Question about Toro Lawn Mower With Toro Power Tools
Won't start has spark
I took the plug out and it has no conpression. Thank you pjo
    President:
  • 986 Answers
How old of engine is it ,I had one do that to me and it had a small push rod that bent on the intake,I remove it and straighten it and it started but I did go bought one to replace it ,I hope this helps you,The reason it bent was because it got hot,
Posted on Sep 06, 2009
Have spark and fuel presure wont start if i spray starting fulid it starts
Cud hav failn conpression. inspect ign parts..spark may b weak or batt not at 12.6v. Fuel pressur mite b weak or injectr issue
Jun 14, 2018 | Cars & Trucks
Homelite xl chainsaw won't start. I took out spark plug, put in some fuel and if fired right up. But won't run.
You need to clean out the carb. possibly replace the Needle Valve and check the Diaphram for stiffness. Also check the fuel line for cracks and rott.
Feb 10, 2013 | Homelite Garden
My 2005 yamaha ttr 125 won't start, I change the spark plug and the conpression seem ok. What else could be?
Hi, N_glutek and the usual suspects are:
1. Fuel tank empty.
2. The fuel tank has old dead gas.
3. Fuel tank bottom contaminated with ethanol sludge, dirt, water, rust, etc.
4. Fuel supply valve/petcock turned off.
5. Fouled spark plugs.
6. Engine flooded as a result of overuse of the enrichner.
7. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
8. Fuel valve/petcock or filter clogged.
9. Fuel line to carburetor or throttle body pinched, kinked or blocked.
10. Carburetor float stuck.
11. Fuel injectors clogged.
12. A severely discharged or damaged battery, you need 12.5 volts or better and be able to pass a load test if necessary.
13. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
14. Loose or corroded wire connection at the coil or plug between ignition sensor and ECM module.
15. Spark plug cables in bad condition and shorting check for spark leakage in the dark, cable connections loose, or connected to the wrong cylinders.
16. Ignition timing incorrect due to a faulty ignition coil, ignition module or MAP, CMP, CKP, O2, TPS, ETP, IAC sensors.
17. Faulty neutral, clutch lever, or kickstand safety switch.
18. Faulty fuel pump or fuse or relay.
19. A stuck bent or burnt valve.
20. Tilt sensor needs a reset.
21. Security system not disarming alarm needs a reset.
22. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
TTR 125 won start need help
Yamaha TTR 125 Won Start eHow
YAMAHA TT R125 Owner Service Manual
OEM parts for Yamaha
YAMAHA TT R110E Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 04, 2012 | 2003 Yamaha TT-R 125
I have rebuilt the carb it is get fire and it still will not run (941av stiyl chainsaw) and it has 90% conpression
Use some starting fluid in the air filter or old school lighter fluid right down in the spark plug hole. Screw the plug in and try and start it up. If you get it to run this way it may pick up the fuel from the tank and run on it's on.
Aug 09, 2011 | Garden
My john deere lt133 riding lawn mower has been shutting down when it get's hot and now it won't start at all. i took a spark tester and I'm getting plenty of spark on everything but the plug. I...
Hi, what are you calling proper voltage? If its a gap tester it should jump at least 8mm. If its a peak voltage tester it should be at least 12,000 volts. If not the ignition module is faulty, which is very common on kohler engines. Hope this helps, regards Phil.
Jun 30, 2011 | Garden
Got spark and gas can't get it running what is the conpression supposed to be
i have a honda power washer EXHA2424, I replace new spark plug, new gas., cleans the cabureetor, and it still won't start please advice me what to do
May 21, 2011 | Devilbliss DeVILBISS Devap DVH2600...
Stopping no power poor gas miles
CHECK SPARK PLUGS, AND WIRES, CHECK COMPRESSION AND CHECK FUEL INJECTORS IF CONPRESSION 9 OR 10 TO 1 CMP IS GOOD THEN REVERT TO SPARK PLUGS, ARE THE WORN, IF SO, REPLACE WITH FRESH NEW ONE.
Feb 21, 2011 | 2003 Chevrolet Suburban 1500
Toro Lawn Mower With Toro Power Tools Logo
70 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
