Question about Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive
Im using a new 320gb freeagent go formatted to hfs on my mac.i cant seem to transfer any thing into the hard disk.
  • 33 Answers
Try formating it and use the volume format of MacOS Extented Journaled. If your planning to use it only for a Mac Computer.
If you are planning to use it with windows and Mac try formatting it in you mac and use the volume format of MS DOS.
Posted on Sep 17, 2009
  • 3,153 Answers
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit but these issies also refer to macs and linux too !
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especialy true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
Posted on Sep 06, 2009
I have a 320gb simpledrive. So far, I have used it for my Mac. Will files I stored on it transfer to my new PC? If so, what do I have to do?
Your Windows PC won't read the files straight away, and when you plug the drive into your PC, it will likely ask to format - Don't!. First install some software to help read the drive, for example, HFSExplorer. Use the software and another large disk to copy all the files off the drive, then reformat the drive to something (not HFS) that both Mac and Windows can understand - perhaps exFAT?
More options here: https://www.howtogeek.com/252111/how-to-read-a-mac-formatted-drive-on-a-windows-pc/
see also
http://www.catacombae.org/hfsexplorer/
Yes, it can do HFS+ (mac OS extended)
Sep 25, 2017 | Computers & Internet
Windows is unable to read the usb
When you formatted the drive for the Mac, you probably used the HFS format. Windows can only read NTFS or FAT formatted drives. You will need to reformat your external drive again. If you use a FAT32 format, all computers will be able to read the drive (Windows, UNIX and Mac - anyway). Note: the FAT32 option does limit the number of files in each directory and the maximum file size.
First back up any files that you have put on the external drive to another disc (your computer's hard disc, for example).
If you are using the M2 external disc for Time Machine backups, you should partition the drive into two sections. Format one to the FAT32 and the other to HFS.
The Disc Utility in OSX can repartition the drive and reformat it. However, sometimes it doesn't correctly format the new partitions. You may need to do some extra step, see http://www.cs.ubc.ca/~pcarbo/macnexstar.html for one set of reformatting steps. In Windows, there is a similar utitily in the Disk Management Control Panel. (Start > Control Panel > System and Security > Administrative Tools > Create and format hard disk partitions (Windows 7)) You can only format the disc to FAT or NTFS with the Windows utility.
Some third-party software is available for changing the partitions on a hard drive formatted for Windows use without losing the data on the disc. I do not know if similar programs exist for OSX.
Some versions of Unix have gparted which will also repartion and reformat a hard disc but can't keep the original data on the drive. (I've used the Windows and Unix partition managers, including Paragon Partition Manager which let me keep my original Windows data on the drive.)
I hope this helps.
Apr 12, 2012 | Samsung M2 PORTABLE 320GB USB20 HARD DRIVE...
My mac is reading my transcend storejet 25 mobile 320gb, but i cant copy files from my mac unto it
Hello Kinoshia,
It seems that Transcend external hard drive have different file system. This is because the Mac machine is not able to transfer the files on to external hard drive. Please format the Transcend external hard drive from Mac machine and then hard drive is ready to accept the data from Mac machine. The drive either has to be formatted for Mac( HFS & HFS+) or FAT32 partitions. If you want to use
Transcend external hard drive for both Windows and Macs than format the drive to be FAT32.
Jun 05, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
My Seagate FreeAgent Go250GB become write protected for Macbook, but works fine on windows laptop. How can I fix this issue?
It's probably formatted to the wrong filesystem; Macs prefer HFS+, Windows prefers NTFS, but they both can read and write FAT32. I'd recommend using the Mac's Disk Utility application to reformat the drive to be FAT 32 (but be careful, this will erase the external hard drive, so back up first!)
Apr 04, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Is the iomega prestige desktop hard drive compatible with the macbook version 10.4.11
dblingest:
According to the datasheet for this product (click here), the drive is compatible with Macs.
If you want to use the drive on both Windows and Macs, you'll need to leave it formatted as FAT32, but if it will only be used with Macs, I would reformat it as HFS using the Disk Utility application that is located in /Applications/Utilities. Formatting with HFS will all for more efficient use of the space on the drive.
