Question about IBM Office Equipment & Supplies
I have a IMB 4610-TF6 and it's making weird
I have a IBM 4610-TF6 and it's making weird characters. Any solution?
I installed 4610windrvxp020500.exe as the driver
I ran the offline test and it seems OK.
Do I need a firmwire?
Install Epson TM driver?
Thanks. Mike
  • mikely1 Sep 06, 2009
    Hi Solution #1,
    Thanks for replying. When I install the driver, there is no option to select English. I am using a RSS Port and select COM2 as the port. The property for the port is 9600 Bits per second and 8 data bits.
    Is there a option the driver menu to select English?
    I have spend hours on this. Hope you can help.
    Many thanks...
    Mike
  • 37 Answers
Ummm did make sure your .exe was in english first?
Posted on Sep 06, 2009
Testimonial: "Hi Solution #1, Thanks for replying. When I install the driver, there is no option to select English. I am using a RSS Port and select COM2 as the por"
Dear expert pos machine(ibm SureOne100 Type :
looks like its running on IBM PC DOS. code page 708 - arabic. https://msdn.microsoft.com/en-us/library/cc195061.aspx however if you are using windows, then you may need an arabic windows, just adding an arabic languge file wont help. IBM PC Dos doesnt have an arabic option. you can download the ibm surepos 100 4613 technical reference manual which is what i did for you. but it no help in that arabic is not an option. research using arabic with DOS. because your keyboard is basically a PC one working in DOS.
Oct 03, 2017 | IBM SureMark Printer TF6 Thermal Label
Problem printing with IBM 4610 TF6
It can be a connection problem, since the printer and the computer are not communicating, probably the cable is bad, so if you have a different cable that we can try that will be better so we can check if its only a cable problem ...
Hope that helps......
Aug 28, 2008 | IBM 4610 TG4 Thermal Label Printer
Stopped printing
reinstall your program for printer.if it dont work.
printer is bad.let me know.ok
Jul 21, 2009 | IBM SureMark Printer TF6 Thermal Label
Printing only one side
Most likely the small 'roller' on the LHS of the paper feed shaft is missing. This roller engages the metal 'yoke' on the LHS when the printer lid closes and provides a suitable pressure for the paper to contact the thermal head. They break into 2 pieces sometimes and fall away from the shaft. Solution: remove circlip and replace the roller if you can get one. I have them made.
Mar 26, 2009 | IBM SureMark Printer TF6 Thermal Label
Printers Spew out 18" of journal tape every morning x 8 registers
Talk to the software suppliers on your Tills, they may have an idea.
Jun 17, 2017 | IBM SureMark Printer TF6 Thermal Label
Cannot get printer to print
very possible but you may need to disable the firewall if you have one then disable the antivirus . then try to reinstall software for the printer and follow directions closely. biigg53566
Dec 05, 2008 | IBM SureMark Printer TF6 Thermal Label
IBM 4610 suremark receipt printer
Hello all,
had the same problem and my solution was to install the latest driver available at the IBM service/driver website. Then unistall it with another IBM driver cleaning tool, then repeat both processes a couple of times, until the printer responded. There is some bug on these latest drivers an older Windows versions, so only after some installations and repairs on the first install, windows gets it right. VERY STRANGE but it worked in 2 machines, both IBM terminal and 4610-tf6 IBM printer.
By the way; RS232 ibm cable...I believe its a null modem 9 pin...not a regular serial cable.
Dip pin config: my printers have 4 so; 1ON 2ON 3OFF 4OFF which means
1 size of paper you are using 80mm
2 if you use an IBM software or other:other
3 if xon/off or DTR/DSR:hardware
4 com speed: 9600baud or 19200baud, 9600
That's what I igured out. If you need any more info: mail
fit.frederico@gmail.com
FredP
Sep 28, 2008 | IBM SureMark Printer TF6 Thermal Label
583 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
