Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Evaporator fan noise. How do I access the evaporator fan motor to replace it?
  • Kenmore Master
  • 3,361 Answers
Turn off the refrigerator. Remove the freezer shelving and bins. Remove the screws holding the rear panel inside the freezer. Repair or replace the fan motor.
You may also have to remove bin supports from the side wall to get the panel out depending upon your model. The model number posted is incomplete.
Posted on Sep 06, 2009
Testimonial: "Exactly what I needed to know. Thanks"
REFRIGERATOR AND FREEZER NOT GETTING COLD. ERROR CODE 5Y.MODEL NUMBER LGUS2642LF2 SERIAL NUMBER 4A23305873
That error code is "SY" and not "5Y" and it is for the evaporator sensor error. You will need to replace the sensor.Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Access the evaporator assembly cover in the rear of the freezer section. In convertible units that can function either as refrigerators or freezers, and is located toward the bottom of the unit on the inner back wall -- if necessary, remove the two lower glass shelves and the crisper compartments.
Remove the screws securing the evaporator cover to the freezer wall, using a Phillips screwdriver.
Pull the evaporator cover away from the wall just enough to access the electrical connection behind the cover. Be careful not to damage the gaskets on either side of the evaporator cover. Reach behind the cover and disconnect the electrical connection from its wiring harness. Remove the evaporator cover from the freezer.
Remove the wires inside the exposed evaporator assembly from their retaining clips, then squeeze the quick-connect mechanism to detach the wires from the fan motor.
Remove the two hex-head screws that hold the fan motor mounting bracket to the back wall of the unit, using a 5/16-inch socket or nut driver.
Remove the two hex-head screws holding the fan motor to the mounting bracket, using the 5/16-inch socket or nut driver, then pull the fan blade off the motor shaft.
Examine the fan to make sure the blades are not damaged; if necessary, replace the fan itself as well as the motor. Slide the fan onto the motor shaft.
Attach the new motor to the mounting bracket, using the 5/16-inch socket or nut driver to secure the two hex-head screws.
Replace and tighten the two hex-head screws that hold the fan motor mounting bracket to the back wall of the unit, using the 5/16-inch socket or nut driver.
Reattach the the fan motor wires by clipping them back into the quick-connect mechanism, and set the wires back into their retaining clips in the same manner as they were attached.
Set the evaporator assembly cover back into place, then reach behind and connect the electrical connection into the wiring harness.
Secure the Phillips screws that hold the evaporator cover to the freezer wall.
Replace the shelves and crisper compartments if they were removed, then plug the refrigerator into its power source and verify proper operation.
Regards,
Richard Roth
http://appliancecafe.com
Nov 07, 2012 | Frigidaire Refrigerators
Whirlpool fridge quit cooling
when you adjust the tempreture dial for the refrigerator this would turn on the evaporator fan motor located behind the rear wall of the freezer click this link http://c.searspartsdirect.com/lis_png/PLDM/00052094-00007.png part number 17 on the schematic would be the panel that you would remove when you remove this panel this would give you access to the evaporator coil as well as the evaporator fan motor if the fan is not spinning then you would replace the evaporator fan motor. If you see any ice build up on the evaporator coil or the fan motor or blocking the drain located under the evaporator coil this is termed as a defrost issue. If you find this then message me back and I will give further instruction on how to diagnose why your unit is haveing a defrost issue. The freezer is the only area that produces cold in a refrigerator. The evaporator fan motor blows the cold air through a small damper door that opens and closes depending on the tempreture inside the refrigerator. The first thing to check is the fan motor that is behind the panel that I mentioned. If you remove the panel and find that the fan is blowing and spinning message me back for further diagnosis. I await your reply Thank you
Rick
P.s what is the tempreture inside the freezer currently?
Oct 23, 2011 | Refrigerators
Motor in wine frige is noisy???why
That motor is an evaporator fan motor. That noise occurs when the bushes in the motor start to wear. The motor is not in effect repairable but has to be replaced. Normally a 9 watt evaporator fan motor is installed into those wine coolers.
Aug 31, 2010 | Haier BC112G Wine Cooler
NEW HIGH SPEED EVAPORATOR FAN MOTOR TOO LOUD Repair technician told me there were problems with the original evaporator motor and replaced it with a new high speed one. Now the fridge is too loud. Before...
It's the rotors making the noise not the motors! I replaced the motor, still made noise, I took off rotor blade sanded it down around each blade, no more high pitched hum!
Jan 12, 2010 | Frigidaire FRS26H5AS Side by Side...
When I turn the unit on it doesn't blow out any air it just makes a low humming noise.
The evaporator fan motor is defective. Check if the motor can be turned manually and spins freely. Otherwise the rotor is stuck. Check and lubricate bushings/bearings.Check the fan capacitor. If all of the above is ok, replace evaporator fan motor.
Sep 07, 2009 | Maytag M6X08F2ACOM Air Conditioner
Evaporator Fan Motor noise is excessive for this refrigerator. GE Profile CustomStyle Model PTI22SFMARBS Serial# SF900146V
Despite my urge to vent about GE refrigerators, I'll keep this short.
If you have a constant squealing noise from the evaporator fan in the freezer, there's a good chance the fan just has failing bearings, and replacing the evaporator fan might solve the problem.
But if the noise is intermittent; quiet sometimes but sometimes buzzing loudly, then my bet is there's nothing wrong with your evaporator fan. It's a problem with the design of GE fridges: They don't defrost completely. So ice builds up on the back freezer wall, etc., and on and around the evaporator fan. That's not a problem when the fan is in "low speed mode". But open the door, get the fridge warm, and the fan kicks into "high speed mode". That's when the noise will start, as the fan blades and assembly warps under speed to hit ice and start vibrating.
Acid test is this: While the noise is occurring, turn the fridge temp (not freezer) control up as high as you can without turning off the fridge. That will make the fan shift into low speed. If the noise stops, you got ice on the fan, my friend.
In that case, unplug the fridge, and get a hair dryer and blow warm air into and onto the evaporator fan area. Maybe gently whack the fan area with your hand a bit, to knock the ice off. Once you get all the ice off, turn it back on. If it runs on high, without any noise, the problem is fixed ... until the next set of high humidity days. I plan to post a video about this, once I get it edited to remove the expletives. ;-)
GE will sell you a "moisture kit" for $340, which may fix the problem, but only if your fridge is out of warranty.
If your fridge is still under warranty, GE will tell you there's nothing wrong and that maybe you just need ear plugs.
Nov 18, 2008 | Refrigerators
Whinning noise
Evaporator fan motor is located in the freezer compartment behind the back wall. To access it you must remove the shelves and the back wall which is held in place by screws. Then you can remove the old fan motor and install a new one in the reverse order that you used to remove the old motor.
Mar 12, 2008 | Hotpoint HSS25GFP Side by Side...
Noise in my refrigerator
Replace the evaporator fan motor that will solve the problem
Nov 29, 2007 | Hotpoint HSS25GFP Side by Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
182 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
