BD9897FS or MOSFET's.
996500046243 IC BD9897FS
996500046242 Mosfet FDD8447L
996500046241 Zener KDZ100V
Oct 18, 2010 | Philips Televison & Video
I was given a Mitsubishi vs-50111 I was told all it needed was to be adjusted due to the color being out of alignment however i let the tv sit for 3 days and when i plug it in i get nothing when i try to...
You need to be concerned about the convergence board. This is the board with all the RCA jacks and RF connections. Pull this board out. You will see two very large cooling fins [heat sinks] with two large ICs [black with about 15 pins each. Marked with #392 ---] I don't know the exact# right now. Replace these Ics. And check the small resistors that stand tall next to theses Ics, replace if necessary! Let me know what you find.Thanks for asking me!
Aug 22, 2010 | Mitsubishi VS-50111 50" Rear Projection...
Sony kv36hs500 tv, suddenly no power, no standby lights, no sound
U check the power source?Take the tv aparts,check or replaced the power fuse,might get lucky.Not,than sorry,this tv can't be repair,without replacing electronic's componnents parts.Hire the same shop to do the repair.Ur tv power ICS inverter are dead.
Jun 15, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Screen black no sound or picture with line in center
this is a common problem,the vertical hold has been damaged.dont leave the teli. on,the white line will burn the middle of the screen and leave a black mark. You need a new integrated circuit(i.c.) for vertical hold.
Mar 17, 2009 | Televison & Video
My tv has picture, but no sound (lots of hash sound)
should replace capacitor ( c 1010 marked on board if it is a M134C chasie also (c 1013) both capastors are 10 mfd at 16 volts. Also check (Q603) rca part number 266897 could be bad.
Jan 27, 2009 | RCA 32V420T 32" TV
No picture
Have you tried checking the fuses this is a solution i posted a little while ago!!! I was watching tv there was a popping noise and screen went blank. My husbands very practical and we took the back off the tv ,we tested the fuses with a fuse tester and one had blown we took the fuse too Maplin our nearest electrical wholesaler who found us new fuses £1.29 for a pack of 10. We replaced the blown fuse now everything works as it should. Hope this helps we saved about £275 by doing it ourselves but do make sure you feel competent enough to have a go its not that hard but do make sure you unplugg the tv from the electric before you attempt taking off the back and checking the fuses and be careful as tvs can store a electric ok
Feb 24, 2008 | LG RU-42PX10 42 in. HD-Ready Plasma...
Dell 32 LCD Flat Screen multiple problems
I have checked all the connections and replaced all the cables with the highest quality I could buy.  I think the problem is in the TV tuner itself.  I live in a MDU so I am stuck with a rooftop satellite/master antenna.
Oct 23, 2007 | Dell W1900 19 in. HD-Ready LCD Television
Philips 51PW9363 51" Rear Projection HDTV-Ready Television Logo
76 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