Please ask follow-up questions as needed and thanks for using FixYa.
Feb 05, 2011 | Iomega 1.5TB Desktop USB Hard Drive
My mac OS X 10.4.11 won't let me drag and drop into Seagate Expansion 500GB - says it can't be modified!!! Help please.
If the drive is formatted with NTFS (the format used by recent Windows operating systems), then you won't be able to write to that file system.
What you will need to do is reformat the drive to HFS or FAT32.
If you will be moving the drive between a Windows and a Mac, then you'll have to format with FAT32. If you will only be using the drive on your Mac or other Macs, then format the drive with HFS.
NOTE: unless you copy the existing files off of the drive first, you will lose all data on the drive.
To do this, do the following:
  • Copy all existing data off of the Seagate drive to a safe location
  • Unmount the Seagate hard drive
  • go to your Machintosh HD / Applications / Utilities folder and start "Disk Utilities"
  • Select the Seagate drive from the list
  • click on the Erase tab
  • Select the Format. For HFS choose "Mac OS Extended (journaled)" for FAT32 choose "MS-DOS FAT"
  • Type a name for your volume in the Name: field
  • Click the "Erase..." button and allow the Disk Utilities program to format the drive
  • Once the drive is formatted, you will be able to save files to the disk.
Thanks for using FixYa and have a great day
Jan 15, 2011 | Seagate 500GB USB 20 5400RPM Portable 500...
Hi i need to copy files from my macbook to my seagate hard disk which is in ntfs format.. it says it is write protected... help me...
the ntfs format is windows operating system format...
MAC will not recognize this format...
You need to format your hard disk according to the MAC OsX from your MAC computer...
Dec 13, 2010 | Seagate FreeAgent Pro Desktop - 320GB -...
Maxtor Basics portable 320gb Mac to pc compatability problems
Hi Tys,
I had a similar issue with my Maxtor Basics portable 500GB drive. I hadn't formatted mine yet, but had heard there were issues, so decided to find out before I start. I even saw your post here looking for an answer. Finally, one of my friends told me the following solution, which worked fine for me:
Don't format the drive as any of the Mac OS Extended options, simply reformat it as MS-DOS (it should be one of the options in Disk Utilities when you choose Erase and go to the Volume Format dropdown list).
Your Mac should be able to recognise and use the drive in this format and it works for PCs. Transferring files between the two shouldn't be a problem.
A thing to note, though, is that these Maxtor drives apparently come ready-formatted as MS-DOS (mine did). But while my Mac recognised the drive, I couldn't copy files on to it. If this happens, erase this MS-DOS formatting with... MS-DOS. Don't ask me why this works, I'm not a Mac Genius, but now my Maxtor is trouble-free and can transfer files from PC to Mac and back again.
Hope this works out for ya!
K
Apr 27, 2009 | Maxtor Basics Personal Storage 3200 Hard...
Formatting my Freeagent 1tb external hard drive for my Mac?
the problem is that your western digital operates using the NTFS (New Technology File System) which is the standard file system of Windows. Apple macs is not interopable with native NTFS therefore you need to install a read-write NTFS file-system driver on your mac.
an excellent free mac NTFS driver can be found here-
http://mac.softpedia.com/get/System-Utilities/NTFS-3G.shtml
download and install the software then restart your mac.
//javaftper
Mar 30, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My Freeagent external hard drive doesn't show up on My Computer
Your Mac would have formatted the Seagate drive as HFS+ (journaled) format. If you have access to a Mac, copy your data off the Seagate to any Mac, then use your PC to reformat the Seagate drive in FAT32 format. Macs recognize FAT32 format, and can store data in it, but can't create the format. The Mac holding your data can store it on the Seagate in the FAT32 format, and you can then copy the files to your PC. Hope this helps.
Feb 25, 2009 | Seagate Free Agent Go Small 12 GB USB...
Seagate FreeAgent  Go 250 GB USB 2.0 Hard Drive Logo
87 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
terminalcon
John Anderson
John Anderson
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
