Question about Echo Garden
How do I change the primer bulb on my Echo CS-3000 chain saw
  • ed_harson Sep 06, 2009
    President:
  • 2,220 Answers
The IPL for an Echo CS-3000 is here:
http://www.echo-usa.com/pdf/documentation/CS3000T1T1E_081303.pdf
See page 8. There is no shop manual offered, you will need to interpret the pictures. Didn't look to difficult. GL
Lou
Posted on Sep 07, 2009
Testimonial: "Having the parts list helped me to understand how the primer bulb was installed. A great help. Thanks, Ed"
On an Echo cs-3000 the primer bulb is a snap fitting on the carb cover. If you remove the air cleaner. Open the choke all the way to close the intake opening and you will see the primer bulb and the 2 snap fittings. There are two hoses attached to the bulb the middle one goes to the carb and the center hose goes to the fuel tank. Remove these 2 hoses and put them on the new primer bulb push them back through and carefully attach the 2 hoses. Done
Posted on Jul 11, 2011
How do I replace the primer bulb on an Echo cs-346 chaln saw?
The part number is 12318139130 and this youtube video covers this part's replacement.
http://www.youtube.com/watch?v=cnzag2RqhRo
Jul 12, 2014 | Echo Garden
Fuel problems
David keep pressing the primer bulb and the air will clear. Make sure that you fill the fuel tank first.
Nov 10, 2013 | Echo CS400 18" Chain Saw
Brand new Echo cs-400 chain saw: The chain spins fast on idle. Should'nt the chain be stationary on idle?
The manual is available here:
http://safemanuals.com/user-guide-instructions-owner-manual/ECHO/CS-400-_E
The idle speed of the negine may be too high.
Page 26 of the manual gives instructions for adjusting the speed with the "T" screw on the carburettor.
May 12, 2011 | Echo CS400 18" Chain Saw
Chainbrake spring broke need new one
Parts Catalogs Parts Catalog, Chain Saw Model(s): CS-310 Serial: C04511001001 - C04511999999 Language: English Parts Catalog, Chain Saw Model(s): CS-310 Serial: C04612001001 - C04612999999 Language: English Parts Catalog, Chain Saw Model(s): CS-310 Serial: C04713001001 - C04713999999 Language: English
Jan 05, 2011 | Echo CS310 14" Bar Length Fully Assembled...
I've replace the spark plug, put in fresh gas and tested it for spark. My CS 100 chain saw will not start. Any help would be appreciated.
The spark at the plug (gapped 0.020") should be blue and snappy. If ok, pour a little fuel mix into the plug hole and try for start. If pops several times, then you have fuel delivery problems. Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other damage. Make sure the primer bulb fills with fuel when pumped several times. If nothing, either the primer is damaged or the carburetor needs cleaning inside. While in the carburetor, inspect the lower chamber diaphragm for hardness or cracking. Go to: www.drystacked.com for a 12 page article on Walbro brand carburetor theory and troubleshooting. Hope that some of this helps!
Oct 23, 2010 | Echo CS400 18" Chain Saw
How do I replace the purge pump on thr Echo chain saw model CS 3000
take side cover off and remove screws that hold the pump bulb in place and remove the gas lines make sure you put the right one back on each side.the one that sucks goes to carb. and other goes to gas tank.
Jun 12, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Cs 3000 carburator rebuild instructions
Go to: http://www.drystacked.com for a 12 page article on Walbro brand carburetors that apply to other brands as well. Make sure that all the external factors have been checked--fuel filter, fuel lines, primer, and carburetor fastener tightness. Check the air cleaner and muffler for plugging. Good luck!
Jun 10, 2010 | Echo CS400 18" Chain Saw
ECHO CS 3000 chainsaw-while idling, shuts off if held on an angle
The idle speed screw may be set too low--adjust so that the chain stops moving, but the engine keeps running. Drain the fuel tank and see if the filter falls to the lowest point of the tank whatever the position. If it doesn't, replace the fuel line hooked to the filter as it may have lost flexibility. Hope this helps!
Apr 11, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
How to replace primer bulb on small echo gas chain saw.
I just replaced the primer bulb on my Echo cs-305.
I didn't find the parts list too helpful.
It's easy. All you have to do is remove the air filter and look at the existing bulb from the bottom-- you can reach in with a screwdriver and pop the 'feet' holding it in place off their catches. When I put the new one in, I attached the tubes using a pair of needlenose pliers.
Apr 04, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Garden Logo
2,045 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
