Question about RTO Atwood DSI-RV Water Heater-6 Gallon
My rv water heater ignites, I have a steady flow of water in the sinks from the hot water spicket, but no hot water. The bypass valve is positioned paralllel to the cold water valve. I am not sure of the water heater brand, but is in a 2005 Sandpiper made by Forest River.
  • John Coristine
    John Coristine May 11, 2010
    IF THE HEATER RESEMBLES THE ONE IN THE PICTURE, ITS AN ATWOOD, OTHERWISE ITS A SUBUBAN. ANYWAY, HOW MANY BYPASS VALVES ARE THERE? IF ONE OR TWO, THEY WOULD BE INLINE TO THE WATER LINES. IF THREE THE OUTSIDE 2 ARE INLINE AND THE MIDDLE ONE IS JUST THE OPPOSITE.
  • 332 Answers
If your lighting and not getting hot water then you have a valve closed or your by pass is in the wrong position, if it is burning on gas it will heat water
Posted on Mar 06, 2010
Low or No Flow - Atwood 10 Gallon Elec, Gas, Heat Exchanger Type RV Water Heater
if good pressure on cold side check heater bypass maybe valve open partial or kinked hose
May 28, 2018 | Water Water Heaters
Where do I find the bypass valves for the hot water heater tank on a Jayco Eagle HT 27.5RLTS RV?
best advice is to find a Jaco distributor and talk with a service man as they have the diagrams or experience to fix the unit
look for a panel at the position out side the van where that unit is as there may be a removable section ( screws or pop rivets) that is the access to that unit
there are plenty of jayco sites around the country
May 09, 2016 | Water Water Heaters
Boiler won't ignite for hot water unless heating is on.
If this is in a RV the propane monitoring valve may require more gas flow to turn on than the water heater requires. A central heating system requires substantial gas flow so when the monitoring valve opens to fire the central heating, there is enough gas flow to also fire the water heater.
Jan 26, 2016 | Water Water Heaters
How to troubleshoot a water heater
1) If water flow stops when tap is off, then Sound of water running: could be factory-installed heat trap inserts or nipples: These things cause noise.
http://waterheatertimer.org/Low-hot-water-pressure.html#trap
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html#heat-trap
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
2) If sound of water continues when tap is off, then there is a broken pipe or leak somewhere in plumbing system.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 17, 2013 | Reliance 606 Series 40 Gallon Natural Gas...
No hot water coming out of tap but we do have cold water out of cold water tap...any suggestions??
Check your by-pass valve(s) at back of water heater. Water goes in cold to bottom fitting, and out hot at top fitting, so those 2 valves ( if any) need to be open, anything in between needs to be closed. There are a few different by-pass set-ups, so if that doesn't explain it, get back to me with a description of your valve set-up and I'll guide you through it. If valve(s) are all in proper position and still no flow through hot line, I'd suspect faulty check valve in between hot line connection and tank.
Aug 07, 2011 | RTO Atwood DSI-RV Water Heater-6 Gallon
Having trubble with hot water. It won't run up the sinks or shower only cold water. I own a 2008 keystone everest
Check to see if it has a hot water heater bypass installed,if so the valve is likely in the bypass position...
Dec 17, 2010 | Water Heaters
Have a 2005 coach w/Atwood DSI-RV 6 gal water heater. Gas lights, heater fires and gets hot, but doesn't transfer the hot water through the lines to the sink faucets. jwmystery@aol.com
You need to check by-pass valve(s) on back of tank for proper position. You need cold open going in to bottom tank fitting, and hot open at top. If any valves in between those 2 lines via "T"'s, turn them to off position.
Oct 29, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
MY Atwood 6 gallon water heater will start heating the water. I turn on the water and it is hot for about 2 minutes and then is cold. The water heater does not turn back on. I waited a couple days and...
Try opening the pressure relief valve (carefully so you don't burn yourself) slightly, and see if water comes out and if it is hot. It sounds like you may have very little if any water in there. Check by-pass valves at back of water heater for proper positioning. Cold should go in the bottom, hot out the top. Make sure there is flow through any valves going into bottom, and any valve at the top.Any valves connected in between the hot and cold should be in the off position. If need be, to test if incoming cold water getting into tank at bottom fitting, shut off water, relieve pressure in system by opening taps until all pressure is gone. then close all taps. Now remove your drain plug, then turn water back on, and water should shoot out the drain plug hole with good pressure within a few seconds and flow steady while water on. If not you have a restriction such as valve in wrong position or faulty, so try moving valve to get better flow out drain plug. If flow out drain is good, then make sure valve at top fitting on back of tank (if any) is also open for good flow . Any other valves should be closed in between those 2 lines. Let me know what you find.
Jul 16, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
RV water heater problem: my water heater ignities, when I turn on the hot water faucet there is a steady flow of water but no hot water. The bypass valve is parallel with the cold water line. I can only...
The first question is this
From the outside of your RV is the water heater square or is it longer than it is tall?
If it is square it is a Suburban
If it is longer than it is tall then it is an Atwood
Forest River mostly uses Suburban
How long do you let the unit burn/run before you try the hot water? From a cold start it will take - depending on the outdoor temp. & the gallon size of your water heater, 15 to 30 minutes for the water to get hot.
If you have waited this long then I would suspect the bypass valve is in the wrong position
Sep 06, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
RTO Atwood DSI-RV Water Heater-6 Gallon Logo
345 people viewed this question
Top RTO Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
Mike
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
