Question about HP Mini 1000 Netbook
My HP Mini won't reboot.
I tried to turn on my netbook but all I got was information telling me to "Reboot and Select proper Boot device or Insert Boot Media in selected Boot device and press a key" but I can only select one boot device. However, this device doesn't seem to be working, because I just continue to get the same screen. It's "Network: Atheros Boot Agent" and it's the only one listed. I don't have CD drive either and I'm in Thailand. I'm only a 16 year old girl on exchange and I have no clue what to do. It won't reboot so I can't see anything on my computer. There's no start menu or anything so I can't even use it. I'm freaking out and I'm scared that I broke it, but I can't ask anyone for help here because they can't understand a word I'm saying.
  • 4 more comments
  • alohacorniuk Sep 06, 2009
    Okay, so I got to the BIOS setup, but I didn't see what you're telling I need. The main tabs are: Main. Security. System Configuration. Diagnostics. Exit. I don't know how to check if the Hard Disk is detected, but under Diagnostics I see this: "Primary Hard Disk Self Test Not Support" so I don't know if that means it's loose or not.
    Main Tab:
    System Time [14:12:55]
    System Date [Sun 09/06/2009]
    Notebook Model : HP Mini 110-1000
    Product Number : VA723UA#ABA
    System Board ID : 308F
    Processor Type :
    Intel(R) Atom (TM) CPU N270 @ 1.60GHz
    Prcessor Speed : 1600MHz
    Total Memory : 1024MB
    BIOS Version : F.05
    KBC Version : 02.09
    Serial Number : CNU9213PFN
    UUID Number :
    338053FE29A9586287C863E653BC9BAE
    Product Configuration ID:
    03A8100000000000100300000
    Diagnostic Log
    Mine says Change Boot Device Order, but I'm guessing it's the same thing. So, then I get a little window that says "Please select boot device:" The only thing listed there is "Network:Atheros Boot Agent."
    So, if I just go into a computer place, they'll be able to fix it? Does it take long?
    Sergeant:
  • 280 Answers
The hard disk cable seems to have got loose. Get into BIOS setup and check if the hard disk is detected. To do this, look for a hint in the first screen that appears with the HP logo. Mostly it will be F2. Hit it before the screen goes off. The main screen will show the devices attached to your laptop. Check if the hard disk is detected(see against the text named Primary Master). If yes, go to Boot tab. Under it see for Boot device priority and select that. Under it make sure your Hard disk is set as the first option.
Reply back with your observations
Posted on Sep 06, 2009
Testimonial: "Awesome! Great advice and figured out what was wrong in a heart beat. Definitely calmed me down by letting me know that my problem is an easy fix. :D"
  • 3 more comments
  • Amruth Louis Sep 06, 2009
    Guess the Hard disk cable is really loose. Can you list me whatever you see in the main tab?
    Sorry, just cross checked with my notebook. Hard Disk is never listed. Can you do me one more favour? When you get the HP screen, tap F9 (this has to correspond with 'Select Boot device'). Check if something called 'Notebook Hard Drive' appears in the list.
    Okay. Your Hard disk cable is loose for sure. You can get it fixed at a HP service centre. Or any other service centre as it is just the cable.
    Yes. Even if you cant explain them, it shouldn't be a problem. Once the switch it on, they'll know. And it doesn't take much time. They'll open the back casing/panel that covers the hard disk, and reconnect the cable. As simple as that. If you're bold enough to take the risk and handle it carefully, you can do it yourself. Else get a professional hand. Please do rate if I was helpful. Have a good day.
    Always here to help :)
  • 37 Answers
You will have to access your computers bios im afraid and look for usb legacy device and reboot from there its not an easy thing to do,then set usb as primary boot device it should work
I had the same problem. I could use the Pro IV PATA ZIF RunCore SSD via the USB enclosure, but I could not use it as the internal drive, as the BIOS would not recognize it.
