Question about RCA RCR450 Remote Control
Remote for converter box will not adjust volume or turn off TV
All of a sudden it stopped adjusting volume. It will turn the converter box off and it will turn off TV but the TV will instanly come back on. Help please. Debbie
  • 3 Answers
SOURCE: Need a smart antenna to go with the Digital TV converter box
First, you don't need a Smart Antenna, the manual is simply stating that your converter will use one if you have it. Any standard antenna will work, so there is no need for a coupon to pay for a new one, whether indoor or outdoor depending on your location and distance from each channel transmission tower. Since you don't give details of what antenna you are using, I will assume you have rabbit ears for each converter. Rabbit ears are notorious for poor reception and any metal or persons nearby will change the reception quality. I would recommend a roof mounted external antenna with splitters for the 3 converters if you have the option. If not, use an amplified internal antenna and mount it closest to the channel towers you will watch most and as high as possible. If you can find a smart antenna, which is an amplified indoor/outdoor antenna with a control cable for changing the direction of reception, for a decent price, you can use that but keep in mind that to use the control feature you will need one for each converter. Also, check antennaweb.org for information on digital channels in your area and their direction and distance. Antennaweb.org will also tell you if any digital channel in your area uses VHF frequencies. If they don't then a UHF only antenna will work fine.
Posted on Feb 18, 2009
  • 814 Answers
SOURCE: converter box code for my rca universal remote
On the web page link below you will find the RCA Customer Support website page with all the service information for your model RCA 3 device universal remote control model number RCR311S. On this page is a pdf copy of the owners manual. You will need a pdf reader and writer to read the owners manual and a writer to make a copy for your own use.The information you are looking for is on pages 4-12 in the owners manual. I hope this information solves your problem of finding a copy of the remote control owners manual. Thank you for using FixYa and have a nice day! /RcaaccessoriesProductDetail.do?ACTION_TYPE_ID=ACTION_TYPE_PRODUCT_DETAIL&http://www.rcaaccessories.com/rcaaccessoriesACTION_CATEGORY_IDSTR_CATEGORY_UNIVERSAL_REMOTES&ACTION_PRODUCT_ID=RCR311S
Posted on Jun 21, 2009
  • 1218 Answers
SOURCE: Programming RCA converter box remote control with Phil/Mag TV---
Good day,
You should have the instruction guide. If not look below. It's there but look closely for the guide itself and how to increase it's size to readable.
Check on the back of the TV to see if there is a 3 and 4 setting, If so, set to 3.
With nothing connected to the tv, and using the tv's remote, scan for channels. It should come up with only channel 3.
Then using the remote with advanced options, set the the input to either antenna or auto.
Connect the antenna cable to input on the converter box. Using the supplied cable connect the output from the converter box to
the TV. Turn the TV on first, followed by the converter box.
Then follow the instructions.
Not really easy so you'll have to fight your way thru it.
Finding the right setting for the antenna will probably take the most time, requiring a station scan after each adjustment.
http://dtvconverterboxes.blogspot.com/2009/05/rca-dta800b1-owners-manual.html
Posted on Dec 28, 2009
  • 8457 Answers
SOURCE: Hello, the remote has quit working for the volume
Ur free air DTV converter box have problem taking in the programs codes belong to ur tv,belong to the remote.Turn the converter box off/on to reboot ur DTV converter box.Read ur owner manual,re enter ur tv codes,belong to ur tv.U tv should be up and running again.
Posted on Jul 31, 2010
supernova278
  • 1932 Answers
SOURCE: I need codes for a SONY TV for the RCA converter
To Get The Code Please Go To Below Website:
http://www.rcaaccessories.com/remotefinder/
You need to select the following information from the drop down list
1.Model of the remote
2.Type of device to which you want to program(TV/DVD/VCR)
Thank you
Posted on Aug 02, 2010
I have an RCA TV converter box, model DTA800B1. I don't have the box or instructions, I am attempting to conneect it to an RCA TV with a built-in DVD player. I would appreciate the code that the TV...
There are a lot of possible RCA TV codes programmed into the DTA800B1 remote.
Try the following three digit codes: RCA 000, 001, 005, 072, 073, 074, 075, 076, 077, 078, 135,
138, 140, 144, 150, 156, 159, 162, 163, 169, 171, 178, 229, 246, 249, 260, 274, 275, 293, 302 in order.
