Question about Nokia N73 Cellular Phone
Hi,howe do i installin off my Nokia PC Suite Connectivity Cable driver? i try it but is not working
    President:
  • Nokia Master
  • 511 Answers
Try to get a new version of nokia pc suite software insatll it then connect it with cable .....ur work is done....
Posted on Sep 06, 2009
Nokia 7210 no response from host
definitively do what TBasilH said! it works!
uninstall Nokia Suite and PC Connectivty Solution, and delete Nokia Connectivity Cable Driver from Nokia folder.
after that, restart both mobile phone and computer - and it will work!!!
i have different type of nokia, but it still helped!
May 20, 2012 | Nokia 7210
Modem not found, install nokia connectivity cable driver software
Have you installed the Nokia Pc Suite? If so, try installing only the Modem Driver, you can download it from HERE. Actually, it should automatically install with the Pc Suite, but if in case, there's problem, installing the Modem Driver separately will fix the issue.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Jun 18, 2011 | Nokia N70 Cellular Phone
I up lode the pc sute for nokia 2690 but the connectivity is not there its shows that usb modem is not connected
uninstall the pc suite first. > go to device manager by typing "devmgmt.msc" in "run" > check if there the nokia hardware is listed there or not. > if it is there uninstall it. > restart the system and install the software. > when it prompts to insert the usb cable insert it. > it will automatically detect the cable and will install the firmware from the mobile. > after installing it will work fine.
mail me raaj_k001@rediffmail.com
Jan 14, 2011 | Computers & Internet
I have already installed nokia pc suite.but i can't connect my nokia 5130c xpressmusic with my laptop via cable. what can i do?
this is because you did not install nokia connectivity software on your laptop. After install the PC site, you also need to connectivity software.
In case you don't have the connectivity software, you can download it from the below link:
http://www.nokia-asia.com/support/download-software/cable-drivers/driver-for-nokia-dku-5
Good luck.
Sep 02, 2010 | Nokia 5130 Cellular Phone
My nokia 6600i is not recognizing the usb wire when connected to the computer and when connecting the headset it keeps showing the usb wire icon for some minutes and then asks to connect the device. I...
Hi, if you want your PC to recognize the phone your using, you will need to install a nokia connectivity first before install nokia pc suite.
Nokia connectivity is a driver that makes your PC to recognize the phone when connected.
When you install the nokia connectivity, install nokia pc suite, and then try it out again. am sure it will work.
Note:Hope the cables are ok.
Take care.
Jun 21, 2010 | Nokia 6600i Slide Cell Phone
MY MOBILE IS NOT CONNECTING TO P C ALLTHO PC
its not only pc suite that needs to be installed. You also need to install nokia connectivity driver. This willl install your usb cable.
You can download the connectivity driver from the nokia link below.
http://www.nokiausa.com/get-support-and-software/product-support/nokia-6102i/pc-software/cable-drivers
Also cross-check if your usb cable is well connected to your phone and computer.
Take care.
Apr 22, 2010 | Nokia N73 Cellular Phone
Howe can i installin my old seria off Nokia N73 Connectivity Cable Drive on My PC Suite??? PLease helmi !
install the nokia pc suit through the cd given to you when you purchased your mobile.
Sep 06, 2009 | Nokia N73 Cellular Phone
I m not able to connect my moblie noika 7210super.... with computer.........wt to do???
Hi Friend,
First initially check wither u have installed the Nokia PC suite which supports your phone,or u can download the latest version of PC suite from the below link provided.
http://nds2.nokia-in.nokia.com/get-support-and-software/product_support/nokia-7210/software/pc-suite
If you are going use PC Suite with the Nokia Connectivity Cable DKU-2, download and install the cable driver first: Nokia Connectivity Cable DKU-2 driver.which can be downloaded from the same link provided
Check and revert back,kindly rate this solution,
Thanks for using Fixya
Regards,
Ayyasam
Jul 06, 2009 | Nokia 7210
Contect service in nokia 3110c how can i solve i am mechenic
Install Nokia Pc Suite software on you PC and do not connect the USB connectivity cable before or during the Pc Suite installation. When the Nokia Pc Suite installation is finished, Nokia Pc Suite will automatically launch the Get Connected Wizard. The on screen instruction will guide you to connect the USB connectivity cable to your PC and to your Phone. The default connection setting will appear on your phone screen. Select Pc Suite.
Nokia Pc Suite will install the cable drivers. This installation may take a few moments and you may be asked to accept the multiple driver installation. Once your Nokia Pc Suite have been installed, you can connect to the internet using "One Touch Access"
Jun 18, 2009 | Nokia 3110 Cellular Phone
I am having nokia n95 i want to connect my mobile to computer through internet via mobile office and i also having latest pc suit .7 but having problem 1- nokia connectivity cable driver software2-survice...
firstly take proper mo settings start ur internet service then insatll pc suite in computer check ur usb cable is proper or not then make a dial up connection with *99# dail code ur work is done...
Jan 31, 2009 | Nokia N95 Cellular Phone
Nokia N73 Cellular Phone Logo
47 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
