Question about Frigidaire ATF6000ES Front Load Washer
Water remains in tub after spin cycle
Water remains in tub after cycle is finished. It can not be seen as it is below the tub but you can hear it sloshing around as it stops. The tub has a bad odor and I have poured bleach in it and let it sit for awhile, fill tub and then spin it out. Tub smells better after that. Problem is that I know that if I don't do this after every wash that the old dirty/smelly water is mixed in with each new load. Is this normal?
  • red0723 May 11, 2010
    how old is the washer? there is a pump that should take all the water away after it spins; sometimes it sits there a makes a noise; that is the pump taking the water out. Does it sit there a make a noise and you think it may be stuck or does it just shut off and is finished?
    Problem Solver:
  • 7 Answers
Hi, a small amount of water in the tub is normal, between the inner and outer drum. As long as it's below the inner drum you're ok. If it's a front load this is a common smell. Just make sure you dry the rubber seal and leave the door open a little to allow air to circulate through the washer.
Posted on Sep 06, 2009
    Problem Solver:
  • 3 Answers
Have you tried to clean the drain hose on the back of the washer? It may have build up inside that you are loosening up by using bleach.
Kenmore 80 series washer model 110 doesn't fully drain when cycle complete
With the lid open, try to turn tub by hand. If you can you may have a bad clutch. If you hear the washer agitating at the begining of the cycle without any water and filling at the end of the cycle, replace the ATC switch. Try spin cycle and open the lid, if you don't see the tub turning, but hear the motor, check motor coupler, or if it never spins after you close lid, check lid switch. These are the most common solutions to this complaint.
Sep 02, 2014 | Washing Machines
Is it normal to have substantial amount water remaining in the washer after final spin?
Hey friend, thank you for allowing me to assist you!
It is normal to have water in the tub after your Frigidaire washer has completed the final spin cycle. The water that is in the tub is there to help prime the pump. Hope this information is helpful. -Matt
Jul 27, 2014 | Frigidaire Affinity ATF7000E Front Load...
GE Topload Washer WPSR3100W1WW -- finished spin cycle, clothes were spun as normal. Water on the floor after spin cycle. When jiggling tubs, we can hear there is some water still in machine. Bottom metal...
That is normal. The balance ring has liquid in it. # 327
On these machines the tub is suspended with 4 metal rods. The lateral movement is controls by 4 straps. When these stretch the tub gets loose and water slings out the washer. Seen it.
Training Manual
This video shows how to take the whole thang apart:
Sep 18, 2010 | Washing Machines
Will not spin regularly
The water should be pumped out in a short time just before the spin cycle begins. Do you hear the pump motor running? Check the drain hoses to and from the water pump for kinking. If ok, check for a stray sock or something that blocks the drain port in the bottom of the outer tub. If also ok, check the plastic pump impeller itself for sheared splines which couple it to the motor shaft. If the motor turns, but impeller doesn't, replace the pump mechanism. If still under warranty, take advantage. Hope this helps!
Apr 12, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Why isn't the maytag neptune draining? when you spin the barrel you can hear water?
if you do not see water in the tube and the clothes have spun out enough to go into the dryer when the washer cycle finishes the washer has drained out all of the water the water you hear in the tub when the door is open and you spin the tub with your hand that liquid is in the sealed balance ring , that is a sealed channel around the front of the tub to help the machine stay balanced it does not come out
Apr 04, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer has water remaining in the tub after it finishes, happens intermitantly. Some times, after washer is off, you can hear water trickling & when you open the door, water is trickling down from the...
Sounds like you may have a bad water valve. Go to http://www.partselect.com/MultiModels.aspx?ModelNum=mah6500&searchTerm=img_54050&RefineSearch=0&imgMfg=Maytag&Page=2 and the water valve will be #14. You can check to see if this is the problem by running a load. After the machine is finnished adding water in the rince cycle, turn the water off to the machine. Let it finnish spinning. Then look to see if the water is still coming in. When a water valve goes bad it can act funny in many differant ways. Your sonds like it may have trash in it that allows it to leak water some of the time. Good luck
Dec 15, 2009 | Maytag Neptune MAH6500A Front Load Washer
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Neptune-is water supposed to remain, after wash is finished, between tub and outer shell
if you hear water when you spin the basket,that is the front tub balance ring.it is filled halfway with water in order to assist mach in balancing load.that is a normal sound.the mach may also leave some water between the basket and outer shell depending on lengh of drain hose.as long as the clothes do not come in contact with the water it is fine.
Sep 27, 2008 | Maytag Neptune MAH5500B Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
293 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
