Question about iLO V27DMBX Television
Preassembled stand removal from 42 inch lcd tv LCT42HA36
Cannot get stand off for wall mounting
  • 4 Answers
SOURCE: the stand on the bottom
There are a number of small silver phillips head screws atteching the base to the back of the set. Remove these and the base will come off. I would suggest that you replace the screws into the back of the set so they won't be lost. I assume you have purchased the proper mounting bracket. If you shop at Wal Mart, they carry two sizes. The 32" will require the largest size. This info applies to what I purchased, which was the 32" LCD flat panel wall mountable unit. I hope I have been some help.....timitot2
Posted on Aug 26, 2007
SOURCE: how to remove the stand from samsung LCD TV
Place the tv on its screen flat on a soft surface,
you need to remove all the screws, not just the stand one marked.
Lift the back panel and then you will be able to slide down the stand, when you have removed the back cover you will also see where how your wall mount will fit to the chassis.
Place all the screws back on the back lid.
Posted on Feb 09, 2008
SOURCE: Wall mounting Panasonic Viera 32" tv
Took me a while to find this. Remove the two lowest screw, holding on the plastic back, in the centre and it drops out.  -- Andrew
Posted on Apr 27, 2008
  • 15 Answers
SOURCE: tv stand screws
Check the kitchen drawer next to the fridge for the screws !!
When you get new screws, use lengths 1/2".. any longer and you might hit something inside.
Don't know why this is posted under IS-LCDTV26.. I would pull a screw from my 26" and measure it, but it's most likely different than your 42"
Posted on Sep 06, 2008
SOURCE: Wall mount
Vuepoint low profile wall mount model fpm255b-01 at walmart
Posted on Oct 23, 2008
SOURCE: Can not remove the stand to mount it on the wall
If the Aquos 46 is anything like the Aquos 42, the monitor is attached to the base with machine screws (bolts). They are located in the lower back portion of the monitor, probably need an Allen wrench to loosen and remove. Once that is done, the base can be removed from the monitor. Best way is to lay the monitor face down on a tabletop padded with foam, a quilt or blanket, etc to protect the screen as you work. Remove the stand from the monitor, not the monitor from the stand; it is easier and safer that way.
Posted on Jan 24, 2009
0 characters
1 Points
Remove stand from w4207 TV
Put tv on bed face down and look at the stand and locate and remove any and all screws holding stand to the flat screen set. Then after mounting the wall plate per instructions mount the tv to wall mounting.
Sep 08, 2015 | Westinghouse W4207 42 in. HD-Ready LCD TV
How do you take a stand off
There are 4 screws found in the center bottom of rear plastic back. 2 at top and 2 at bottom - approx 1/2 inch from bottom the 1st 2 will be about 3 inches apart - then directly above there are 2 more. These screws hold the bracket that holds the stand. Once you remove the bracket there should be no parts sticking out further than the actual television and can now be mounted to the wall with a mounting system.
Jul 20, 2014 | LG 42LH30 42 in. LCD TV
My tv is a 42 inch toshiba model#42HL67 im trying to remove the base from the tv so that i can mount my tv
Hi, I have looked into whether or not this t.v. is wall mountable. The only way to tell if this is possible will be to look on the back of t.v. and if wall mounting is possible then there will be 4 screw holes approximately 15 inches apart forming a square. If these " mounting holes are not present then there is no way to mount the wall bracket. Second if holes are present there may be a protective plastic cover at the top of the table top stand where it meets the t.v.. It more than likely is just a snap on type situation and a little bit of prying will pop it off revealing the screws. I hope this has been useful, and thanks for asking FixYa, Good luck- Prodzilla.
Apr 20, 2011 | Toshiba 42HL67 42 in. LCD Television
Could you please advise me how i can take the stand off my television so i can mount it on the wall??
hi there, swivel stand of the TV is all detachable by screws. try to locate them underneath or sometimes it is cover with rubber caps so it is not easily noticeable. if you remove the stand then you need to purchase a lcd wall mounted frame, I suggest the universal one for this is adjustable up to 42 inch LCD monitor. hope this helps please rate and vote.
Mar 30, 2011 | Flat Panel Televisions
Can my sanyo dp42746 be hung up on any tv stand. The brackets that hold up my tv broke off where can I get new ones??
Tries websites like, to buy a new wall mount bracket set for holding tvs 42-50 inches.Should work fine LCD tvs or Plasma tvs used the same wall mount bracket set.
Jan 13, 2011 | Sanyo DP42746 42 in. Plasma Television
42'' Sense LCD TV Removing the Stand
usually you got 4 screw in the back of the tv need the bottom
be sure to put tv face down on your bed you gone have a surprise
gone fall from the stand
and pull it from the tv by the buttom
Mar 06, 2010 | Flat Panel Televisions
How to remove stand on vivo 32 inch lcd tv
if you send picture to , i can try to help you
Sep 12, 2009 | Flat Panel Televisions
Tv stand screws
Sep 01, 2008 | Insignia LCDTV26 26 in. Television
Stand base removal
how do you remove the stand of lg 50pg30fd so it can be wall mounted
Jun 15, 2008 | Toshiba 42HP66 42 in. LCD Television
iLO V27DMBX Television Logo
76 people viewed this question
Top iLO Flat Panel Televisions Experts
Jaime Hernandez
Are you an iLO Flat Panel Television Expert? Answer questions, earn points and help others
