Question about Kitchen Ranges
Westinghouse self cleaning oven manual or owners manual
We have a White Westinghouse self cleaning oven stove and I wanted to clean it and I can't find my manual.....
  • 4 more comments
  • Anonymous Dec 18, 2007
    I have turned both nobs to CLEAN. The door pulls tight but the cleaning does not start. Neither does the LOCKED light come on. I have never used the clean cycle and I do not have a manual. Bought stove from neighbor who was moving. They had only had stove a short time, in their beach house.
  • London Lisa Nov 30, 2008
    I have a similar issue..except for some reason the control panel stoped working..we checked the fuses and they are all fine. the clock no longer works and none of the control buttons work. I really do not want to have to 'self' clean the oven!! Does anyone know how to it manually?? ..lol and no manual..it came with the house.
  • tinawells1 Dec 25, 2008
    White westinghouse self cleaning oven is not working. Timer is working. Set start timer same as clock and but end timer for three hours later. Never heard the button pop out. Stove is locked but no lights are coming on and I have both knobs turned to cleaning.
  • Anonymous Jan 11, 2009
    I have a self-clean oven, I have set the oven lock, set time to 3 hours for a big job. I am getting no heat.
    lynn
  • ulrichvaness Jan 21, 2009
    I have a white westington house oven seems like a bit older type smooth top cream and black color 8 buttons no thing on the knobs that look like a padlock and dont know what the model number is ...ne ideas how i can get it to self clean ?
  • Anonymous Mar 27, 2014
    Self cleaning oven
Many White-Westinghouse manuals can be found here: http://www.frigidaire.com/support/manuals.asp I had the same problem and was able to solve it. They didn't have the exact manual for mine (a KF450G), but they had one that was similar enough (KF580H) to solve this issue. Setting the knobs to clean is only part of the process, to get it to run you need to set the timer. Read the key information below transcribed from the manual: --- To set the controls for the cleaning cycle: 1) Close the oven door. 2) Be sure the clock shows the correct time of day. 3) Be sure the Start Time knob is set for the same time as the clock. If not, turn the knob to the time on the clock. The knob will then pop out. 4) Push in and set the Stop Time knob for 2 to 3 hours past the Start Time. Example: If the Start Time and Clock read 1:00, set the Stop Time for 3:00 or 4:00. 5) Turn the Temperature Control to CLEAN. 6) Turn the Selector to CLEAN. If all controls are set correctly, the oven signal light will come on and stay on until the oven reaches its cleaning temperature. It will then cycle on and off. --- There is more information in the manual, but it's much too much information to manually transcribe - I've only typed enough for you to get it working. Note that the LOCKED light won't light initially, it only lights once the oven exceeds 550 degrees. Once that light is on, the oven will not reopen until the temperature drops below that point, even if you stop the clean cycle. Be sure to empty out the storage drawer under the oven before cleaning.
Posted on Feb 08, 2008
For the 8 button control ovens, white-westinghouse
turn both knobs to the lock setting (it looks like a padlock)
select the timer button (a clock with a line under it)
Increase the timer to 3 hours for heavy cleaning, 1 hour for light cleaning.
Then press start, (looks like a man running)
After cleaning let the oven cool down for 45 minutes
Hope this helps!
Posted on May 12, 2008
  • Nancy
    Nancy Dec 26, 2013
    Thank you sooooo much!! It makes near an hour I'm looking for this :-)
  • awsehme Jan 17, 2018
    ?? thank you sooo much
We have an older self cleaning model the temp turn up to only 350% and we cant set the actual cooking time ...solutions?ThanksP&N
Posted on Aug 28, 2009
I have the same problem and I read on another site that it has something to do with the timer. So, I set the timer for an hour, set the teperature knob to clean and the Selector knob to clean and it made a noise, locked the door and the oven light came on - we'll see if it works!
Posted on Dec 11, 2007
  • Jan Benjamin Dec 11, 2007
    Yes, it worked, but you must set the start and stop time. I did 1 and 1/2 hours. You will know that it is working when both the oven light and the locked light turn on. Once finished, the oven light turn off but the locked light stays on until the oven cools. The whole process took me 3 hours.
Stove pilot is on but oven wont light?
How do you know the pilot is on? Most likely if actually burning gas pilot, you have a bad oven thermostat. or perhaps valve. If your question is about the light switch itself, that is a different issue and somewhat confusing.
Feb 27, 2015 | White-Westinghouse White Westinghouse...
How do I clean under the electric elements on my basic westinghouse stove
Hello friend, thanks for your post!
I understand that you would like to clean under the cooktop on your Frigidaire range. Could you provide me with your model number please? You can locate the serial tag (which lists your model number) on the storage drawer on the right hand side. With this information I can better assist you. -Matt
Sep 16, 2014 | Electrolux White Westinghouse Stove Range...
Westinghouse Self Cleaning Oven - Digital
hello susie,
try this site
http://kitchen.manualsonline.com/manuals/mfg/westinghouse/westinghouse_oven_product_list.html
May 13, 2013 | Kitchen Ranges
Older westinghouse stove won't unlock after self cleaning. I have tried to turn off main power and reset but won't work. Thanks
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Dec 24, 2010 | Microwave Ovens
I have a 1950's westinghouse electric stove and I am looking for parts. Specifically the heating element for the oven?
I have a 1950s westinghouse electric stove for sale with the original owners manual in mint condition... please email me if you are interested... mgsromaniello@yahoo.com
thanks and i look forward to hearing from you
Jul 27, 2010 | Kitchen Ranges
No instructions on how to use self cleaning Frigidaire range/oven
stove stuck in self cleaning mode door was open when cleaning mode was turned on will not shut now what do i need to bdo?
Feb 14, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
White-Westinghouse wall oven, no manual
after self cleaning I cannot open the door
Dec 18, 2009 | Ovens
Oven Door is locked and will not open
On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. Pull or push the rod to move the lock to the open position..
Jun 06, 2008 | GE JBP70SKSS Stainless Steel Electric...
Westinghouse stove
Turned the self cleaner on my electric stove although oven door at end of cleaning cycle would not open, it remained locked.
Would greatly appreciate any ideas.
Thanks
May 15, 2008 | Westinghouse Bethany Antique Brass- Indoor...
Kitchen Ranges Logo
17,288 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
