Question about Whirlpool Dishwashers
Model ADG 332 SAV Just after switching on, after rinse water filled up, a big cloud of acrid smoke billowed out of the machine, without fusing it. Cycle then stopped. I switched off the machine, and on restarting nothing further, just an occasional mechanical bleep. Is this terminal or an weasy fix?
  • gristdavid Sep 06, 2009
    Thanks for your quick response. I have no background for this kind of thing. Is this the beginning of the end for this machine, or is a replacement panel a cheap and simple option for a continuing useful life? How much can I expect to pay for a panel?
    Yes, it has at least got me on the right track.
    Brigadier General:
  • 3,614 Answers
This could be a control panel failure or a timer switch has a problem, you may need to check this controls with a VOM meter to test if the panel is still functioning properly. You have to unplug the unit after doing this and you may need a help of someone who is professionally familiar fixing electronics if you have no background or have no idea doing all of this things.
Hope this initial info helps.
Posted on Sep 06, 2009
  • micromaster
    micromaster Sep 06, 2009
    eventually if the panel was dead/faulty replacement was the best option for that.. As of now I have no better idea on how much the part will cost now, better to call for any local repair center on how much it will cost for the replacement.
Roper washing machine does not fill for rinse cycle. Goes directly to rinse agitate without water.
Without Model number I am only guessing but I suspect you have a blocked sensing tube that travels from the Level selector switch to the side of the tub somewhere. It is possible for this plastic tube to become partially clogged and not allow trapped air to vent when tub is drained of water. Usually this problem manifests itself as an overflow of the tub. Check the full length of this clear hose and see if the end nearest the tub looks like it may have debris or dirty detergent clogging it.
This hose is pushed onto a nipple mounted to a reservoir on the side of the tub. Push a thin copper wire 4-5 inches into the those after removing from nipple and also down into the nipple an inch or two before reinstalling the hose to the nipple. You MIGHT even blow into the hose while you have it off and you SHOULD hear a clicking sound coming from the level selector switch body.
Good Luck. Come back with Model number under lid if that doesn't help.
Nov 28, 2015 | Roper Washing Machines
Machine will fill and wash , but will not fill and rinse
AS YOU SHOULD KNOW KENMORE APPLIANCES MADE BY MANY DIFFERNT COMPANIES AND WITHOUT FULL MODELL NUMBER IT IS HARD TO SAY WHAT IS PROBLEM BUT COULD BE DOOR LOCK OR MAIN CONTROLL BOARD PROBLEM
Dec 09, 2013 | Sears Kenmore Elite 3.9 cu. ft. Front-Load...
When starting the machine its starts washing without filling
This could be because the water level fill switch assembly is bad and it is telling the washer that it is already full of water.
Nov 27, 2013 | Maytag Centennial MVWC500V Washer
Maytag_lse7804ace: washer won't fill with water. If I fill it by hand, the cycle works fine (until it gets to the rinse cycle, when it won't fill again).
Hello John,
The most probable reason the washer is not filling is because of a blown fuse that is part of the lid switch asm. By UNPLUGGING THE WASHER and removing the 2 INNER screws on the the control panel and the control panel can be rotated down to see the fuse in the lid switch asm. Here is where the fuse is on the switch asm. its circled in red 11_4_2011_1_39_54_am.jpg
Nov 03, 2011 | Washing Machines
When cold water is selected the washer does not start or if cold rinse is selected it does not fill or go any further in the cycles
Cold water valve is faulty. on hotter washes it will fill with hot but all rinses are cold fill so will stop waiting for water at first rinse.
Aug 03, 2010 | Washing Machines
Filling and running for 2 mins, discharging all the water then signalling that the cycle is complete Model is ADG 7460
This sounds like the heater is faulty. Try running the dishwasher on a rinse cycle- if this cycle completes as normal then this would prove that the heater has gone. If not please get back to me
Jun 12, 2010 | Whirlpool Dishwashers
Mower smoking and running rough
Check the gas you put in, it sounds like it had water in it.
Apr 26, 2010 | John Deere 420,1020,2010,2020,2510,2520...
AUDI A6 1999 USING OIL, NO OBVIOUS SIGNS
your engine needs to be compression tested
May 28, 2009 | 1992 Audi 80
Cold water will not stop filling during rinse
while the unit is filling in the warm cycle. reach behind and shut off the hot water tap.I bet the water flow stops filling, if so, you would need to change the inlet valve on the machine. You see, in warm, if the cold is not filling, you still hear the hot filling and the unit will advance. The rinse cycles are mostly "cold" only. if the valve is not opening it will not allow it to advance from the rinse section on the board.
Feb 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
What do i do to clear the ''rinse machine'' message?
Fill up the water tank 150%
Turn the "Milk" knop and have two cups underneath that you can empty regulary. Then just wait and the machine will say Rinsing Finished.
Fill up the water tank completely again, and the machine will ask. "Clean Water" press the big cup knop.
Then the machine should say, *SELFTEST*
Nov 12, 2008 | Miele CVA615 Espresso Machine
Dishwashers Logo
27 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
