Question about Cycling
Stuck in low gear
I have a mountain drive that was off the road for three months pending a frame replacement. It appeared to reinstall fine but it's stuck in the low ratio. The changing buttons pop in and out fine and will press in further beyond the in position as per the instructions.
Has anyone come across this and is there and easy solution?
Thank you.
Manufacturer replied to email so awaiting definative instructions.
Posted on Sep 07, 2009
Will not release from park when started
This is the gear shift interlock,There is a possible recall with this mechanism.That is pending. Its called the roll away vehicle. #EA09013.
Mar 17, 2012 | 2004 Mercury Mountaineer
Tip
Mountain Bikes Vs Road Bikes.Mountain bikes have become very sought after and...
Mountain Bikes Vs Road Bikes.Mountain bikes have become very sought after and furthermore are usually readily available. A majority of these bicycles will often be a lot more comfy in comparison to road bikes due to the fact that you ride with a considerably more erect posture. They are simply devised for going off the beaten street paths and into places like the rugged slopes as well as mountain tops. If one thinks about it, this is exactly how their name was derived. Fortunately they are usually larger than road bicycles, due to the fact mountain bicycles have to withstand the excessive abuse relating to traveling on difficult, bumpy paths. A lot of them include additional features for example shock absorbers, wide tires, in addition to straight handlebars. You will find there's a suspension system that produces a comfortable drive, along with the heavy, wide tires are generally more unlikely to slip in comparison to the slimmer wheels of the road bicycle. Specialized knobby tires intended for outstanding grip and also a complete suspension are crucial aspects of the design related to mountain bikes. The actual bikes will be meant for difficult and also tough landscapes. The bicycles are engineered to fulfill their unique intent as long lasting off road sports gear. The specific bicycle created for downhill biking is actually extremely well put together and will have the ability to endure high-speed driving on pathways customized courses. These kinds of styles of bikes have got to be continuously transforming as new technologies and material come into play. <br /><br />Road bikes are produced with a particular style with regards to speedy, lengthy traveling times. The particular frame within the bike is probably the most important element. A very important characteristic in terms of a road bike tend to be how heavy it is in addition to stiffness which decides where the actual energy from your pedal strokes is to be sent. Basically these two elements have a direct impact on how much power is being delivered to the bike chain and therefore the actual wheels. Due to this quality, racing bicycles must sacrifice ease and comfort to get top acceleration. Drop or declining handle bars tend to be positioned beneath the seat level to be able to position the operator in a much more streamlined and sleek posture. The exact driving positioning is actually trying to combat the wind resistant by having he rider be curled on the dropped handle bars. Both sets of tires are generally in close proximity to guarantee the bicycle presents quick and easy handling. In summary, road bicycles are perfect for a lot of types of riding however they tend to be dangerous on rocks as well as other non paved surfaces.
on Dec 21, 2010 | Cycling
Low gear appears to be slipping.have to hold gas to bottom to slowly take off.it will then change great and reverse works fine.
The clutch pack in the trans is very worn and needs replacement. Going to a transmission shop will determine these findings we are talking about
Dec 26, 2010 | 1997 Mercury Mountaineer
I have 99 deville,about a month ago it started missing and backfiring,it starts good and runs fine in park,as soon as u put it gear and give it some gas it chugs and misses.ive had hooked up to three...
Firstly, It might be an Idea, only, that you could change the O2 Sensor...Only an idea right now.
You could also have a look at this site I found..
http://www.audizine.com/forum/showthread.php/391877-P0300-Multiple-misfire-P1128-Upstream-Heated-o2-sensor-swapped-(Pending)
I had similar problems with my Jag Xk8, also could not be fixed....Had all sensor's change and is still working fine...
Hope this helps..
Oct 22, 2010 | 1999 Cadillac DeVille
I smell gas coming from my mercury mountaineer? What's the prob?
This car you are driving is 20 years old. Have you thought of getting a newer model? It sounds like you are having too many problems.
Jul 05, 2017 | 1997 Mercury Mountaineer
My 2003 Mercury Mountaineer Gear Shift is stuck.
THERE IS A SENSOR ON THE BRAKE PEDAL THAT RELEASES THE THE SHIFTER.THERE A 3 COMPONENTS INVOLVED.U CAN PUT IT IN NEUTRAL BEFORE U START THE CAR.THEN WIL SHIFT.
May 01, 2009 | 2004 Mercury Mountaineer
98 Jeep Grand Cherokee Stuck in 1st gear!
I would drop the trans pan and change fluid & filter. If you find an extreme amount of debris in pan, filter may have become partially plugged, which can lower internal pressure. Only problem is that if there is enough debris to plug up filter, it indicates wear inside unit, which a fluid change will not correct (no chemical will) But, if problem becomes somewhat better after oil change, an additive such as Lucas conditioner may prolong useful life somewhat.Otherwise, have unit rebuilt.
good luck
Mar 04, 2009 | 1998 Jeep Grand Cherokee
1998 Mercury Mountaineer Transmission issues..
sounds like servo/solenoid problems for those gears run the fault codes or have it inspected and properly diagnosed by an accredited transmission specialist shop
it is running with no reported noises or other problems so at this point it will not need a new transmission
Jun 26, 2017 | 1998 Mercury Mountaineer
2000 audi a4 low erratic humming noise
Could be a transmission issue. Did you hit any objects while driving ? Have you performed a visual inspection under your vehicle ? Have you checked to see if you have any loose vacuum hoses ? Any codes in your engine control module or transmission control module ?
Jun 22, 2017 | 2006 Audi A4
Cycling Logo
32 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
