Question about Peg Perego John Deere Gator HPX
Gap spacing for 3 cyclinder diesl john deere gator
Gap spacing for the valves for 3 cyclinder diesl john deere gator engine
Model 3007d003 yr 2004
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Wrong forum
Posted on Jun 08, 2012
momsjustknow
  • 135 Answers
SOURCE: peg perego john deere gator 4x2
Here are the printable instructions from the Perego website.
http://www.pegperego.com/pegcatalogue/toys/downloads/Gator_Work_FIUS0301G24.pdf
From what I can tell, there are levers on both sides of the grill that you press to flip the grill down to the ground. You can then get to the battery to pull it out and charge it.
Hope this helps!
Good Luck! from Moms Just Know
Posted on Nov 03, 2008
  • 60 Answers
SOURCE: old john deere gator and battery new charger still will not move
Could be several things.  Your battery could be bad. After not being charged for a while, they do go bad- often. You may want to try a new battery along with your new charger.  You could also have a switch /connection problem. If you get a new battery and it still doesnt work, you may want to check the switches and wiring. It is not uncommon for the switch to go bad especially if it had been stored outside.
Posted on Mar 11, 2009
mikeramesar
  • 37 Answers
SOURCE: cannot find out how to get to the battery for a
Where the front bully bar is, there is an indent in the middle , enough for your phillips head screw driver to get into, you must undo that screw and there will be a tab on either side of that panel to pull and the front bummer assembly will hinge out towards you, you can then unplug the battery and connect your charger..
Good luck!!
Posted on Dec 27, 2009
  • 156 Answers
SOURCE: help for my childs John Deer Gator
the peg perego gators have two switches in the shifter that need replaced.
I have replaced them before on my grandkid's gator.
Here is the website I get my parts from
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html
You can also call them direct at 1.801.655.0800.
They seem to always know which part I need and I have always been very happy with their service.
Hope this helps
Posted on Mar 18, 2010
  • 19 Answers
SOURCE: john deere gator 1999 4x6 overheating.replaced
bleed air out of cooling system contact dealer for instructoins
Posted on Aug 17, 2010
Starter Wiring diagram for a 2004 John Deere gator MODEL CS
Request the diagram directly from John Deere.
Nov 05, 2016 | John Deere Garden
Is there a hand brake adjustment on a 855D
John Deere Gator XUV 4x4 855D adjusting handbrake ...
www.fixya.com/.../adjusting_handbrake/.../john_deere/gator_xuv_4x4_85...
John Deere Gator XUV 4x4 855D atvs adjusting handbrake unsolved issues. Ask your John Deere Gator XUV 4x4 855D questions. Get free help from atv ...
  1. John Deere Brake Adjustment‎
    Adfixya.com/John+Deere+Brake+Adjustment‎Troubleshooting Tips
  2. Free Manuals
  3. Instant Solutions
  4. Instant Answers
  5. John Deere Brake Adjustment‎
Jan 17, 2016 | John Deere 2012 Gator XUV 4x4 855D
Need to know where the fuse is for the fuel pump for my 625i to fix my fuel pump
Troubleshooting - Operator's Manual - John Deere
manuals.deere.com/cceomview/OMM136969.../OMM136969_L013.htm...
Fuel shut-off valve turned off (if equipped). · No fuel or ... Open-circuit in wiring. Engine is hard to ... Fuel pump output not adjusted to specification. · Improper fuel ...images for john deere 625i wiringimages for john deere 625i wiring
Dec 05, 2015 | Peg Perego John Deere Gator HPX Ride on...
John deere tractor 1070 will not start not getting fuel to only 3 cyclinders has 4 cyclinders fuel tank full have changed fuel filter bleed the lines fuel gage is not working but was working before
The lookup at:
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
for the model 1070 harvester shows it is a 3 cylinder unit.
What I might recommend is pull off the valve cover and make sure the intake valve is moving up and down as the engine is cranking. (dont get cut up)
It sounds like a pushrod may have fallen out.
good luck.
Joe
Feb 10, 2011 | John Deere Garden
John Deere 445. I would like someone who knows about this tractor answer the question as to why after replacing the camshaft why the motor backfires through the carb. If you read through all of my...
Of the 100+ camshaft replacements that I personly have done on the 425/445 and John Deere Gators I have come across 3 that backfired when completing the replacement.2 were do to bent valves coming in contact with the piston after gear failed and 1 was from a sheared flywheel key.The only other time I had this same injected engine backfire was on a John Deere gator 620i that had a faulty computer and fired @ 90 derees off.Do a compresion check and that will help out alot.
Aug 06, 2010 | John Deere Garden
Peg Perego John Deere Gator HPX Logo
240 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