Notice that the correct orientation of the ZIF ribbon cable is such that the SSD faces down inside the HP computer. Whatever orientation you use when inserting the ribbon cable into the SSD (contacts facing you or facing down), you must use the opposite orientation when connecting the other end of the ribbon cable to the inside of your computer.
I did this, but the BIOS didn't recognize my drive... UNTIL I tried again with the opposite cable orientation from the one I was trying. It appears that the contacts MUST face down on the connection inside the HP Mini, but can face either way when connecting the other end of the cable to the RunCore SSD. After I changed this orientation, the BIOS recognized the RunCore drive and the computer now boots fine.
Posted on Feb 11, 2010
Im sorry i dont have a soulition but im 10 and mine is doing the same thing i dont get it what do i do!!!!!!!!!!
Posted on Nov 08, 2010
  • 3 Answers
PIck your ****. thewn say AMAZING! it will work
Posted on Mar 21, 2010
WHEN I TURN MY NETBOOK ON IT SAYS " REBOOT AND
If you have a CD or DVD in the internal drive, remove it and reboot. If the system does not have a drive then you may be experiencing HD Failure and the system will not identify its main hard drive to boot from.
Feb 28, 2011 | Computers & Internet
Reboot and select proper boot device or insert boot media in selected boot device and press a key message coming upon my hp mini 110
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to ......,press escape then press f10 to save to cmos to restart
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
?????????????????? hope this helps
Dec 27, 2010 | HP Mini 1000 Netbook
My hp mini is showing Reboot and select proper boot device or insert boot media in selected boot device and press a key
Insert a Bootable Opearating system CD
Reload Your Operating System if Problem persist change your hard disk
Load the Operating System
Dec 21, 2010 | HP Mini 1000 Netbook
I cant fix my mini laptop it is tell me to select proper boot device or insert boot media in selected boot device and press a key I have try this and it don't work
Verify BIOS settings and see if the harddrive is listed. If it's not then the harddrive maybe bad. Or, insert the set-up disk in the CD driver to see if it will boot that.
Oct 28, 2010 | HP Mini 1000 Netbook
Hp mini 110 started with a hp symble and f9=change boot device order f10 bios setup options. after a few minites screan said reboot and select proper boot device or insert boot mediain selected boot...
The hard drive is not being recognized as a bootable device- you will need to reinstall windows or replace the hard drive in order to resolve this issue
Oct 02, 2010 | HP Mini 110-1037NR Netbook
its basically telling you that your master hard drive with O/S installation cannot be found in the booting system...Check if your master HD is not corrupted and see if your O/S still exist or maybe wiped out..
Mar 31, 2010 | Computers & Internet
I have an HP 110 Mini I tried to turn on my netbook but all I get is information telling me to "Reboot and Select proper Boot device or Insert Boot Media in selected Boot device and press a key" but I can...
either your hard drive has been damaged or it has been disabled by the bios. Your netbook probably has a solid state hard drive. You need to get your information removed from the drive at this point and get the operating system of your choice installed. For further assistance, you can call us 24/7 at 800-595-3564.
Jan 18, 2010 | HP Mini 1000 Netbook
I have a hp mini netbook and when i turned it on it started to tick. it was the speakers it was ticking from then bottom. and it gives the hp start screen (blue logo that says HP) then it goes black and it...
Sounds like the hard drive went bad, hard drives will click away when the platters are touching each other.
Take the hard drive out and see if the clicking is still there, if it is the motherboard at that point cause the sound is built onto the motherboard.
If the clicks go away after taking out the hard drive then you know the hard drive is definitely bad.
Dec 01, 2009 | HP Computers & Internet
My HP mini shows the "Reoot or select proper boot device or Insert Boot Media in selected Boot device and a press a key" listing. I hit Control/Alt/DEL and get the F9 and F10 options. I have not been able...
select drive "c" as boot device, reboot and if it doesn't boot, then the hdd may be corrupt. if you can get to the hdd recovery setting, use this to reboot to factory spec.
Oct 11, 2009 | HP Mini 1035NR Notebook
HP Mini 1000 Netbook Logo
12,225 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