To program the remote. Turn on your TV manually and press PGM (to the left of the zero in the number pad section). The LED should light and stay lit. Type in the first 3 digit code and press OK (in the center of the arrow keys near the top). See if the gray volume up/down keys work to change the volume. If it doesn't work press PGM again and enter the next code.
Note that the converter box remote will only turn on and off, switch the input from Channel 3 or 4 to AV in, adjust the volume and mute the TV. It will not control any of the DVD functions. Your original TV remote will not control the converter box.
The manual for the DTA800B1 is available here: http://www.1800customersupport.com/productdocuments/DTA800B1_RCA.pdf .
I hope this helps.
(who has the DTA800A which is the model without the analog pass-through.)
Sep 17, 2011 | RCA Televison & Video
I have a Sony KDF-55WF655. I think the IR sensor is going bad. My remote occasionally stops working for no reason. I have tried numerous different remotes, but I get the same problem no matter which...
Hi:
The IR receiver inside the television is becoming intermittent and needs to be replaced. You might also check the connections on the receiver small circuit board for cold or loose solder joints.
Sep 09, 2011 | Sony Grand WEGA KDF-55WF655 36" Rear...
Jul 31, 2010 | RCA Televison & Video
Hooked up converter box and stations are all working but sound is coming out a hissing.
Use the volume control on the remote for the converter box to raise the sound level. Adjust the TV volume with the converter box turned all the way up then reduce to normal listening level with the converter box remote.
Jul 29, 2009 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
I bought the magnavox and all my channels are
Check the converter box. Many have a volume setting that is usually set very low at the factory. On the remote control for the converter check to see if there are volume buttons. If so, change the converter box volume higher, to a level that makes the TV audio level "normal", then use the volume control on the TV for adjustment as you watch. If you set the volume on the converter box too high, you may get some distortion in the audio from your TV. So adjust the converter box to find the proper output from your TV without distortion.
Jun 20, 2009 | Insignia Digital-to-Analog Converter for...
WHY DOES THE VOLUME GO DOWN WHEN I USE CONVERTER BOX?
You will need to adjust the volume on the tv when using the box. The digital sound is different then the sound coming across on analog signal thus do not expect them to be at the same level. The box is not so dreaded, the picture quality is much better then what you get with analog.
Jun 10, 2009 | Insignia Digital-to-Analog Converter for...
Hissing sound from a Panasonic old TV...Sound and picture are OK. The hissing sound even continues when the MUTE on the Box is ON. The hissing only stops when the MUTE on the TV is ON. I am using the...
If you disconnect or power off the converter box does the hiss go away?
If you connect a VCR or DVD player does it still have the hiss? We
need to isolate what source is causing the hiss if it is from the set or
if it is from the converter box.
When you turn the volume control down on the set, does the hiss
reduce in level? If mute stops it, it should reduce in level as you
turn the volume down. Then turn up the sound level control on
the converter box whether its a manual control or by remote. If you
can get a combination that minimizes the hiss and gets higher sound
level from the programming that may cure it.
I am not familiar with the converter box you are using. Are you using
Audio/Video cables from it to the set or is it coming out with coaxial cable
and used on a channel? If you are using a very old set with a tuner input
perhaps the fine tuning is out of adjustment.
Feb 21, 2009 | Panasonic CT-20D11 20" TV
TV audio too low with converter box
leave the volume up on the tv to 50% - 80%, then adjust it from the volume on the box's remote control
Jan 09, 2009 | Televison & Video
Sharp Aquos 32"
TV is under warranty. Get a tech to look at it. It could require a new IR sensor, a firmware upgrade or a system reset that only a tech can do called an Industry Initialization that is in the service mode only
Jun 24, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Bought 2 DTT-9900 converter boxes and hooked them to 2 TV's, get signals after playing around with antenna. but after using both TV's to play a dvd (dvd player hook to TV) The sound went down to almost...
Try turning off the converter box when using the DVD player. The zenith have a second sound control on the converter box remote thus you may have to adjust the sound on the tv remote because you are using the dvr. I set the zenith sound level at the highest level and use on the tv remote only to adjust sound. This eliminated a hiss that the sound control on the converter box was causing.
Apr 28, 2008 | Zenith ZN110 Remote Control
RCA RCR450 Remote Control Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
