Question about Samsung DVDR120 DVD Recorder
Vertical addjustment for a DVD recorder
I am trying to convert some PAL VCRs to NTSC DVDs from a JVC PAL VCR.
I bought a PAL-to-NTSC converter that works, but the vertical adjustment is off and is recorded as such by my NTSC MAGNAVOX DVD recorder.
Is there a way to fix this?
Thanks,
  • roberga Dec 09, 2007
    This make no sense and is therefore un-helpful.
  • 138 Answers
It should be inbuilt to switch on the vetical adjusment! or else you have to find another! 1
Posted on Dec 08, 2007
I want to play region 1 dvds on my toshiba dvr2o
Go into system , then disk settings , you should have a option to play NTSC on PAL select this and your region 1 discs should play with no problems. NTSC is region 1 format
Oct 10, 2014 | Toshiba Dvr20 Digital Dvd Recorder And Vcr...
JVC DR-MX1S
It's likely to be an incompatible signal. You have PAL (UK) and NTSC (Belgium), the DVDR/VCR combo may not be compatible with PAL causing it to seem like it's not receiving any signal, when in fact it is - but not in a recognisable format. You may try and get an NTSC to PAL signal converter like this: http://cgi.ebay.co.uk/NEW-TV-AV-Video-System-NTSC-To-PAL-Converter-Converor_W0QQitemZ270163920912QQihZ017QQcategoryZ32837QQtcZphotoQQssPageNameZWDVWQQrdZ1QQcmdZViewItem That'll solve your problem.
Sep 09, 2007 | JVC DR-MX1S DVD Recorder/VCR
I have an Aiwa hv-mx 100 vcr Now some time the picure of my pal videos doesn't show in NTSC tv. Is it the problem of converter within vcr? or voltage regulater?
Pal and NTSC devices signal prequencies don't matches.Can't work to gether.U sure it different Pal and NTSC mix together devices before?
Oct 22, 2010 | Aiwa HV-MX100 VHS VCR
I have converted some NTSC vhs to PAL dvd, when i play them on my LG DVD player, it says disc error
U must copy NTSC to NTSC.PAL to PAL.Check ur DVD recorder/VCR combo menu set up regions auto, if it have it.Will play all regions DVD discs.
Mar 26, 2010 | LG RC897T DVD Recorder/VCR Combo
Do you have video players that I can use to playback analog v8 tapes (PAL and NTSC) and record them in digital format?
I went to the local Sony store and they agreed to convert my 8mm home video tape into digital, DVD format for less than 15 bucks!
Oct 24, 2009 | JVC KV-V8 VHS/S-VHS playback VCR
The display screen is rolling and is in black and white.
Hi
You switched to PAL mode from NTSC or vice versa. Most DVDs will only output PAL or NTSC, not both. So even if the disc is region ffree, the fact that it's encoded in PAL (50hz) makes it appear like you describe - no vertical hold / black and white.
Some set top players [Apex, Phillips] will convert PAL to NTSC on the fly or vice versa.
Remember, PAL/NTSC is not the same as Region.
Here's some detailed info:
http://www.michaeldvd.com.au/Articles/PALvsNTSC/PALvsNTSC.asp
http://www.sjbproductions.com/web_pages/tip_video/ntsc_pal.htm
http://www.dvdcity.com/codefree/codefree-ntsc-info.html
You can convert the DVD to NTSC, and strip the region code by following http://www.videohelp.com/guides/how-to-convert-interlaced-pal-dvd-to-ntsc-dvd-id1107#1107
-or-
http://forum.videohelp.com/topic221928.html
[This is very time consuming.]
You
What DVD
Most players are either NTSC or PAL, however increasingly DVD players from the Far East (Apex, Phillips etc)
, which is 50hz instead of 60hz, hence the lack of vertical hold
Mar 23, 2009 | Televison & Video
Converting NTSC home Video tapes to Pal DVD or NTSC DVD
You need either an NTSC DVD recorder (keep in mind that the US has 110 voltage, while Australia does not), or a computer card that supports NTSC. Some video capture cards support both NTSC and PAL (often switchable). Choose good quality, and pay attention to video/sound sync - some bad quality cards loose sync. Once the tapes are transferred to DVD - and keep it native NTSC all the way, they can be played on virtually any PAL DVD player/TV combo. With an NTSC source, it's best NOT to convert to PAL, while with a PAL source in the US, you'd need to convert to NTSC or only show the DVD on a computer (where NTSC/PAL doesn't matter).
Feb 19, 2009 | Panasonic DMR-ES35VS
PAL to NTSC conversion
This is not a converting unit, it will play the format of the tape inside. To convert the signal you need one of the following:
1) A converting VHS player; they are fairly expensive.
2) A separate video converter (hardware); they run for about $200-$500; just put this between your VCR and the TV.
3) Capture the PAL on your computer using a software like Movie Maker via a Firewire cable. Than convert it to NTSC on your machine using software like Nero... do a search on Google for converting software. Or just watch it on our computer in PAL format, most computers do that... For this step I use a separate camcoder that has a passthrough feature. The VCR connects to it and the camcorder connects to the computer via Firewire.
4) send the PAL tape to a specialized shop for conversion. They normally charge $30-$40 for a regular 2h VHS tape.
Jan 20, 2008 | Philips DVDR3435V/37 DVD Recorder/VCR
Pal to NTSC
If you bought a converter it would convert 25 frames a second to 29.97 or 30 frame 625 to 525 NTSC no adjustments and thats been that way for decades. You can rent a sony or Aiwa deck with legal converter on board and do this easy. So go and get a real converter!
Dec 08, 2007 | Televison & Video
NTSC to PAL
You have to buy first a VHS player that can play NTSC, might not be available locally in Ireland so you have to probably buy online (US). The DVD recorder is fairly comnon nowadays and all of them are capable of recording and playing NTSC and PAL. You can then connect the AV out of VHS player to the AV In of the recorder. Or you can use a VHS-DVD combi. You can google in UK, here is an example: Toshiba RD-XV45, according to the specs, it can play NTSC on the VHS and you can record to DVD on any format that yoou want You can go to this link to view other product: http://audiovisual.kelkoo.co.uk/b/a/sbs/100304323/16875665.html My father died of cancer 6 years ago and I am also transferring the Hi-8 videos to digital format using PC.
May 23, 2007 | Samsung SV5000W VHS VCR
Samsung DVDR120 DVD Recorder Logo
50 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
