SOURCE: Print head remains clogged canon pixma iP 4000
I have successfully managed to clean the print head with isopropyl alcohol by placing a flexible plastic tube over the cartridge seat, filling the tube partially with the alcohol, then blowing very hard through the tube. The alcohol does not appear to harm anything.
SOURCE: 5 flashes amber pixma ip3000
5 flashes amber means the print head is not installed properly (error code 1401) or the EEPROM data of the print head is faulty (error code 1403 or 1405).
Make sure the contacts on the printhead are clean, re-install and try again. If this fails a new printhead may be required. You may be able to re-initialize the EEPROM by entering the service mode.
SOURCE: Canon pixma ip 3000 power problem
The cord is a tough one. but it has to be pushed in very hard in some models. are you sure it is plugged in at the back of the printer hard? push extra hard.
