Question about HP PSC 750 All-In-One InkJet Printer
Leaking psc750 HP
My psc750 HP is leaking (only the black) inkt out of the bottom.
What is wrong?
Wat can I do to solve?
  • c_vd_broek Sep 06, 2009
    Hy Stephan,
    the printer is from 2004 and the total amount of prints is today 14.969. The cartridge is orininal but I don't no how many times I change the past years. The ink is leaking (a lot) out of the bottom.
    Hope you can explane to me why.
    Thanks so far,
    Conny
  • Stephan Reichert
    Stephan Reichert May 11, 2010
    Hello, please submit the following information to your question to enable me to help you. How long have you had the printer? How many pages would you say you print in a months time? Do you remember how many times you have changed the cartridges? Are the cartridges original HP , Generic or refilled? Where on the printer is the ink leaking from? Regards Stephan
Insinkerator leaking from bottom
Any leak from bottom part of disposal means replacement.
Copy following link for specific troubleshoot, and replacement steps with tips.
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Nov 05, 2012 | Badger 5 Insinkerator 76037h 1/2 Hp Feed...
HP PSC 750 all-in-one - leaking black ink out of the bottom.\r\nIs there any solution?
Hello
Have a look at the link below, it should assist you in solving your problem.
Click HERE.
Kind regards
Michel
Sep 24, 2010 | HP PSC 750 All-In-One InkJet Printer
Leaking transmission fluid from the dipstik
does it bubble out the top or leak at the bottom?
Sep 14, 2009 | Chevrolet 2500 Cars & Trucks
My HP Deskject 932C started dripping a large quantity of black ink from many openings in the bottom plate of the printer. The ink cartridges have been removed, and black ink has been leaking out slowly for...
If you were using an original cartridge, contact HP and they will probably ask you to mail in the faulty cartridge.
If you were using a refilled cartridge you might have to buy a new printer.
Aug 06, 2009 | Office Equipment & Supplies
Psc750 alarm message: remove and check black cartridge.
There seems to be a problem with the cartridge. If it is printing normally, you can either live with the error, or replace the cartridge.
You can try cleaning the contacts with a q-tip and some rubbing alcohol just in case.
Jun 22, 2009 | HP PSC 750 All-In-One InkJet Printer
Leaking black in from the bottom of the printer
actually your printer needs servicing but for temprory solution.take a bunch of tissue paper .keep the printer on and the printer cover open so the cartridge will be in the center.then with the tissue paper place it internally on the side from where its leaking.the sponge which collects the wastage ink is at present got full and now it does not have the capacity to soak the ink.so its leaking.as you will place the tissue papers the ink will be soaked by tissue paper and the sponge will again become bit dry to soak more ink.but its the temprory solution.to make it permanent get the printer serviced and sponge replaced.the problem is not all serious ,its common.every printer comes to this stage after certain usage.and the servicing is the solution.a local printer repair shop also does the servicing job .
hope this helps.
thanks.
May 03, 2009 | HP Photosmart 8250 InkJet Printer
I changed the black ink cartridge in my HP Officejet K7100 series printer as it was gone and now it will not print anything
look in the printer menu for simple errors.
reset the inkt level.
or look if windows "sees" recognise the printer
Nov 18, 2008 | HP Office Equipment & Supplies
HP Photosmart C3180
when you start the printer alignment page will become come then it is put in the glass and scan it
your promblem will be solved
Jul 09, 2008 | HP Photosmart C3180 All-In-One InkJet...
Newly Installed 7680
probably you did nothing wring, I seen a few of these cartridges leak - HP should replace the machine if the damage was caused by original cartridges.
Apr 21, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP PSC 750 All-In-One InkJet Printer Logo
67 people viewed this question
Seeker5211
Seeker5211
