Question about Janome Sewing Machines
I have a Janome 1600P QC drags on a Little Gracie 2 frame
I have a Janome 1600P QC and use it on a Little Gracie 2, with the Sure Stitch Regulator.
The machine I was using before on the frame was a Janome 6600 with the Sure Stitch.
On both machines I've been using Valdani 50wt. thread in the top and bottom.
My problem. the machine will be stitching with no problems then all the sudden the machine will just slow down to a crawl for about 4 stitches then speed up all the sudden - be ok, then slow down again. I called Grace about it and they said it was the 6600 wasn't fast enough for the quilting, so I went out and purchased a faster machine that is giving me the same problems.
However, I did noticed that after cleaning the grooves in the carriage wheels it worked perfect for that row then the next row I did it started to drag again. I also noticed that the track on the right side of the frame was cracked - I couldn't figure out what was making a cracking noise then I discovered it when I ran a cloth across the track.
So I'm not sure if this is a machine problem, frame problem, or Sure Stitch problem?
Thanks,
  • 51 Answers
Sorry for your headache. It is the frame. If it is not level, balanced, you have hell to pay. Also it there is a nick in the grooves of the carriage tracks this will cause a machine problem. You may be able to repair the frame, or level it about the old level the table trick, put something under that part.
Good luck
Posted on Sep 06, 2009
Janome Memory Craft 8200QC Horizon. Can you get a stitch regulator? How does it work? Does it help to free motion stitch ?
You should check with a Janome dealer if your machine can use a stitch regulator. Machines that take a stitch regulator need the ability to plug into the machine, which is not available on a lot of machines unless they have the stitch regulator function. A stitch regulator helps some people. It still takes a lot of practice moving the fabric smoothly.
On my BSR, it has an "eye" that measures the distance the fabric moves under the presser foot so it can stitch at the specified distance. The faster the fabric moves, the faster it stitches, but the stitches tend to more uniform in length.
FWIW, I read a summary of the Janome 8200 QC Horizon and there was no mention of a stitch regulator.
http://freemotionquilting.blogspot.com/2011/05/piecing-quilting-on-janome-horizon-7700.html
Mar 11, 2017 | Janome Sewing Machines
Machine sews fine when it is set up on a table, but when it is on the Gracie II quilting frame and operated by their stitch regulator, the stitch quality is very bad. It varies from fair to very bad - I...
Use a carpenter's level to level up your frame, and be sure to keep the quilt leveled up to barely above the throat plate on the machine, and level front to back. Check the connections on the regulator sensors. If even one is not making good connection, you'll have skipped or broken stitches.
Jan 24, 2011 | Juki TL-98Q
Need help in using the grace sure stitch regulator of quilting
I am having irregular stitches on the forward/backward motion. I am using a Janome 16000 P on a Gracie II frame. (I purchased this as a used productin a private sale) Do I need a darning plate to effectively use the Sure Stitch regulator in a free motion mode or with a template?
Mar 04, 2010 | Janome Sewing Machines
I recently acquired a Janome 1600 with the Gracie II Frame. I am having trouble with the bobbin thread being too loose. How do I fix this.
Is the problem with the thread being wound too loose on the bobbin or is the bobbin thread too loose on your sewing? If it is the later, refer to your book on tightening the thread by turning the screw [very little at a time] on your bobbin case.
Oct 18, 2009 | Janome 1600P-DB Mechanical Sewing Machine
Feed Dogs on Janome 1600P
I recently purchased a Janome 1600P-DB and in order to do free motion quilting I had to cover the feed dogs with an index card. I also cut a small section out of the card to allow for the thread and needle to move freely. Standard tape was used.
Jun 14, 2009 | Janome 1600P-DB Mechanical Sewing Machine
Cannot get a straight stitch
Please check the top tension as well and rethread. I had this problem and after doing the above, everything worked perfectly. Thanks.
Mar 03, 2009 | Janome 1600P-DB Mechanical Sewing Machine
Needle Thread breaking after about 30 seconds of quilting
Make sure the feed dogs are dropped (or feed dog cover is on - I can't remember which way this machine works). The stitch length on the machine has no function so ignore it. (I set it to zero so the machine doesn't have to work as hard). Hopefully this is all that's wrong. If not, use a shorter setting for the stitch length on the regulator, oil the hook and move slowly and smoothly.
Jan 18, 2009 | Juki TL-98Q
Machine vibration
check to see if the machine is setting securely on the quilt frame .also check to see if the frame is setting level on the floor
May 01, 2008 | Janome 1600P-DB Mechanical Sewing Machine
Thread breaking
I HAVE THE SAME PROBLEM WITH THREAD BREAKING. HAVE TRIED EVERYTHING. FINALLY I GOT SOME UPHOLSTERY THREAD AND IT SEAMS TO WORK MUCH BETTER. NOW i AM HAVING TROUBLE FINDING THE NEEDLES FOR THIS MACHINE. NOT HAPPY WITH MACHINE AT ALL
Dec 09, 2007 | Janome 1600P-DB Mechanical Sewing Machine
Sewing Machines Logo
306 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
