Question about Panasonic Televison & Video
Picture on my panasonic 42 inch has just shifted left. HD Movies
Movies as fine. meun setting does work trying to shift it to the right. Help.
  • 77 Answers
SOURCE: blue snowy pixel areas on my plasma
some of these panels were mis-calibrated from the factory after not aging long enough. Let the TV run for atleast 2 hours and adjust the Vs and Vscan voltages. When it is blue in the left I have found generally the Vs is about 10 volts too high.
Posted on Jun 25, 2007
SOURCE: Picture has shifted to the left
This is a known problem. Panasonic sells a jig to correct it. I had the same problem and bought the jig for about $25. It plugs into a special port in the back of the tv behind a little door. You can read all about it here: http://www.avsforum.com/avs-vb/showthread.php?t=534816
Posted on Sep 07, 2007
SOURCE: Image has shifted to the left
Go to this thread - the instructions posted work.
You just need to buy the JIG to upgrade your firmware.
http://www.avsforum.com/avs-vb/showthread.php?t=534816&page=6
Posted on Feb 07, 2008
  • 109 Answers
SOURCE: Help with Panasonic plasma TV's display shift
you have an issue with the digital or main control board, and if the unit is still under warranty the manufacturer will help locate someone nearby. (actually even if out of warranty it's still a good idea to use that service co. for the simple fact they have more exeperience with the tv's
Posted on Mar 31, 2008
SOURCE: LG 42PC3D plasma television -- screen split down the middle
Our 42" LG picture is also split down the middle. It doesn't matter if it is cable or a DVD. I would love to know if anyone has found out the solution to this prob. The TV is only 3 years old...
Posted on Aug 12, 2008
Screen Shift PLZ HELP
burn in run  a white screen
Jun 06, 2009 | Philips 42PF7421D 32 in. LCD HDTV
Philips 32pt television screen format off center, to the left
For me it was the cable box settings...
I'm not a tech person, so take this for what its worth. I had the same problem with my Vizio and my Time Warner Cable HD/DVR box using the HDMI cord connection. HD channels were always fine, and non HD channels were fine until I went to an HD channel and back. When switching back, the non-HD channels would be shifted to the left as you describe. After much back and forth with both Vizio and Time Warner (each saying its caused by the other), I stumbled across the following fix...
I went into the cable box (scientific atlanta 8300) "settings", under "display," under "output resolution." There was a list including 480i, 480p, 720p, 1080i, and "auto select." I unchecked both 480 options and left 720 and 1080 checked. Problem solved. The other "Display" menu settings are as follows: Picture Size = Stretch, Aspect Ratio = 16x9.
Hope this helps.
Mar 27, 2008 | InFocus SC-MANGRY-106H MANUAL PULL DOWN
Picture shifts to left
I had the offset left issue for non-HD channels with my Panasonic 42" plasma, using Comcast HD cable box. Went into the configuration menu (to get there with the newer Comcast boxes, you have to turn the box off, then hit the menu button on the box immediately after). You will see on the menu a resolution (probably says 1080i), then below it a "4:3 override". Our said 480i. When I changed it to "none", so that it stayed 1080i, it worked! It also works by selecting 480p, but then the picture is stretched.
Mar 13, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Samsung hpr4252x perfect picture in
You have a burn in problem from watching widescreen movies.If you have access to a signal generator or tv setup disc run a perfectly white screen on the plasma for about 30 min.This should help even out the pixels on the display.
Mar 05, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
1080p Prob with TH-50PE700U
try diffrent hdmi cable, sometimes with this new digital stuff there are compatibility issues, not common, but not unheard of
Feb 20, 2008 | Panasonic (TH-50PZ700U) Television
Shifted Picture
Yes. This problem comes about by actually pressing the center ring accidentally during normal viewing. Just press and hold the left or right side of the ring until the pciture straightens itself out again (if the black portion of the screen is to the right of the picture, press the right ring; if it is to the left side, press the left ring).
-Tha Mp3 Doctor
Feb 04, 2008 | Philips 51PW9363 51" Rear Projection...
You need to contact a technician who has the software jig to fix your problem.....The part number is TNPX25JIG and is no longer
available...........Good Luck.
Jan 25, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Aug 15, 2007 | Panasonic TH-42PD25U/P 42 in. Plasma EDTV
Picture is shifted 6 inches to the left
try moving the image with the adjustments.... wont work? change the 100uf 200volt filter just ahead of the flyback.
Feb 04, 2006 | Panasonic TH-37PX50U 37 in. HD-Ready...
Televison & Video Logo
61 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
